Hi, there.
We are having problem connecting to CloudXR server.
Client: Oculus Quest 2
Server: AWS EC2 g4dn.xlarge instance
Image: NVIDIA Gaming PC - Windows Server 2016
Server IP: 13.209.67.66
Maybe someone have a build .apk file for Oculus Quest 2 to test the connection between the client and server?
Or someone try to connecting to the server and see if it works?
Logs
SteamVR System Report created Wed Aug 28 07:00:13 2024
SteamVR Version: 2.7.4 (1721847232) SteamVR Date: 2024-07-24 Steam: Public Steam Branch: Steam AppID: 250820 Tracking: No Driver OS: Windows 10 OS Version: 10.0.0.14393 Direct Mode Vendor: NVIDIA Direct Mode Version: 446.16 Admin: Yes Performance drops: 0/1 0/2 0/3 0/4 0/0 Display Mode: Extended Display DeviceName: \\.\DISPLAY1 DeviceDirectMode: No DevicePrimary: Yes DeviceRect: 1680x1050 @ (0, 0) DeviceString: NVIDIA Tesla T4 DeviceID: PCI\VEN_10DE&DEV_1EB8&SUBSYS_12A210DE&REV_A1 DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video\{65AF8CAD-DA24-4DA8-A2E1-005A36635B9D}\0000 DeviceMonitorCount: 0 === vrserver.txt - C:/Program Files (x86)/Steam/logsWed Aug 28 2024 06:57:14.145 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:14.145 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:14.145 [Info] - vrserver.exe 2.7.4 startup with PID=4828, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:14.145 [Info] - [vrserver] watchdogs enabled
Wed Aug 28 2024 06:57:14.148 [Info] - CSharedResourceNamespaceServer starting up
Wed Aug 28 2024 06:57:14.148 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: 1
Wed Aug 28 2024 06:57:14.148 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:14.148 [Error] - CSharedResourceNamespaceClient::Init(): failed connect
Wed Aug 28 2024 06:57:14.148 [Warning] - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Wed Aug 28 2024 06:57:14.149 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: -15
Wed Aug 28 2024 06:57:14.193 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:14.194 [Info] - CSharedResourceNamespaceServer sent namespace data: 4828
Wed Aug 28 2024 06:57:14.249 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:14.260 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:14.260 [Info] - CSharedResourceNamespaceServer sent namespace data: 4828
Wed Aug 28 2024 06:57:14.260 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 4828
Wed Aug 28 2024 06:57:14.260 [Info] - Self queried namespace: 4828
Wed Aug 28 2024 06:57:14.261 [Info] - [Init] VR server 2.7.4 (v1721847232) starting up with config=C:\Program Files (x86)\Steam\config
Wed Aug 28 2024 06:57:14.261 [Info] - [Init] VRServer will wait for VRMonitor before exiting
Wed Aug 28 2024 06:57:14.267 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.268 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.268 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.268 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.269 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.269 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.271 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:14.278 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.278 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.278 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.278 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.279 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.280 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.281 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:14.290 [Info] - [Display] Enabling direct mode for NVIDIA [Vid=0xD94D Pid=0xC207]…
Wed Aug 28 2024 06:57:14.290 [Error] - [Display] Failed to set display visibility.
Wed Aug 28 2024 06:57:14.291 [Info] - Unable to read app config file from C:\Program Files (x86)\Steam\config\appconfig.json. No applications will be available
Wed Aug 28 2024 06:57:14.294 [Info] - [Remapping] Loading automap templates.
Wed Aug 28 2024 06:57:14.297 [Info] - [Controller Setup] Adding controller type vive
Wed Aug 28 2024 06:57:14.297 [Info] - [Controller Setup] Adding controller type rift
Wed Aug 28 2024 06:57:14.298 [Info] - [Controller Setup] Adding controller type indexhmd
Wed Aug 28 2024 06:57:14.298 [Warning] - [Controller Setup] CreateHMDControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_hmd_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:14.299 [Info] - [Remapping] Setting up device remapping for controller type: vive_controller.
Wed Aug 28 2024 06:57:14.299 [Info] - [Controller Setup] Adding controller type vive_controller
Wed Aug 28 2024 06:57:14.300 [Info] - [Remapping] Setting up device remapping for controller type: oculus_touch.
