Hi all,
I am using a TX2 with Astro carrier board.
I connected my camera on the non native NIC.
Somes frames were dropped.
So i decided to use the native NIC & every things went ok.
And so by pinging an IP through the other NIC (the non native one) i saw there were losts of ping delays very high :
nvidia@tegra-ubuntu:~$ ping 192.168.0.30
PING 192.168.0.30 (192.168.0.30) 56(84) bytes of data.
64 bytes from 192.168.0.30: icmp_seq=1 ttl=64 time=0.755 ms
64 bytes from 192.168.0.30: icmp_seq=2 ttl=64 time=0.530 ms
64 bytes from 192.168.0.30: icmp_seq=3 ttl=64 time=2.61 ms
64 bytes from 192.168.0.30: icmp_seq=4 ttl=64 time=2.17 ms
64 bytes from 192.168.0.30: icmp_seq=5 ttl=64 time=0.252 ms
64 bytes from 192.168.0.30: icmp_seq=6 ttl=64 time=2.04 ms
64 bytes from 192.168.0.30: icmp_seq=7 ttl=64 time=2.33 ms
64 bytes from 192.168.0.30: icmp_seq=8 ttl=64 time=0.332 ms
64 bytes from 192.168.0.30: icmp_seq=9 ttl=64 time=0.824 ms
64 bytes from 192.168.0.30: icmp_seq=10 ttl=64 time=1.97 ms
64 bytes from 192.168.0.30: icmp_seq=11 ttl=64 time=0.889 ms
64 bytes from 192.168.0.30: icmp_seq=12 ttl=64 time=0.925 ms
64 bytes from 192.168.0.30: icmp_seq=13 ttl=64 time=61.4 ms
64 bytes from 192.168.0.30: icmp_seq=14 ttl=64 time=65.8 ms
64 bytes from 192.168.0.30: icmp_seq=15 ttl=64 time=2.46 ms
64 bytes from 192.168.0.30: icmp_seq=16 ttl=64 time=2.77 ms
64 bytes from 192.168.0.30: icmp_seq=17 ttl=64 time=8.64 ms
64 bytes from 192.168.0.30: icmp_seq=18 ttl=64 time=2.09 ms
Do you have the same issue ?
I think this is why i had frame drops.
Bye
François
