No captured data from v4l2 driver (TC358743)
Yes I am seeing the same, thanks for your help!
Phil
I have enabled some extra debugging and this is what I see when I start gstreamer to capture the HDMI input, still trying to decipher it but it does seem to be trying to enable the stream?
[ 251.445993] tc358743 6-000f: Calling tc358743_g_input_status
[ 251.446670] tc358743 6-000f: tc358743_g_input_status: status =0x0
[ 251.448171] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.448176] tc358743 6-000f: fse->code 8207, index 0
[ 251.448179] tc358743 6-000f: ----------------------------------------
[ 251.448182] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1280, height: 720
[ 251.448189] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.448191] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.448202] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.448204] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.448211] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.448214] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.457026] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.457031] tc358743 6-000f: fse->code 8207, index 1
[ 251.457034] tc358743 6-000f: ----------------------------------------
[ 251.457039] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1920, height: 1080
[ 251.457046] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.457049] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.457059] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.457063] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.457071] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.457075] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.465810] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.465814] tc358743 6-000f: fse->code 8207, index 2
[ 251.465817] tc358743 6-000f: ----------------------------------------
[ 251.465819] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1280, height: 720
[ 251.465823] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.465824] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.465830] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.465832] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.465837] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.465839] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.474744] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.474746] tc358743 6-000f: fse->code 8207, index 3
[ 251.474748] tc358743 6-000f: ----------------------------------------
[ 251.474750] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1920, height: 1080
[ 251.474755] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.474756] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.474761] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.474763] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.474767] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.474770] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.483561] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.483564] tc358743 6-000f: fse->code 8207, index 4
[ 251.483567] tc358743 6-000f: ----------------------------------------
[ 251.483571] tc358743 6-000f: Error in tc358743_enum_frame_size, 4 outside of num_frmfmt (4)
[ 251.491845] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.491852] tc358743 6-000f: fse->code 4106, index 0
[ 251.491854] tc358743 6-000f: ----------------------------------------
[ 251.491857] tc358743 6-000f: Error in tc358743_enum_frame_size fse->code, code: 4106, UYVY: 1498831189, ARGB32: 875713089
[ 251.503293] tc358743 6-000f: Calling tc358743_get_fmt
[ 251.503297] tc358743 6-000f: Here 6b, colorspace: 1
[ 251.503299] tc358743 6-000f: get fmt complete
[ 251.503302] tc358743 6-000f: format width 1920
[ 251.503304] tc358743 6-000f: format height 1080
[ 251.503307] tc358743 6-000f: fmt_code: 8207
[ 251.503309] tc358743 6-000f: RGB888 code: 4106
[ 251.503311] tc358743 6-000f: UYVY8 code: 8207
[ 251.503314] tc358743 6-000f: tc358743_set_fmt(), ret: 0
[ 251.503317] tc358743 6-000f: Set format code: 4106
[ 251.503319] tc358743 6-000f: Good code 4106
