New to CUDA, Questions on Optimization
I’m relatively new to CUDA. Been dabbling in GPGPU for some time now, but just recently switched from ATI to NVIDIA, so the architecture and API are still a bit fresh to me.
So I’ve written a simple test program which generates pi using a monte carlo method. It’s a very inefficient way to find an approximation of pi, but it works well for a benchmark, and it’s easily parallelizable.
So I wanted to write an implementation of this pi approximation using both vanilla C++ and CUDA acceleration, to see what performance difference I could get out of the two.
Here is the vanilla code, to give you an idea of what this does:
#include <iostream>
#include <cstdlib>
#include <cmath>
#include <ctime>
using namespace std;
#define iterations 1000000000
int withinCircle(float& a, float& b)
	return (sqrt((a * a) + (b * b)) <= 1.0f);
void randomize(float* a, size_t size)
	for(size_t i = 0; i < size; i++) a[i] = (rand() / (float)RAND_MAX);
int main()
	int gridSize = 1024;
	int numGrids = iterations / gridSize + ((iterations % gridSize) ? 1 : 0);
	float* a = new float[gridSize];
	float* b = new float[gridSize];
	unsigned int hits = 0;
	srand(time(NULL));
	for(int i = 0; i < numGrids; i++)
		randomize(a, gridSize);
		randomize(b, gridSize);
		for(int j = 0; j < gridSize; j++) hits += withinCircle(a[j], b[j]);
	cout << "Pi = " << (hits * 4) / (float)iterations << endl;
	delete [] a;
	delete [] b;
I then modified this to use GPU acceleration:
#include <iostream>
#include <cmath>
#include <ctime>
#include <cstdlib>
__global__ void withinCircle(float* a, float* b, float* c)
	int idx = blockIdx.x * blockDim.x + threadIdx.x;
	float a_t = a[idx], b_t = b[idx];
	c[idx] = sqrt((a_t * a_t) + (b_t * b_t));
	for(int i = 0; i < size; i++)
int main()
	srand(time(NULL));
	unsigned long long hits = 0;
	int blocksPerGrid = 16384;
	int threadsPerBlock = 512;
	int gridSize = blocksPerGrid * threadsPerBlock;
	cout << numGrids << " Grids,\n" << blocksPerGrid << " Blocks per grid,\n" <<
		threadsPerBlock << " Threads per block\n" << endl;
	float* a_h = (float*)malloc(sizeof(float) * gridSize);
	float* b_h = (float*)malloc(sizeof(float) * gridSize);
	float* c_h = (float*)malloc(sizeof(float) * gridSize);
	float *a_d, *b_d, *c_d;
	cudaMalloc(&a_d, sizeof(float) * gridSize);
	cudaMalloc(&b_d, sizeof(float) * gridSize);
	cudaMalloc(&c_d, sizeof(float) * gridSize);
		randomize(a_h, gridSize);
		randomize(b_h, gridSize);
		cudaMemcpy(a_d, a_h, sizeof(float) * gridSize, cudaMemcpyHostToDevice);
		cudaMemcpy(b_d, b_h, sizeof(float) * gridSize, cudaMemcpyHostToDevice);
		withinCircle<<<blocksPerGrid, threadsPerBlock>>>(a_d, b_d, c_d);
		cudaThreadSynchronize();
		cudaMemcpy(c_h, c_d, sizeof(float) * gridSize, cudaMemcpyDeviceToHost);
		for(int i = 0; i < gridSize; i++) hits += (c_h[i] <= 1.0f);
	cudaFree(a_d);
	cudaFree(b_d);
	cudaFree(c_d);
	free(a_h);
	free(b_h);
	free(c_h);
	cout << hits << " hits, " << iterations << " iterations" << endl;
Both work as they should. Now, the single-threaded vanilla processor-only code completes in about 26 seconds. The CUDA accelerated version completes in 29 seconds. I know my CUDA accelerated version is far from being well optimized, so my question is how exactly you would optimize this. I know memory accesses are a huge performance killer with CUDA, and GPGPU in general, but with a kernel this simple, I really can’t quite understand how to improve memory access times.
Any tips on what you would do to optimize this would be greatly appreciated. This example program doesn’t have any real world application, but I’m trying to get a grasp in CUDA and the architecture through writing and optimizing this simple stuff.
Cheers.
The simplest way to boost performance would be to move the in-circle test onto the GPU as well. If you add a second kernel which implements the in-circle test and then performs a parallel reduction on the results in GPU memory, not only will you get the benefit of the GPUs higher memory bandwidth for the in-circle test and summation, but you will also greatly reduce the size of the memory transfer from GPU back to the host, which is probably a bottleneck in this code.
The holy grail would be to move the random number generation onto the GPU as well, but quality pseudo random number generation on the gpu is a more involved task. There are a few codes available for this if you want to try it - the CUDA SDK contains a Mersenne Primes based generator, and there is also this implementation of a Park-Miller generator. This isn’t really my area of interest, so I can’t speak to how good or bad they are.
