(newbie) nvcc stops with "Parsing error near 'LL': syntax error"
When compiling a cuda file (.cu) the nvcc compiler stops compilation with the error message:
ptxas axial.xn08.ptx, line 65; fatal   : Parsing error near 'LL': syntax error
ptxas fatal   : Ptx assembly aborted due to errors
make: *** [libcu/axial.xn08.o] Error 255
The relevant c code is (the type integer is defined as ‘long int’):
/* Table of constant values */
__device__  integer c__9 = 9;
__device__  integer c__1 = 1;
__device__  integer c__3 = 3;
(within the file scope, i.e. not part of a function). BTW: the weird variable names stem from a fortran to c translation by f2c.
This gets translated into a ptx file of which the corresponding part is:
.global .s64 c__9 = 9LL;
	.global .s64 c__1 = 1;
	.global .s64 c__3 = 3LL;
I wondered where the ‘LL’ came from…
The parts of the (intermediate) file containing the relevant parts of the preprocessed files are:
axial.xn08.cpp1.ii:
__attribute__((__device__)) integer c__9 = 9;
__attribute__((__device__)) integer c__1 = 1;
__attribute__((__device__)) integer c__3 = 3;
and of axial.xn08.cpp2.i:
# 81 "libcu/axial.xn08.cu"
 __attribute__((__device__)) integer c__9 = 9L;
# 82 "libcu/axial.xn08.cu"
 __attribute__((__device__)) integer c__1 = 1L;
# 83 "libcu/axial.xn08.cu"
 __attribute__((__device__)) integer c__3 = 3L;
and of axial.xno8.cpp3
static __attribute__((__used__)) __attribute__((__device__)) integer c__9 = 9L;
static __attribute__((__used__)) __attribute__((__device__)) integer c__1 = 1L;
static __attribute__((__used__)) __attribute__((__device__)) integer c__3 = 3L;
It seems that nvcc adds an additional ‘L’ twice.
Anybody knows how to solve this or indicate what I am doing wrong?
My system is:
ubuntu 8.10,
cuda 2.1
nvidia driver version 180.22
graphics card: 9800 GT
gcc version 4.3.2
pieter@ubuntu:~/work/xnprogs.08.cuda$ /usr/local/cuda/bin/nvcc --version
Copyright (c) 2005-2007 NVIDIA Corporation
Built on Wed_Dec__3_16:25:17_PST_2008
Cuda compilation tools, release 2.1, V0.2.1221
thanks, pieter