[ 251.503653] tc358743 6-000f: Calling tc358743_get_fmt
[ 251.503658] tc358743 6-000f: Here 6b, colorspace: 1
[ 251.503661] tc358743 6-000f: get fmt complete
[ 251.503664] tc358743 6-000f: format width 1920
[ 251.503667] tc358743 6-000f: format height 1080
[ 251.503670] tc358743 6-000f: fmt_code: 8207
[ 251.503673] tc358743 6-000f: RGB888 code: 4106
[ 251.503675] tc358743 6-000f: UYVY8 code: 8207
[ 251.503678] tc358743 6-000f: tc358743_set_fmt(), ret: 0
[ 251.503680] tc358743 6-000f: Set format code: 4106
[ 251.503683] tc358743 6-000f: Good code 4106
[ 251.503719] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.503722] tc358743 6-000f: fse->code 8207, index 0
[ 251.503724] tc358743 6-000f: ----------------------------------------
[ 251.503726] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1280, height: 720
[ 251.503732] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.503734] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.503740] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.503743] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.503748] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.503751] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.512762] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.512766] tc358743 6-000f: fse->code 8207, index 1
[ 251.512768] tc358743 6-000f: ----------------------------------------
[ 251.512771] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1920, height: 1080
[ 251.512776] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.512778] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.512786] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.512789] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.512794] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.512798] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.521539] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.521544] tc358743 6-000f: fse->code 8207, index 2
[ 251.521547] tc358743 6-000f: ----------------------------------------
[ 251.521551] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1280, height: 720
[ 251.521558] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.521561] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.521569] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.521571] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.521578] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.521581] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.530399] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.530407] tc358743 6-000f: fse->code 8207, index 3
[ 251.530409] tc358743 6-000f: ----------------------------------------
[ 251.530412] tc358743 6-000f: tc358743_enum_frame_size() complete successfully, width: 1920, height: 1080
[ 251.530417] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.530419] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.530426] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.530428] tc358743 6-000f: tc358743_enum_frame_interval() completed
[ 251.530433] tc358743 6-000f: tc358743_enum_frame_interval()
[ 251.530438] tc358743 6-000f: Error in tc358743_enum_frame_interval num framerates (2 outside 2)
[ 251.539378] tc358743 6-000f: tc358743_enum_frame_size()
[ 251.539381] tc358743 6-000f: fse->code 8207, index 4
[ 251.539383] tc358743 6-000f: ----------------------------------------
[ 251.539385] tc358743 6-000f: Error in tc358743_enum_frame_size, 4 outside of num_frmfmt (4)
[ 251.548706] tc358743 6-000f: Calling tc358743_get_fmt
[ 251.548715] tc358743 6-000f: Here 6b, colorspace: 1
[ 251.548717] tc358743 6-000f: get fmt complete
[ 251.548720] tc358743 6-000f: format width 1920
[ 251.548722] tc358743 6-000f: format height 1080
[ 251.548724] tc358743 6-000f: fmt_code: 8207
[ 251.548726] tc358743 6-000f: RGB888 code: 4106
[ 251.548728] tc358743 6-000f: UYVY8 code: 8207
[ 251.548731] tc358743 6-000f: tc358743_set_fmt(), ret: 0
[ 251.548733] tc358743 6-000f: Set format code: 8207
[ 251.548735] tc358743 6-000f: Good code 8207
[ 251.549099] tc358743 6-000f: Calling tc358743_get_fmt
[ 251.549102] tc358743 6-000f: Here 6b, colorspace: 1
