I just recently upgraded to skylake. 6700K, maximus viii hero with the latest bios, and a 980 ti. Any program that is GUI related crashes with a segmentation fault when exited. Console based applications do not.
It seems to be hitting users on systems that use nvidia hardware with the newest official nvidia drivers. When using older nvidia drivers the issue goes away and doesn’t exist.
a temporary fix is either to downgrade the nvidia drivers if you have that option, compile glibc without --enable-lock-elision, or try that patch in the one arch thread that’s meant to work around the lock.
i tried the latest beta drivers with both the 4.2 and the newest released 4.3 kernel and still get the fault when glibc has elision enabled.
not sure if its really nvidia or if its intel just asking here since nvidia seems to be apart of it.
I can confirm this issue, same problem here on my system after hardware upgrade to Skylake.
After a hardware upgrade (new mainboard + CPU) on an existing Linux installation, many application are crashing and core dumping with a “general protection” trap. Example:
“traps: manjaro-setting[2091] general protection ip:7f10d10397e0 sp:7ffda2e13708 error:0 in libpthread-2.22.so[7f10d1027000+18000]”
Obvioulsy applications are affected when closing (trying to remove a lock that doesn’t exist any more?). The number and frequency of core dumps effectively renders the system unusable!
My hardware is composed of a MSI H170A GAMING PRO mainboard, Intel Skylake i5-6500 CPU and GTX 950 card.
I tried various system configurations, including kernel 4.2.5, 4.3.0, and using different BIOS version that loaded microcode versions 0.x33 or 0x49. The errors persisted.
I’m using the latest Manjaro packet “non-free Nvidia 352.55” drivers.
As a last resort, I re-compiled the current glibc and lib32-glibc sources specifying “–enable-lock-elision=no” option, installed these libs/apps, rebooted, and all such errors are gone!
MSI support hotline says they are using the latest microcode (0x49) that was provided by Intel, and can’t do anything else about it for the time being.
This happens on Ubuntu as well, but only once an alternative has been configured to use the NVIDIA libraries for EGL. For me, the crashes mostly seem to occur when the program quits, but it also causes the lock screen on Plasma 5 to crash in such a way as to always return to the lock screen after typing the password, which makes the system rather unusable.
There are some processors that have buggy TSX-NI (which always causes the lock elision segfaults), but the people in the thread above determined that this is a different problem that apparently began with the 352 drivers and continues up through 358.16. nvidia-bug-report.log.gz (103 KB)
