Newly installed drivers are not found when nvidia-smi is called.
I am trying to set up a new machine and the machine is not seeing the newly installed drivers.
nvidia-bug-report.log.gz (119 KB)
please try this:
  • install nvidia-prime (sudo apt install nvidia-prime)
  • switch to nvidia (sudo prime-select nvidia)
  • remove stray blacklist files (sudo rm /lib/modprobe.d/blacklist-nvidia.conf /etc/modprobe.d/blacklist-nvidia.conf)
  • update the initrd (sudo update-initramfs -u)
  • reboot
I have a very similar problem, the NVIDIA drivers cannot be loaded.
I’m using Ubuntu 18.04 with a GeForce GTX 1060 Mobile NVIDIA card.
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
What I tried so far:
Switch the nvidia profile
$ sudo prime-select nvidia
Info: the nvidia profile is already set
(Re)move blacklisted files
$ sudo mv /lib/modprobe.d/blacklist-nvidia.conf ~/
$ sudo mv /etc/modprobe.d/blacklist-nvidia.conf ~/
Update the initrd
$ sudo update-initramfs -u
Reboot
However, I still get
$ nvidia-smi
This is probably due to the fact that I cannot disable secure boot. When I disable secure boot in the BIOS, Ubuntu cannot boot. It freezes during boot, showing this error:
[FAILED] Failed to start NVIDIA Persistence Daemon.
See 'systemctl status nvidia-persistenced.service' for details
Here is some information:
$ systemctl status nvidia-persistenced.service
â—Ź nvidia-persistenced.service - NVIDIA Persistence Daemon
   Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2019-10-04 11:07:28 IST; 5min ago
  Process: 1168 ExecStopPost=/bin/rm -rf /var/run/nvidia-persistenced (code=exited, status=0/SUCCESS)
  Process: 1042 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, status=1/FAILURE)
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: Started (1052)
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for t
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: PID file unlocked.
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1042]: nvidia-persistenced failed to initialize. Check syslog for more details.
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: PID file closed.
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
Oct 04 11:07:28 pierre-G5 nvidia-persistenced[1052]: Shutdown (1052)
Oct 04 11:07:28 pierre-G5 systemd[1]: nvidia-persistenced.service: Control process exited, code=exited status=1
Oct 04 11:07:28 pierre-G5 systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
Oct 04 11:07:28 pierre-G5 systemd[1]: Failed to start NVIDIA Persistence Daemon.
The following files don’t exit, so that’s why the NVIDIA Persistence Daemon cannot start:
/dev/nvidia*
Any suggestions? Many thanks in advance.
nvidia-bug-report.log.gz (112 KB)
You have secure boot enabled, please disable it in bios.
Yes I know that secure boot is enabled but when I disable it, Ubuntu cannot boot because the NVIDIA Persistence Daemon cannot start (see my post above).
Does purging/reinstalling the nvidia driver after disabling secure boot help? Otherwise, please create a new nvidia-bug-report.log with secure boot disabled.
Brilliant! Uninstalling the Nvidia driver worked. Then I was able to disable secure boot. Then I reinstalled the Nvidia driver.
Here’s what I did:
Uninstalling NVIDIA driver
sudo apt-get remove --purge '^nvidia-.*'
sudo apt-get install ubuntu-desktop
sudo apt-get --purge remove "*cublas*" "cuda*"
sudo apt-get --purge remove "*nvidia*"
sudo add-apt-repository --remove ppa:graphics-drivers/ppa
sudo rm /etc/X11/xorg.conf
sudo apt autoremove
sudo reboot
Disable secure boot.
Reinstalling the driver
sudo ubuntu-drivers devices
sudo ubuntu-drivers autoinstall
sudo reboot
$ nvidia-smi
Fri Oct  4 13:53:43 2019
| NVIDIA-SMI 430.26       Driver Version: 430.26       CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 106...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   59C    P0    26W /  N/A |    713MiB /  6078MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0      1606      G   /usr/lib/xorg/Xorg                            98MiB |
|    0      1958      G   /usr/bin/gnome-shell                          52MiB |
|    0      2585      G   /usr/lib/xorg/Xorg                           391MiB |
|    0      2797      G   /usr/bin/gnome-shell                         105MiB |
|    0      3785      G   ...quest-channel-token=4785359086748578459    62MiB |
Many thanks Generix!
I disabled secure boot prior to posting my original query. I appreciate all the help everyone has replied with, but so far nothing has worked.
Looks like you installed the driver using the .run installer. Please uninstall it using the --uninstall option, then install the driver using Ubuntu’s software&updates application.
My issue was a bit different from the one below, but IT SAVED ME. In my case, after I had uninstalled everything using the direction below, I was doing:
but I wasn’t focused on the messages and the driver build was failing. When the build fails it will write a build log into your /var/lib/dkms/nvidia/… directory and that for me was the answer. I had screwed up where my CC compiler was pointing. I also add the newer versions of GCC, so that may have helped as well (mentioned in another post).
Thank you so much !!! This solved my problem after days of uninstall / install cycles.
When I uninstalled the NVIDIA drivers using pierre.aumjaud’s method, I checked the software and updates > Additional Drivers, and it said manual driver installation, and wouldn’t let me select anything else. I followed the exact steps and rebooted, switched to secure boot, and it still wouldn’t boot. Not sure whats wrong.
This worked for me after I reinstalled Ubuntu 21.04, but didn’t work for me in Ubuntu 20.04. I had to also do nvidia-settings and switch to Intel (or prime-select intel) before purging nvidia.
Many thanks!
Are you able to re-enable secure boot after downloading the nvidia drivers or do I need to keep it permanently disabled now?
It needs to stay disabled unless you configure module signing in Ubuntu using update-secureboot-policy
Or reinstall with secure boot enabled and on install, choose “Install third-party software” which also enables module signing.
This worked perfectly, thank you very much. I got a noob question the problem was because of the secure boot? Why?
I know this is very old but today I seem to have the same issue with 550 drivers, they were working before but stopped working now and I can’t disable secure boot because it’s a remote computer and I currently can’t physically get to it. I’m sure that this can be fixed without it because everything worked normally for months.
This works for me, but anyone know? why after install everything and completed install using driver 570, i got “no device were found” when prompt nvidia-smi
