Yes, the camera is always attached to the board.
I found after many tests that I have to write the contents of the file “tegra210-p3448-all-p3449-0000-camera-arducam-dual.dts” to “tegra210-porg-plugin-manager.dtsi”. This way gstnvarguscamerasrc can find the camera and run successfully.
As shown below:
hi, @JerryChang
I finally found the root cause of the problem.
The reason is that the “devname” in the “tegra210-p3448-all-p3449-0000-camera-arducam-dual.dts” file does not match the name set in the camera device tree.
Thank you for your long -term help.
