NITO File Compatibility Between JetPack 7.2 and DriveOS 7.x — File Format vs. Tuning/Output Equivalence
Hello NVIDIA Team,
Jetpack7.x, DriveOS 7.x We have a few questions
  1. File usability: Setting aside official support, is it technically possible to load the exact same .nito binary file on both JetPack 7.2 (SIPL) and DriveOS 7.x (NvSIPL)? Or would this fail outright at load/parse time (e.g., due to a schema version mismatch or file header check), before any algorithmic difference even comes into play?
  2. Parameter values: If the same camera module is tuned/characterized separately for JetPack 7.2 and for DriveOS 7.x, would the resulting tuning parameter sets (AE/AWB targets, color correction matrix, noise reduction coefficients, etc.) actually contain the same values? Or does the tuning workflow/toolchain differ enough between the two stacks that the parameter values themselves would come out different, even for the identical camera hardware?
  3. Output equivalence: Assuming the same hardware configuration , if the exact same parameter values could somehow be applied on both the JetPack 7.2 SIPL pipeline and the DriveOS 7.x NvSIPL pipeline, would the two stacks produce the same ISP output (same AE/AWB behavior, color reproduction, noise reduction result) given identical input frames? Or is there an underlying difference in the ISP firmware / Auto Control algorithm / default pipeline behavior between the two stacks that would cause the output to differ even with identical parameter values?
In other words, we’re trying to understand whether the JetPack ↔ DriveOS NITO incompatibility is (a) purely a file-level restriction (schema/format rejection), (b) a difference in the tuning process itself that produces different values, and/or (c) a genuine algorithmic difference in how each stack’s ISP pipeline interprets/applies the same tuning data.
Any clarification on this would be very helpful for our test/validation planning.
Thank you
The DriveOS can only support on DRIVE platform, you can’t use it on Jetson platform, thus they’re not compatible.
May I know which platform you’re using now?
Thanks for the reply. We’re planning to work on Jetson AGX Thor (JetPack 7.2).
To clarify our question: we’re not trying to run DriveOS on Jetson. We plan to use the same .nito file as input on both platforms. Given that same input file and the same camera module (same sensor/serializer/deserializer):
  1. Would the parameter values actually applied internally by each stack stay identical, or does either stack reinterpret/override some values on load?
  2. Would the resulting ISP output be the same, or could it differ between JetPack and DriveOS even with the same input?
The ISP NITO file is different for the driver OS and L4T.
You need to generate new NITO for L4T.
Thank you for the answer.
One more follow-up: if we use identical parameter values on both JetPack and DriveOS, will the ISP output be the same, or will it be different? If different, is it because the internal ISP processing logic itself differs between the two stacks? Please confirm.
Suppose depend on which parameter.
Understood — so even with the same parameter values, the output may differ depending on the parameter type. Thank you for your help!