[ 251.549104] tc358743 6-000f: get fmt complete
[ 251.549106] tc358743 6-000f: format width 1920
[ 251.549108] tc358743 6-000f: format height 1080
[ 251.549110] tc358743 6-000f: fmt_code: 8207
[ 251.549112] tc358743 6-000f: RGB888 code: 4106
[ 251.549114] tc358743 6-000f: UYVY8 code: 8207
[ 251.549116] tc358743 6-000f: tc358743_set_fmt(), ret: 0
[ 251.549118] tc358743 6-000f: Set format code: 8207
[ 251.549121] tc358743 6-000f: Good code 8207
[ 251.549123] tc358743 6-000f: enable_stream: disable
[ 251.549373] tc358743 6-000f: I2C write 0x857f = 0xd0
[ 251.549376] tc358743 6-000f: Reading i2c_rd16
[ 251.549752] tc358743 6-000f: RET 0
[ 251.549981] tc358743 6-000f: I2C write 0x0004 = 0x0cd4
[ 251.549985] tc358743 6-000f: 836:enable_stream: end
[ 251.549988] tc358743 6-000f: Reading i2c_rd16
[ 251.550271] tc358743 6-000f: RET 0
[ 251.550274] tc358743 6-000f: Reading i2c_rd16
[ 251.550560] tc358743 6-000f: RET 0
[ 251.550564] tc358743 6-000f: tc358743_set_pll:
[ 251.550567] tc358743 6-000f: tc358743_set_csi:
[ 251.550570] tc358743 6-000f: Reading i2c_rd16
[ 251.550855] tc358743 6-000f: RET 0
[ 251.551088] tc358743 6-000f: I2C write 0x0002 = 0x0e00
[ 251.551322] tc358743 6-000f: I2C write 0x0002 = 0x0c00
[ 251.551604] tc358743 6-000f: I2C write 0x0150 = 0x00000001
[ 251.551886] tc358743 6-000f: I2C write 0x0210 = 0x00001770
[ 251.552165] tc358743 6-000f: I2C write 0x0214 = 0x00000005
[ 251.552445] tc358743 6-000f: I2C write 0x0218 = 0x00002004
[ 251.552739] tc358743 6-000f: I2C write 0x021c = 0x00000001
[ 251.553021] tc358743 6-000f: I2C write 0x0220 = 0x00000606
[ 251.553301] tc358743 6-000f: I2C write 0x0224 = 0x00004a38
[ 251.553744] tc358743 6-000f: I2C write 0x0228 = 0x00000008
[ 251.554013] tc358743 6-000f: I2C write 0x022c = 0x00000005
[ 251.554282] tc358743 6-000f: I2C write 0x0230 = 0x00000005
[ 251.554554] tc358743 6-000f: I2C write 0x0234 = 0x0000000f
[ 251.554828] tc358743 6-000f: I2C write 0x0238 = 0x00000000
[ 251.555101] tc358743 6-000f: I2C write 0x0204 = 0x00000001
[ 251.555374] tc358743 6-000f: I2C write 0x0518 = 0x00000001
[ 251.555646] tc358743 6-000f: I2C write 0x0500 = 0xa3008084
[ 251.555920] tc358743 6-000f: I2C write 0x0500 = 0xb4000312
[ 251.556183] tc358743 6-000f: I2C write 0x0500 = 0xd5000012
[ 251.556445] tc358743 6-000f: I2C write 0x0500 = 0xa6000004
[ 251.556448] tc358743 6-000f: tc358743_set_csi_color_space: YCbCr 422 16-bit
[ 251.556869] tc358743 6-000f: I2C write 0x8573 = 0xc1
[ 251.557292] tc358743 6-000f: I2C write 0x8576 = 0x60
[ 251.557294] tc358743 6-000f: Reading i2c_rd16
[ 251.557666] tc358743 6-000f: RET 0
[ 251.557880] tc358743 6-000f: I2C write 0x0004 = 0x0cd4
[ 251.557883] tc358743 6-000f: Called tc358743_set_fmt
That’s the kind of output I get, I added a bunch of logging around the frame format stuff because I thought the error might be there but not I’m less sure, I think it just increments the index until it runs out of possible formats so an ā€˜error’ occurs.
Having commented out the other two lines that @electrixoul suggested I am now able to capture a fully green video via gstreamer! This makes me think that the device tree is now working and we just need to solve the frame format. The detected timings are 50fps but the driver can currently only capture 60fps so I’m going to experiment around that.
I have uploaded my latest code (including the missing files from before) to the same gist as before (this one) and added a WIP readme that should help people getting started when working on this driver.
Yes I came to the same conclusion, it looks like it isn’t finding a suitable frame format so it is failing. I did read somewhere that the tc358743 doesn’t always correctly recognise the frame height so I wonder if that’s the issue?
I will have a look at your latest code.
I accidentally uploaded the tc358840 code because I’ve been using that as a reference driver, corrected now so it should just be the tc358743 code
Yes I thought you had, I was just going to comment!
I’m gettting a green screen when I run gststreamer as well, this is using a 720p60 input.
@robert.j.h.chandler Thank you very much ! that was of great help !
