Hi all,
Newbie to AI / coding here :)
I just completed the first tutorial on DLI “getting started with AI on Jetson Nano”.
For the “Thumbs” image classification project, the AI prediction is displayed in a sliding widget from 0 to 1.
If for instance I want to export this result (print or add to a text file etc) in a particular instance (i.e. a snapshot), how would I code for this?
Thank you in advance!
I’ve attached the block of code for the “training and evaluation” section below:
BATCH_SIZE = 8
optimizer = torch.optim.Adam(model.parameters())
# optimizer = torch.optim.SGD(model.parameters(), lr=1e-3, momentum=0.9)
epochs_widget = ipywidgets.IntText(description='epochs', value=1)
eval_button = ipywidgets.Button(description='evaluate')
train_button = ipywidgets.Button(description='train')
loss_widget = ipywidgets.FloatText(description='loss')
accuracy_widget = ipywidgets.FloatText(description='accuracy')
progress_widget = ipywidgets.FloatProgress(min=0.0, max=1.0, description='progress')
def train_eval(is_training):
global BATCH_SIZE, LEARNING_RATE, MOMENTUM, model, dataset, optimizer, eval_button, train_button, accuracy_widget, loss_widget, progress_widget, state_widget
try:
train_loader = torch.utils.data.DataLoader(
dataset,
batch_size=BATCH_SIZE,
shuffle=True
state_widget.value = 'stop'
train_button.disabled = True
eval_button.disabled = True
time.sleep(1)
if is_training:
model = model.train()
else:
model = model.eval()
while epochs_widget.value > 0:
i = 0
sum_loss = 0.0
error_count = 0.0
for images, labels in iter(train_loader):
# send data to device
images = images.to(device)
labels = labels.to(device)
if is_training:
# zero gradients of parameters
optimizer.zero_grad()
# execute model to get outputs
outputs = model(images)
# compute loss
loss = F.cross_entropy(outputs, labels)
if is_training:
# run backpropogation to accumulate gradients
loss.backward()
# step optimizer to adjust parameters
optimizer.step()
# increment progress
error_count += len(torch.nonzero(outputs.argmax(1) - labels).flatten())
count = len(labels.flatten())
i += count
sum_loss += float(loss)
progress_widget.value = i / len(dataset)
loss_widget.value = sum_loss / i
accuracy_widget.value = 1.0 - error_count / i
if is_training:
epochs_widget.value = epochs_widget.value - 1
else:
break
except e:
pass
train_button.disabled = False
eval_button.disabled = False
state_widget.value = 'live'
train_button.on_click(lambda c: train_eval(is_training=True))
eval_button.on_click(lambda c: train_eval(is_training=False))
train_eval_widget = ipywidgets.VBox([
epochs_widget,
progress_widget,
loss_widget,
accuracy_widget,
ipywidgets.HBox([train_button, eval_button])
# display(train_eval_widget)
print("trainer configured and train_eval_widget created")
