New streammux doesnt work with 2 channels
This is my configuration
• x86 Machine with dGPU
• DeepStream Version : deepstream-6.3
• TensorRT Version: 8.6.1.
• NVIDIA GPU Driver Version (valid for GPU only) : Driver Version: 535.86.10 CUDA Version: 12.2
• Issue Type: questions
• USE_NEW_NVSTREAMMUX=yes
I have a code that have 2 channels as mp4 files as input. Whenver I am trying to new streammux one of the video is frozen and other video is not even showed.
import sys
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
from common.bus_call import bus_call
import time
import threading
import os
import pyds
def attach_probe_to_pad(pad):
    print("Here\n")
    pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
def queue_status(delay_queue, i=0):
    while True:
        time.sleep(1)
        print(f"queue:{i}==>current-level-buffers={delay_queue.get_property('current-level-buffers')}")
def make_element(element_name, element_alias):
    element = Gst.ElementFactory.make(element_name, element_alias)
    if not element:
        sys.stderr.write(f"Unable to create {element_name}\n")
    return element
def decodebin_pad_added(decodebin, pad, nvvideoconvert):
    print("Decodebin pad added")
    caps = pad.get_current_caps()
    structure_name = caps.get_structure(0).get_name()
    if "video" in structure_name:
        pad.link(nvvideoconvert.get_static_pad("sink"))
def pgie_src_pad_buffer_probe(pad, info, u_data):
    print("Buffer probe called")
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer")
        return Gst.PadProbeReturn.OK
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
        print("Unable to get batch meta")
    l_frame = batch_meta.frame_meta_list
    if not l_frame:
        print("No frame meta list")
    while l_frame is not None:
        print("Processing frame")
        try:
            display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
            if not display_meta:
                print("Unable to acquire display meta from pool")
                break
            circle_params = display_meta.circle_params
            circle_index = 0
            num_circles = min(len(circle_params), 5)  # Ensure we do not exceed the allocated circles
            x_start = 100
            y_start = 100
            radius = 50
            spacing = 50
            for i in range(num_circles):
                circle_params[circle_index].xc = x_start + (radius * 2 + spacing) * i
                circle_params[circle_index].yc = y_start
                circle_params[circle_index].radius = radius
                circle_params[circle_index].circle_color.set(1.0, 0.0, 0.0, 0.5)  # Red color
                circle_index += 1
            display_meta.num_circles = circle_index
            pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        except StopIteration:
            break
        except Exception as e:
            print(f"Error processing frame: {e}")
            break
        try:
            l_frame = l_frame.next
            break
def main(args):
    Gst.init(None)
    pipeline = Gst.Pipeline.new("video-pipeline")
    # Create elements for the first source
    filesrc1 = make_element("filesrc", "filesrc1")
    filesrc1.set_property("location", "/opt/nvidia/deepstream/deepstream-6.3/samples/streams/fisheye_dist.mp4")
    decodebin1 = make_element("decodebin", "decodebin1")
    nvvideoconvert1 = make_element("nvvideoconvert", "nvvideoconvert1")
    videorate1 = make_element("videorate", "videorate1")
    capsfilter1 = make_element("capsfilter", "capsfilter1")
    caps1 = Gst.Caps.from_string("video/x-raw,framerate=25/1")
    capsfilter1.set_property("caps", caps1)
    nvvideoconvert2 = make_element("nvvideoconvert", "nvvideoconvert2")
    capsfilter2 = make_element("capsfilter", "capsfilter2")
    caps2 = Gst.Caps.from_string("video/x-raw(memory:NVMM), width=640, height=480")
    capsfilter2.set_property("caps", caps2)
    streammux = make_element("nvstreammux", "streammux")