but unlike you guys getting green screen , I didn’t , I’ll post my observations later
Hi Robert , this is my results (I’m using Jetson Nano B01 dev-board which have 2-physical CSI ports):
  1. running command ā€œv4l2-ctl --log-statusā€
Status Log:
   [  206.625273] vi 54080000.vi: =================  START STATUS  =================
   [  206.626639] tc358743 6-000f: -----Chip status-----
   [  206.627001] tc358743 6-000f: Chip ID:0x00
   [  206.627342] tc358743 6-000f: Chip revision:0x00
   [  206.627350] tc358743 6-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
   [  206.627356] tc358743 6-000f: Sleep mode: off
   [  206.627362] tc358743 6-000f: Cable detected (+5V power): yes
   [  206.627679] tc358743 6-000f: DDC lines enabled: yes
   [  206.627994] tc358743 6-000f: Hotplug enabled: yes
   [  206.628329] tc358743 6-000f: CEC enabled: no
   [  206.628334] tc358743 6-000f: -----Signal status-----
   [  206.628340] tc358743 6-000f: TMDS signal detected: yes
   [  206.628345] tc358743 6-000f: Stable sync signal: yes
   [  206.628351] tc358743 6-000f: PHY PLL locked: yes
   [  206.628356] tc358743 6-000f: PHY DE detected: yes
   [  206.632204] tc358743 6-000f: 496:tc358743_get_detected_timings: width 1920 heigh 1080 interlaced 0
   [  206.632213] tc358743 6-000f: Detected format: 1920x1080p50.0 (2640x1125)
   [  206.632218] tc358743 6-000f: horizontal: fp = 0, -sync = 720, bp = 0
   [  206.632224] tc358743 6-000f: vertical: fp = 0, -sync = 45, bp = 0
   [  206.632228] tc358743 6-000f: pixelclock: 148500000
   [  206.632234] tc358743 6-000f: flags (0x0):
   [  206.632240] tc358743 6-000f: standards (0x0):
   [  206.632247] tc358743 6-000f: Configured format: 1920x1080p60.0 (2200x1125)
   [  206.632252] tc358743 6-000f: horizontal: fp = 88, +sync = 44, bp = 148
   [  206.632260] tc358743 6-000f: vertical: fp = 4, +sync = 5, bp = 36
   [  206.632265] tc358743 6-000f: pixelclock: 148500000
   [  206.632270] tc358743 6-000f: flags (0x12): CAN_REDUCE_FPS CE_VIDEO
   [  206.632274] tc358743 6-000f: standards (0x3): CEA DMT
   [  206.632278] tc358743 6-000f: -----CSI-TX status-----
   [  206.632282] tc358743 6-000f: Lanes needed: 4
   [  206.632642] tc358743 6-000f: Lanes in use: 4
   [  206.632952] tc358743 6-000f: Waiting for particular sync signal: no
   [  206.633261] tc358743 6-000f: Transmit mode: yes
   [  206.633572] tc358743 6-000f: Receive mode: no
   [  206.633873] tc358743 6-000f: Stopped: no
   [  206.633876] tc358743 6-000f: Color space: YCbCr 422 16-bit
   [  206.634117] tc358743 6-000f: -----DVI-D status-----
   [  206.634120] tc358743 6-000f: HDCP encrypted content: no
   [  206.634122] tc358743 6-000f: Input color space: RGB full range
   [  206.634367] vi 54080000.vi: ==================  END STATUS  ==================
  1. running command ā€œgst-launch-1.0 -vvvvv v4l2src ! ā€œvideo/x-raw, width=1920, height=1080, framerate=60/1,format=UYVYā€ ! nvvidconv ! omxh264enc ! mpegtsmux ! filesink location=test.tsā€ :
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)60/1, interlace-mode=(string)progressive
Framerate set to : 60 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)60/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)UYVY, colorimetry=(string)2:3:5:4, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:src: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)byte-stream, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/MpegTsMux:mpegtsmux0.GstPad:sink_65: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)byte-stream, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/MpegTsMux:mpegtsmux0.GstPad:src: caps = video/mpegts, systemstream=(boolean)true, packetsize=(int)188
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/mpegts, systemstream=(boolean)true, packetsize=(int)188
/GstPipeline:pipeline0/MpegTsMux:mpegtsmux0.GstPad:src: caps = video/mpegts, systemstream=(boolean)true, packetsize=(int)188, streamheader=(buffer)< 47400030a600ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff0000b00d0001c100000001e020a2c32941, 474020308b00ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff0002b0280001c10000e041f00c050448444d5688040ffffcfc1be041f00a050848444d56ff1b443f5a3175c0 >
