Hi all!
I am new to CUDA development.
I am trying to copy a 2D array of chars from the host memory to the device memory in order to perform some computation.
Unfortunately I did not manage to make it work.
Here is the code I am using:
char* table[3][3] = { {"col1", "col2", "colxxx"},
{"test1", "test2", "test3"},
{"test4", "test5", "test6"} };
// Host code
int width = 3, height = 3;
float* devPtr;
size_t pitch;
cudaMallocPitch(&devPtr, &pitch, width * sizeof(char*), height);
cudaMemcpy2D(devPtr, pitch, table, width*sizeof(char*), width*sizeof(char*), height, cudaMemcpyHostToDevice);
MyKernel<<<1, 1>>>(devPtr, pitch, width, height);
and the kernel code (which should simply print out the content of the matrix):
__global__ void MyKernel(float* devPtr,size_t pitch,int width, int height)
cuPrintf("Height: %d\n", height);
for (int r = 0; r < height; ++r) {
char** row = (char**)((char*)devPtr + r * pitch);
for (int c = 0; c < width; ++c) {
char* element = row[c];
cuPrintf("%s\n", &element);
I receive in output the string “Height: 4” and 12 empty lines.
I think the problem is that I am not actually copying the strings to the device, but only the pointers to these ones.
How could I solve this problem? Should I use 3D-arrays instead of 2D ones?
Thanks,
Andre