    if os.environ["USE_NEW_NVSTREAMMUX"] == "yes":
        streammux.set_property("config-file-path", "/opt/nvidia/deepstream/deepstream-6.3/sources/src/streammux.txt")
    else:
        streammux.set_property("batched-push-timeout", 25000)
        streammux.set_property("width", 640)
        streammux.set_property("height", 480)
        streammux.set_property("batch-size", 2)
    nvstreamdemux = make_element("nvstreamdemux", "nvstreamdemux")
    nvvideoconvert3 = make_element("nvvideoconvert", "nvvideoconvert3")
    tee = make_element("tee", "tee")
    delay_queue = make_element("queue", "delay_queue")
    autovideosink_delay = make_element("autovideosink", "autovideosink_delay")
    autovideosink_delay.set_property("sync", True)
    # Create elements for the second source
    filesrc2 = make_element("filesrc", "filesrc2")
    filesrc2.set_property("location", "/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4")
    decodebin2 = make_element("decodebin", "decodebin2")
    nvvideoconvert4 = make_element("nvvideoconvert", "nvvideoconvert4")
    videorate2 = make_element("videorate", "videorate2")
    capsfilter3 = make_element("capsfilter", "capsfilter3")
    caps3 = Gst.Caps.from_string("video/x-raw,framerate=25/1")
    capsfilter3.set_property("caps", caps3)
    nvvideoconvert5 = make_element("nvvideoconvert", "nvvideoconvert5")
    capsfilter4 = make_element("capsfilter", "capsfilter4")
    caps4 = Gst.Caps.from_string("video/x-raw(memory:NVMM), width=640, height=480")
    capsfilter4.set_property("caps", caps4)
    nvvideoconvert6 = make_element("nvvideoconvert", "nvvideoconvert6")
    delay_queue2 = make_element("queue", "delay_queue2")
    autovideosink_delay2 = make_element("autovideosink", "autovideosink_delay2")
    autovideosink_delay2.set_property("sync", True)
    nvdsosd1 = make_element("nvdsosd","nvdsosd1")
    nvdsosd2 = make_element("nvdsosd","nvdsosd2")
    nvvideoconvert7 = make_element("nvvideoconvert", "nvvideoconvert7")
    nvvideoconvert8 = make_element("nvvideoconvert", "nvvideoconvert8")
    # Add elements to the pipeline
    elements = [
        filesrc1, decodebin1, nvvideoconvert1, videorate1, capsfilter1, nvvideoconvert2, capsfilter2,
        filesrc2, decodebin2, nvvideoconvert4, videorate2, capsfilter3, nvvideoconvert5, capsfilter4,
        streammux, nvstreamdemux, nvvideoconvert3, tee, delay_queue, autovideosink_delay,
        nvvideoconvert6, delay_queue2, autovideosink_delay2,nvdsosd1,nvdsosd2,nvvideoconvert7,nvvideoconvert8
    for element in elements:
        pipeline.add(element)
    # Link the first source elements
    filesrc1.link(decodebin1)
    def decodebin_pad_added1(decodebin, pad):
        print("Decodebin pad added for source 1")
            pad.link(nvvideoconvert1.get_static_pad("sink"))
    decodebin1.connect("pad-added", decodebin_pad_added1)
    nvvideoconvert1.link(videorate1)
    videorate1.link(capsfilter1)
    capsfilter1.link(nvvideoconvert2)
    nvvideoconvert2.link(capsfilter2)
    capsfilter2_pad = capsfilter2.get_static_pad("src")
    streammux_pad1 = streammux.get_request_pad("sink_0")
    capsfilter2_pad.link(streammux_pad1)
    # Link the second source elements
    filesrc2.link(decodebin2)
    def decodebin_pad_added2(decodebin, pad):
        print("Decodebin pad added for source 2")
            pad.link(nvvideoconvert4.get_static_pad("sink"))
    decodebin2.connect("pad-added", decodebin_pad_added2)
    nvvideoconvert4.link(videorate2)
    videorate2.link(capsfilter3)
    capsfilter3.link(nvvideoconvert5)
    nvvideoconvert5.link(capsfilter4)
    capsfilter4_pad = capsfilter4.get_static_pad("src")
    streammux_pad2 = streammux.get_request_pad("sink_1")
    capsfilter4_pad.link(streammux_pad2)
    # Link streammux to nvstreamdemux
    queue_before_demux = make_element("queue", "queue_before_demux")
    pgie = make_element("nvinferserver", "primary-inference")
    pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
    pipeline.add(queue_before_demux)