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/mpegts, systemstream=(boolean)true, packetsize=(int)188, streamheader=(buffer)< 47400030a600ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff0000b00d0001c100000001e020a2c32941, 474020308b00ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff0002b0280001c10000e041f00c050448444d5688040ffffcfc1be041f00a050848444d56ff1b443f5a3175c0 >
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:07.046914529
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
(no green screen shows)
  1. running command ā€œv4l2-ctl --device /dev/video0 --stream-mmapā€
New timings found
55457.27 fps
it shows ā€œ55457.27 fpsā€ which is super weird
  1. running command ā€œv4l2-ctl --device /dev/video0 --stream-mmap --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-to=frame.raw --stream-count=10 --verboseā€
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
	Width/Height      : 1920/1080
	Pixel Format      : 'UYVY' (UYVY 4:2:2)
	Field             : None
	Bytes per Line    : 3840
	Size Image        : 4147200
	Colorspace        : SMPTE 170M
	Transfer Function : Rec. 709
	YCbCr/HSV Encoding: Rec. 709
	Quantization      : Limited Range
	Flags             :
New timings found
		VIDIOC_REQBUFS returned 0 (Success)
		VIDIOC_QUERYBUF returned 0 (Success)
		VIDIOC_QBUF returned 0 (Success)
		VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq:      0 bytesused: 4147200 ts: 0.000000 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq:      1 bytesused: 4147200 ts: 0.000000 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq:      2 bytesused: 4147200 ts: 0.000000 (ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq:      3 bytesused: 4147200 ts: 0.000000 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq:      4 bytesused: 4147200 ts: 0.000000 fps: 59.68 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq:      5 bytesused: 4147200 ts: 0.000000 fps: 59.28 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq:      6 bytesused: 4147200 ts: 0.000000 fps: 59.90 (ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq:      7 bytesused: 4147200 ts: 0.000000 fps: 59.58 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq:      8 bytesused: 4147200 ts: 0.000000 fps: 60.26 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq:      9 bytesused: 4147200 ts: 0.000000 fps: 59.60 (ts-monotonic, ts-src-eof)
For 2. the pipeline records to a file called test.ts in the directory that you ran the command from. If you play the file you’ll probably see a green video playing
you are right , thank you !
Also, the frame.raw that you captured in 4. can be converted to png with the command:
convert -size 1920x1080 -depth 16 uyvy:frame.raw frame.png
I tried it earlier and this was green as well!
If you want to display the captured video live on the Jetson Nano (currently displays a green image!) you can run the command:
gst-launch-1.0 -vvvvv v4l2src ! nvvidconv ! nvegltransform ! nveglglessink -e
Cheers
Phil
@phil1 @robert.j.h.chandler
just googled ā€œgst-launch green screenā€ and found a lot of topics, one saying :
ā€˜green’ color indicates uninitialized memory in YUV formats. This could eg. be the nvvidconv not filling all pars of the buffer.
so I guess the shared memory which VI module was about to write is empty ? that could be the reason of green screen
I also wonder if we’ve got the bus width/port index correct in the DT
The ā€˜Port Index’ section in the Sensor Programming Guide would suggest that the bus width of CSI-B is only 2 where in the DT I specified a bus width of 4. I’m wondering if the connector on the dev kit is connected to CSI-A and CSI-B or just CSI-B?
From the schematic it seems like theFPC connector is for CSI0 with 4 lanes, but it’s not clear what CSI0 means in terms of the CSI-A, CSI-B, etc.