Wed Aug 28 2024 06:57:14.301 [Info] - [Controller Setup] Adding controller type oculus_touch
Wed Aug 28 2024 06:57:14.302 [Info] - [Remapping] Setting up device remapping for controller type: knuckles.
Wed Aug 28 2024 06:57:14.303 [Info] - [Controller Setup] Adding controller type knuckles
Wed Aug 28 2024 06:57:14.303 [Warning] - [Controller Setup] CreateControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_controller_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:14.303 [Warning] - [Controller Setup] CreateControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_hpcontroller_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:14.303 [Info] - [Controller Setup] Adding controller type khr_simple_controller
Wed Aug 28 2024 06:57:14.304 [Info] - [Controller Setup] Adding controller type gamepad
Wed Aug 28 2024 06:57:14.306 [Info] - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:14.306 [Info] - Add Json firmware manifest from {indexcontroller}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:14.306 [Info] - Add Json firmware manifest from {indexhmd}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:14.307 [Info] - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:14.307 [Info] - Add Json firmware manifest from {tundra_labs}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:14.308 [Info] - Web language is english
Wed Aug 28 2024 06:57:14.308 [Info] - [Web] Starting web server on port 27062
Wed Aug 28 2024 06:57:14.312 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black-italic.ttf.
Wed Aug 28 2024 06:57:14.318 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black-italic.ttf.
Wed Aug 28 2024 06:57:14.322 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black.ttf.
Wed Aug 28 2024 06:57:14.327 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-bold-italic.ttf.
Wed Aug 28 2024 06:57:14.332 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-bold.ttf.
Wed Aug 28 2024 06:57:14.336 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-extrabold-italic.ttf.
Wed Aug 28 2024 06:57:14.341 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-extrabold.ttf.
Wed Aug 28 2024 06:57:14.346 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-light-italic.ttf.
Wed Aug 28 2024 06:57:14.350 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-light.ttf.
Wed Aug 28 2024 06:57:14.353 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-medium-italic.ttf.
Wed Aug 28 2024 06:57:14.357 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-medium.ttf.
Wed Aug 28 2024 06:57:14.361 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-regular-italic.ttf.
Wed Aug 28 2024 06:57:14.365 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-regular.ttf.
Wed Aug 28 2024 06:57:14.369 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-thin-italic.ttf.
Wed Aug 28 2024 06:57:14.373 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-thin.ttf.
Wed Aug 28 2024 06:57:14.377 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans.ttf.
Wed Aug 28 2024 06:57:14.381 [Info] - Connecting client (VR_ServerPipe_4828) app container status: 1
Wed Aug 28 2024 06:57:14.384 [Info] - New Connect message from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win32\vrstartup.exe (VRApplication_Bootstrapper) (Args: ) 408
Wed Aug 28 2024 06:57:14.386 [Info] - Creating Builtin AppInfo for C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win32\vrstartup.exe (VRApplication_Bootstrapper). steam.overlay.250820, , 408
Wed Aug 28 2024 06:57:14.386 [Info] - AppInfoManager.ProcessConnected BEGIN 408 C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win32\vrstartup.exe 7 steam.overlay.250820
Wed Aug 28 2024 06:57:14.388 [Info] - SetApplicationPid appkey=steam.overlay.250820 pid=408, external transition
Wed Aug 28 2024 06:57:14.388 [Info] - SetApplicationPid: Setting app steam.overlay.250820 PID to 408
Wed Aug 28 2024 06:57:14.388 [Info] - AppInfoManager.ProcessConnected END
Wed Aug 28 2024 06:57:14.388 [Info] - [Input] Enabling legacy input for steam.overlay.250820
Wed Aug 28 2024 06:57:14.398 [Info] - vrlink: SVLDriver::Init()
Wed Aug 28 2024 06:57:14.398 [Info] - driver vrlink implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:14.398 [Info] - Loaded server driver vrlink (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\bin\win64\driver_vrlink.dll
Wed Aug 28 2024 06:57:14.398 [Warning] - Driver vrlink has no suitable devices.
