I’m currently looking into a simple CUDA example from here
It is a program where each position in an array of size N is incremented by one in both host code and device code. I have modified it a bit to time the execution of each method for comparison purposes.
The processing time is only lower for the device code for very large values of N so I wanted to introduce some more “work” for each position in the array to see how that would affect the difference. A for loop that increments an integer 1000 times was my first idea, but it doesn’t work very well. Here are the two functions with the for loops included.
[codebox]
void incrementArrayOnHost(int *a, int N)
for (int i=0; i < N; i++){
a[i] = a[i]+1;
int x=0;
for(int j=0; j<10000; j++){
x++;
global void incrementArrayOnDevice(int *a, int N)
int idx = blockIdx.x*blockDim.x + threadIdx.x;
if (idx<N){
a[idx] = a[idx]+1;
int x=0;
x++;
[/codebox]
The processing time for the device code stays roughly the same no matter how many times the for loop is run. But if I’m not mistaken x is a shared variable and all the threads cooperate to increment it? Any way to make it unique for each thread or maybe I should use another method to introduce more “work” for each thread.