I altered DTSI file :
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#include <dt-bindings/gpio/gpio.h>
host1x {
    vi_base: vi {
        num-channels = <1>;  // Change 4->2
        ports {
            #address-cells = <1>;
            #size-cells = <0>;
            vi_port1: port@0 {
                status = "okay";
                reg = <0>;
                tc358743_vi_in1: endpoint {
                    status = "okay";
                    port-index = <0>;  /* CSI-B */
                    bus-width = <2>; /* Use CSI-B only */
                    remote-endpoint = <&tc358743_csi_out0>;
    csi_base: nvcsi {
        num-channels = <1>;
        #size-cells = <0>;
        channel@0 {
            reg = <0>;
            ports {
                #size-cells = <0>;
                port@0 {
                    status = "okay";
                    reg = <0>;
                    tc358743_csi_in0: endpoint@0 {
                        status = "okay";
                        port-index = <0>;
                        bus-width = <2>;
                        remote-endpoint = <&tc358743_out1>;
                port@1 {
                    reg = <1>;
                    status = "okay";
                    tc358743_csi_out0: endpoint@1 {
                        status = "okay";
                        remote-endpoint = <&tc358743_vi_in1>;
    i2c@546c0000 {  /* I2C_PM, "adapter" 6 */
        status = "okay";
        #size-cells = <0>;
        tc358743@0f {
            status = "okay";
            compatible = "tc358743";
            reg = <0x0f>; /* shifted by 2 */
            mclk = "cam_mclk1";
            reset-gpios = <&gpio 149 0>;
            refclk_hz = <27000000>;  // refclk_hz -> regclk
	        interrupt-parent = <&gpio>;
	        interrupts = <TEGRA_GPIO(E, 6) GPIO_ACTIVE_HIGH>;
            /* Physical dimensions of sensor */
            physical_w = "4.713";
            physical_h = "3.494";
            /* Sensor Model */
            sensor_model ="tc358743";
            ddc5v_delay = <2>;
            enable_hdcp = "false";
            lineinitcnt = <0xe80>;
            lptxtimecnt = <0x003>;
            tclk_headercnt = <0x1403>;
            tclk_trailcnt = <0x00>;
            ths_headercnt = <0x0103>;
            twakeup = <0x4882>;
            tclk_postcnt = <0x008>;
            ths_trailcnt = <0x02>;
            hstxvregcnt = <0>;
            ports {
                #size-cells = <0>;
                port@0 {
                    reg = <0>;
                    tc358743_out1: endpoint {
                        port-index = <0>; /* CSI B */
                        data-lanes = <1 2>;
                        clock-lanes = <0>;
                        clock-noncontinuous;
                        link-frequencies = /bits/ 64 <297000000>;
                        remote-endpoint = <&tc358743_csi_in0>;
tegra-camera-platform {
    status = "okay";
	compatible = "nvidia, tegra-camera-platform";
	num_csi_lanes = <2>;  // Changed 2 -> 4
	max_lane_speed = <1500000>;
	min_bits_per_pixel = <10>;  // Changed 16 -> 10
	vi_peak_byte_per_pixel = <2>;
	vi_bw_margin_pct = <25>;
	max_pixel_rate = <750000>;
	isp_peak_byte_per_pixel = <5>;
	isp_bw_margin_pct = <25>;
	* The general guideline for naming badge_info contains 3 parts, and is as follows,
	* The first part is the camera_board_id for the module; if the module is in a FFD
	* platform, then use the platform name for this part.
	* The second part contains the position of the module, ex. ā€œrearā€ or ā€œfrontā€.
	* The third part contains the last 6 characters of a part number which is found
	* in the module's specsheet from the vender.
	modules {
	    module1 {
	        status = "okay";
	        badge = "tc358743_top_i2c6_b";
	        position = "front";
	        orientation = "1";
	        drivernode0 {
	            status = "okay";
	            /* Declare PCL support driver (classically known as guid)  */
	            pcl_id = "v4l2_sensor";
	            /* Driver's v4l2 device name */
	            devname = "tc358743 6-000f";
	            /* Declare the device-tree hierarchy to driver instance */
	            proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tc358743@0f";
it works normally, except this time gst-launch shows a frozen-transparent window instead of a green window:
output of ā€œmedia-ctl -p -d /dev/media0ā€ :
root@t-desktop:~/i2c# media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver          vi
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  0.0.0
Device topology
- entity 1: nvcsi--1 (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
	pad0: Sink
		<- "tc358743 6-000f":0 [ENABLED]
	pad1: Source
		-> "vi-output, tc358743 6-000f":0 [ENABLED]
- entity 4: tc358743 6-000f (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev1
	pad0: Source
		[fmt:UYVY8_1X16/1920x1080 field:none colorspace:smpte170m]
		[dv.caps:BT.656/1120 min:1x1@0 max:10000x10000@165000000 stds:CEA-861,DMT,CVT,GTF caps:progressive,reduced-blanking,custom]
		[dv.detect:BT.656/1120 1920x1080p50 (2640x1125) stds: flags:]
		[dv.current:BT.656/1120 1920x1080p50 (2640x1125) stds:CEA-861 flags:CE-video]
		-> "nvcsi--1":0 [ENABLED]
- entity 6: vi-output, tc358743 6-000f (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
	pad0: Sink
		<- "nvcsi--1":1 [ENABLED]