Wed Aug 28 2024 06:57:14.405 [Info] - Unable to load driver CloudXRRemoteHMD from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\bin\win64\driver_CloudXRRemoteHMD.dll (127)
Wed Aug 28 2024 06:57:14.405 [Error] - ASSERT: “DriverManager CloudXRRemoteHMD load error 127u” at c:\buildslave\steamvr_rel_win64\build\src\common\vrcommon\drivermanager.cpp:439.
Wed Aug 28 2024 06:57:14.408 [Info] - vrlink: SVLRoot::SVLRoot() Parsing Data
Wed Aug 28 2024 06:57:14.408 [Info] - vrlink: SVLRoot::SVLRoot() sReqEncMode = mid
Wed Aug 28 2024 06:57:14.408 [Info] - vrlink: SVLRoot::SVLRoot() Parsing Arg (0)
Wed Aug 28 2024 06:57:14.408 [Info] - vrlink: SVLRoot::SVLRoot() Arg Parsed
Wed Aug 28 2024 06:57:14.422 [Info] - vrlink: Soft AES PERF: 7.059654 MByte/s
Wed Aug 28 2024 06:57:14.423 [Info] - vrlink: Intel IPSEC AES PERF: 253.164551 MByte/s
Wed Aug 28 2024 06:57:14.426 [Info] - vrlink: OpenSSL AES PERF: 41.322315 MByte/s
Wed Aug 28 2024 06:57:14.440 [Info] - vrlink: Soft AES PERF: 7.319572 MByte/s
Wed Aug 28 2024 06:57:14.441 [Info] - vrlink: Intel IPSEC AES PERF: 221.729492 MByte/s
Wed Aug 28 2024 06:57:14.442 [Info] - vrlink: OpenSSL AES PERF: 72.568939 MByte/s
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: UDP Driver
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: Active Data Links: m_pLink:0000020D5C6F4FA0 pTcpLink:0000000000000000 pUdpLink:0000020D5C6F4FA0 p8814Link:0000000000000000
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: SVLDataLink::HandleFECChange( 32 )
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: SVLServer::SVLServer(…)
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: SVLAudioWSAPI::SVLAudioWSAPI(…)
Wed Aug 28 2024 06:57:14.446 [Info] - vrlink: SVLHMDDriverD3D11::SVLHMDDriverD3D11() C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources
Wed Aug 28 2024 06:57:14.447 [Info] - vrlink: SVLCryptWindows CryptAcquireContext succeeded for generation.
Wed Aug 28 2024 06:57:14.447 [Info] - vrlink: SVLDataLink::InitCrypt(…,55,1)
Wed Aug 28 2024 06:57:14.447 [Info] - vrlink: SVLDataLink::InitCrypt() m_TransportMode = 1 // 1017
Wed Aug 28 2024 06:57:14.447 [Info] - vrlink: Starting session with ID: 0166c016
Wed Aug 28 2024 06:57:14.447 [Info] - vrlink: SVLDataLinkUDP::Disconnect()
Wed Aug 28 2024 06:57:14.449 [Info] - vrlink: SVLDataLinkUDP: Found available QOS service! (Socket creation = 1700)
Wed Aug 28 2024 06:57:14.449 [Info] - vrlink: Socket bound to port 10400
Wed Aug 28 2024 06:57:14.449 [Info] - vrlink: SVLDataLinkUDP: WSAIoctl failed with 10022
Wed Aug 28 2024 06:57:14.449 [Info] - vrlink: SVLDataLinkUDP::Reconnect() Joining Thread 0000000000000000
Wed Aug 28 2024 06:57:14.450 [Info] - vrlink: Set thread FFFFFFFFFFFFFFFE priority to: 15
Wed Aug 28 2024 06:57:14.450 [Info] - vrlink: SVLDataLinkUDP::Reconnect() Thread Create Complete
Wed Aug 28 2024 06:57:14.450 [Info] - vrlink: Data Link Startup with Options: nTimedRetryOption = 1, nQoSOption = 0
Wed Aug 28 2024 06:57:14.450 [Info] - vrlink: Listening for incoming control connections on 10440 via socket 1708
Wed Aug 28 2024 06:57:14.623 [Info] - vrlink: SVLDriver::Init() Complete
Wed Aug 28 2024 06:57:15.023 [Error] - Unable to load driver CloudXRRemoteHMD because of error VRInitError_Init_FileNotFound(103). Skipping.
