No compile error when calling device-only method from templated class on host, using nvcc
When I compile the following code with nvcc, I would expect to get a compile error because Functor::print() is only defined on the device but it’s called from a host function hostExecutefunctor(F f). However, the compiler finishes without a single warning. When I run the compiled program, it fails silently when executing f.print() This means my program only prints the line “About to execute the functor”.
#include <stdio.h>
struct Functor
  __device__ void print()
    printf("Printing\n");
template <class F>
void hostExecuteFunctor(F f)
  printf("About to execute the functor\n");
  f.print();
int main()
  Functor f;
  hostExecuteFunctor(f);
  printf("Successfully finished the program.\n");
  return 0;
The problem could be solved by specifying the functor method as __host__ __device__, but I rather stay minimalistic so it’s clear which methods will never run on CPU.
However, we have a lot of these functors in our code and a mistake is quickly made. Is there a way to get a compile error when the situation specified above occurs?
PS: I noticed that the other way around, calling a host function from a device function, the compiler does give an error. See the example below.
#include <stdio.h>
struct Functor
  void print()
template <class F>
__global__ void kernelExecuteFunctor(F f)
  f.print();
int main()
  Functor f;
  kernelExecuteFunctor<<<1, 1>>>(f);
  cudaDeviceSynchronize();
  return 0;
Compile error:
silent_error_cpu.cu(16): error: calling a __host__ function("Functor::print") from a __global__ function("kernelExecuteFunctor<    ::Functor> ") is not allowed
My setup:
Operating system: Ubuntu 20.04
CUDA toolkit installed via ubuntu package ‘nvidia-cuda-toolkit’. Version : 10.1.243-3
NVIDIA driver version: 440.100
This maps to nvbug 4783921 . We will get back conclusion here when the ticket cycle is completed internally .
[Public] Hi Thomas ,
After our engineering team’s investigating , we think this is expected behavior . Calling a device only function from host code is a user error.
This is a documented undefined behavior case in the cuda c++ programming guide. Ref: CUDA C++ Programming Guide
Under the hood, nvcc introduces a dummy call for the device function “print” (needed for device function registration) which ends up being called in the case.
Throwing a warning for this is not straight forward as the host code is being compiled by the host compiler which we have no control over.
Best,
Yuki
