NGC aarch64 pytorch containers .def files
Hi all, I am trying to install some packages into an NGC container for ARM CPU and NVIDIA GPU. I am however finding some errors with cmake.
Do you know where I can find the .def or dockerfiles used to build such containers? It would make it easier to install packaged directly with root (as I then run things with singularity on an HPC, which doesn’t allow root access)
