After switching to a new 2.5G router, my spark’s network degraded to 100 Mbit/s. With the old 1G router it got the full speed. I tested both the cable and port with other 1G devices and they don’t drop to 100Mbit. (cat6 cable)
In case it’s relevant, my spark is a Lenovo PGX.
Any ideas? Has anyone run into issues like this?
Run sudo ethtool -I enP7s7 and post the output here.
This is reading on a FE Spark so I’m not sure if on the Lenove unit the port has the same label:
dgxspark@spark3:~$ sudo ethtool -I enP7s7
Settings for enP7s7:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 2500Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: on
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
Check advertised link modes locally and remote.
10baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Receive-only
10baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
1000baseT/Full
2500baseT/Full
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: on
Wake-on: g
Link detected: yes
When I reconnected the LAN yesterday evening, it got the full 2.5g but by the morning it had dropped back down to 100mbit /shrug
Maybe auto negotiation is failing. Does your router allow you to set it statically?
The same issue appeared on other network devices too, so I don’t think there’s anything wrong with the spark. It looks like the upstream Fritzbox I use as a cable modem somehow negotiated the link speed on the AP’s built in 2.5g switch. I didn’t even know that was possible.
Thanks for your help. Case closed I guess.
JW2026
September 1, 2026, 8:37am
7
Monitor for buffer over-run on the various interfaces if you have the visibility. 2.5Gbps also has tighter specs than 1 Gbps, so the cable might be borderline.
I had this happen to me and it was the cable.
jrsphd
September 1, 2026, 1:06pm
9
Cable connectors go bad over time and cause the drop once you lose a pair.
