Hello NVIDIA community,
My apologies I have already put this into a different forum area. I just saw there is one for accounts.
I am experiencing an NVIDIA NGC account issue that is preventing me from deploying official NVIDIA NIM containers on my ASUS Ascent GX10 (NVIDIA GB10 / DGX Spark platform).
I have already contacted NVIDIA Support, and the issue has been escalated to a higher-level technical team. However, I would appreciate any additional guidance from NVIDIA engineers or community members who may have encountered this problem.
The problem
I can successfully:
Sign in to my NVIDIA account.
Access the NVIDIA NGC organization dashboard at https://org.ngc.nvidia.com.
See my organization listed under ORG OWNER in the organization selector.
Browse the NVIDIA NGC Catalog.
Navigate to https://org.ngc.nvidia.com/setup/api-keys.
Open the Personal API Key generation dialog and select the relevant service permissions, including NGC Catalog.
However, when I click Generate Personal Key, the portal returns the following error:
“Account does not exist.”
This happens despite being authenticated and having access to my NGC organization.
Impact
Without a working NGC Personal API Key, I cannot complete the required registry authentication and download the official NVIDIA NIM container images for my GX10.
This is blocking my planned evaluation of NVIDIA’s local inference models.
What I have already tried
Signing in to the NVIDIA NGC portal.
Accessing the organization dashboard and NGC Catalog.
Repeating the Personal API Key generation process.
Attempting NVIDIA container registry authentication, which was unsuccessful.
Contacting NVIDIA Support and providing a description of the issue.
I also have screenshots and a screen recording showing the exact failure.
Questions
Has anyone encountered the error “Account does not exist” when generating an NGC Personal API Key, despite successfully signing in?
Could this indicate a mismatch between the NVIDIA account identity, NGC organization membership, and backend account provisioning?
Is there a known provisioning or entitlement issue affecting NGC accounts used with DGX Spark / GB10 systems?
Is there an account-side check or repair procedure that NVIDIA Support can perform to resolve this?
I understand that this may require investigation by NVIDIA’s identity or NGC backend team rather than a local configuration change.
I would greatly appreciate any technical guidance or confirmation of a known issue.
Thank you for your help.
