我正在使用 NVIDIA NIM API 进行个人开发/测试。由于进行多智能体(Agentic Workflow)开发,单次任务会产生20-50次API调用环节,导致频繁遇到 429 Too Many Requests 错误,严重影响了开发进度。特此申请将速率限制从当前的 40 RPM 提升至 200 RPM。
user:gj-x@qq.com
gj-x
1
Related topics
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 472 | May 7, 2026 | |
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 186 | May 8, 2026 | |
| 尊敬的支持团队: 我正在使用 NVIDIA NIM API 进行个人开发/测试。由于进行多智能体(Agentic Workflow)开发,单次任务会产生20-50次API调用环节,导致频繁遇到 429 Too Many Requests 错误,严重影响了开发进度。特此申请将速率限制从当前的 40 | 0 | 84 | August 28, 2026 | |
| Request for NIM API Rate Limit Increase (40 → 200 RPM) | 0 | 133 | May 7, 2026 | |
| Rate limit increase request — 40 RPM to 200 RPM for Testing | 0 | 127 | May 24, 2026 | |
| 申请提高NVIDIA NIM API 速率限制(40 → 200 RPM) | 0 | 89 | June 4, 2026 | |
| 申请提升 NVIDIA NIM API 速率限制(40 RPM 至 200 RPM) | 1 | 185 | July 6, 2026 | |
| 申请提升 NVIDIA NIM API 速率限制(40 RPM 至 200 RPM) | 1 | 358 | July 5, 2026 | |
| 申请提高个人开发用 NVIDIA NIM API 速率限制至 200 RPM | 0 | 161 | May 22, 2026 | |
| Request to Increase NIM API Rate Limit (40 → 200 RPM) – Personal Development Use | 0 | 70 | May 16, 2026 |
