I retested on a different xavier board and the nvsipl_camera program worked as expected on both Tegra A and B. It seems the original xavier board has a HW issue. Is there any test I can run to verify HW? The board has only been used inside the office benchtop, it has not been used inside a vehicle.
not sure if this is related but please check “#4 Camera Interface Module (CIM) connector resulting from a non-optimized manufacturing process” and “APPENDIX A. SYSTEMS WITH OPTIMIZED
CIM MANUFACTURING PROCESS” in DRIVE AGX Developer Kit Hardware Errata to see if the platform is affected.
Dear @gordon1zrra,
If the issue persists even after re flashing the target, I suspect it should be HW issue. Could you share the board details( like S/N along with pictures) via private
For now I’m going to assume there is HW issue with TegraB PortA. This is not high priority for us since we don’t use TegraB PortA to capture camera data.