    # pipeline.add(pgie)
    streammux.link(queue_before_demux)
    # queue_before_demux.link(pgie)
    # pgie.link(nvstreamdemux)
    queue_before_demux.link(nvstreamdemux)
    # Attach the probe to the pad of the first stream
    # attach_probe_to_pad(demuxsrcpad1)
    pgie_src_pad = pgie.get_static_pad("src")
    if not pgie_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
    # Link nvstreamdemux -> nvvideoconvert3 -> delay_queue -> autovideosink_delay
    # Link nvstreamdemux -> nvvideoconvert3 -> nvdsosd -> delay_queue -> nvvideoconvert7 -> autovideosink_delay
    demuxsrcpad1 = nvstreamdemux.get_request_pad("src_0")
    if not demuxsrcpad1:
        sys.stderr.write("Unable to create demux src pad 1\n")
        return
    queuesinkpad1 = nvvideoconvert3.get_static_pad("sink")
    if not queuesinkpad1:
        sys.stderr.write("Unable to create queue sink pad 1\n")
        return
    demuxsrcpad1.link(queuesinkpad1)
    nvvideoconvert3.link(nvdsosd1)
    nvdsosd1.link(delay_queue)
    delay_queue.link(nvvideoconvert7)
    nvvideoconvert7.link(autovideosink_delay)
    # Link nvstreamdemux -> nvvideoconvert6 -> nvdsosd -> delay_queue2 -> nvvideoconvert8 -> autovideosink_delay2
    demuxsrcpad2 = nvstreamdemux.get_request_pad("src_1")
    if not demuxsrcpad2:
        sys.stderr.write("Unable to create demux src pad 2\n")
        return
    queuesinkpad2 = nvvideoconvert6.get_static_pad("sink")
    if not queuesinkpad2:
        sys.stderr.write("Unable to create queue sink pad 2\n")
        return
    demuxsrcpad2.link(queuesinkpad2)
    nvvideoconvert6.link(nvdsosd2)
    nvdsosd2.link(delay_queue2)
    delay_queue2.link(nvvideoconvert8)
    nvvideoconvert8.link(autovideosink_delay2)
    # Attach the probe to the pad of the second stream
    # attach_probe_to_pad(demuxsrcpad2)
    # Create an event loop and feed GStreamer bus messages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    pipeline.set_state(Gst.State.PAUSED)
    # Start the pipeline
    print("Now playing...")
    print("Starting pipeline\n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
        print(f"Error: {e}")
    # Cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
in the old streammux it is working. Please help me to fix the issue, also let us know how it can be mitigated.
Sorry for late reply. Could you attach the /opt/nvidia/deepstream/deepstream-6.3/sources/src/streammux.txt file you are using?
[property]
algorithm-type=1
batch-size=32
max-fps-control=1
min-fps-control=1
overall-max-fps-n=30
overall-max-fps-d=1
overall-min-fps-n=25
overall-min-fps-d=1
max-same-source-frames=1
Could you try to set the batch-size to 2?
        streammux.set_property("config-file-path", "streammux.txt")
 +      streammux.set_property("batch-size", 2)
    else:
You can refer to the FAQ to set the parameters for new nvstreammux.
Hi @yuweiw
It doesnt work on the batch-size=2 as well
you can refer to the FAQ to set the parameters for new nvstreammux.
I am following this, but clearly the simplest example doesnt work with new streammux
I am using DeepStream Version : deepstream-6.3
Should I use DS 7.0?
Yes. You can try that. I use your source code and config file on DS 7.0, and it can run normally after configuring batch-size=2. Did you just set the batch-size in the config file or add as the patch I attached in your source code?
Added as the patch in the python file.
I am planning to do the recovery as well in the new streammux, it was not working in 6.3,
What are all the improvement of new streammux in DS 7
Since there are also a 6.4 version in the middle, I’m sorry there are some improvements and bug fixes that cannot be fully listed.
The recovery or buffer was not working with new nvstreammux in 6.3, I just need to know if there is any improvement in those, I have asked the question here as well.
New Streammux removing and adding same channel, doesnt work
Yes. We have optimize this on the latest version 7.0. You can try that.
Thank you @yuweiw
