NIM embedding model downloads but fails with auth error on startup
Hi @naveansari, The NIM Team is recommending that you use the updated Embedding NIM - NVIDIA Retrieval QA Llama 3.2 1B Embedding v2 | NVIDIA NGC for your work - thanks, Sophie
I am having exactly same issue for /snowflake/arctic-embed-l
log:
–2025-02-04 07:37:40-- https://api.ngc.nvidia.com/v2/org/nim/team/snowflake/models/arctic-embed-l/versions/2_tokenizer/zip
Connecting to api.ngc.nvidia.com (api.ngc.nvidia.com)|35.161.3.4|:443… connected.
HTTP request sent, awaiting response… 410 Gone
2025-02-04 07:37:40 ERROR 410: Gone.
WARNING: tools.nim.ngc_models - Failed to download from nim/snowflake/arctic-embed-l:2_tokenizer: Failure from NGC CLI -
Thank you all for surfacing this issue. We are working to resolve on the backend mechanism enabling the model pull as part of the NIM deployment process. Will have a fix up by end of week and the issue should be resolved.
The issue is resolved. The NIMs can now be pulled again. Thank you for the fix, would appreciate it if we could get notice or warnings when certain images are going to be deprecated. Thanks once again
Hi @ai-intern Pleased that this is now working for you. Certainly we aim to share information when images are to be depreciated and will make sure to try to share that info in the future. Have a great week, Sophie
Hi @sophwats, was only the nv-embedqa-e5-v5 fixed? The error for the snowflake/arctic-embed-l:1.0.1 is still there and there doesn’t appear to be a new version released.
Thank you!
Hi @constantinos.xanthopoulos - I agree that the Snowflake model is still not working. Reaching out to the team now. Will get back to you asap. Thanks for your patience.
Sophie
Okay, I’ve just tested again and I can now launch the snowflake/arctic-embed-l:1.0.1 successfully. @constantinos.xanthopoulos what error are you seeing?