Wed Aug 28 2024 06:57:15.036 [Info] - lighthouse: version 2.7.4
Wed Aug 28 2024 06:57:15.036 [Info] - lighthouse: [DepthAugmentedPassthrough] supported on this system: 1
Wed Aug 28 2024 06:57:15.036 [Info] - lighthouse: [DepthAugmentedPassthrough] : Object is created
Wed Aug 28 2024 06:57:15.037 [Info] - lighthouse: Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:15.037 [Info] - lighthouse: Add Json firmware manifest from {indexcontroller}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:15.037 [Info] - lighthouse: Add Json firmware manifest from {indexhmd}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:15.038 [Info] - lighthouse: Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:15.038 [Info] - lighthouse: Add Json firmware manifest from {tundra_labs}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:15.039 [Info] - lighthouse: Attached HID Devices:
Wed Aug 28 2024 06:57:15.039 [Info] - lighthouse: No devices
Wed Aug 28 2024 06:57:15.039 [Info] - driver lighthouse implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:15.039 [Info] - Loaded server driver lighthouse (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\bin\win64\driver_lighthouse.dll
Wed Aug 28 2024 06:57:15.039 [Warning] - Driver lighthouse has no suitable devices.
Wed Aug 28 2024 06:57:15.040 [Info] - oculus: version 2.7.4
Wed Aug 28 2024 06:57:15.041 [Info] - driver oculus implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:15.041 [Info] - Loaded server driver oculus (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus\bin\win64\driver_oculus.dll
Wed Aug 28 2024 06:57:15.041 [Warning] - Driver oculus has no suitable devices.
Wed Aug 28 2024 06:57:15.042 [Info] - driver oculus_legacy implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:15.042 [Info] - Loaded server driver oculus_legacy (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus_legacy\bin\win64\driver_oculus_legacy.dll
Wed Aug 28 2024 06:57:15.042 [Warning] - Driver oculus_legacy has no suitable devices.
Wed Aug 28 2024 06:57:15.044 [Info] - driver gamepad implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:15.044 [Info] - Loaded server driver gamepad (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\gamepad\bin\win64\driver_gamepad.dll
Wed Aug 28 2024 06:57:15.044 [Warning] - Driver gamepad has no suitable devices.
Wed Aug 28 2024 06:57:15.044 [Warning] - Not loading driver null because it is disabled in settings
Wed Aug 28 2024 06:57:15.044 [Info] - No connected devices found. Returning best error VRInitError_Init_HmdNotFound
Wed Aug 28 2024 06:57:15.044 [Info] - [Remapping] Setting up device remapping for controller type: knuckles.
Wed Aug 28 2024 06:57:15.045 [Info] - [Remapping] Parsing remapping data succeeded for controller type: knuckles.
Wed Aug 28 2024 06:57:15.045 [Info] - [Remapping] Setting up device remapping for controller type: oculus_touch.
Wed Aug 28 2024 06:57:15.047 [Info] - [Remapping] Parsing remapping data succeeded for controller type: oculus_touch.
Wed Aug 28 2024 06:57:15.047 [Info] - [Remapping] Setting up device remapping for controller type: vive_controller.
Wed Aug 28 2024 06:57:15.048 [Info] - [Remapping] Parsing remapping data succeeded for controller type: vive_controller.
Wed Aug 28 2024 06:57:15.048 [Info] - Refusing connect from 408: vrstartup because VRInitError_Init_HmdNotFound
Wed Aug 28 2024 06:57:15.048 [Info] - Processing message VRMsg_Connect from 408: vrstartup took 0.665 seconds
Wed Aug 28 2024 06:57:15.051 [Info] - Closing pipe 408: vrstartup because it was broken from the other end
Wed Aug 28 2024 06:57:15.051 [Info] - Process 408: vrstartup disconnected (Thread(0x0000020D5986DD40/0x000)
Wed Aug 28 2024 06:57:15.051 [Info] - AppInfoManager.ProcessQuit processid=408 eLaunchingApp=LaunchingApp_None
Wed Aug 28 2024 06:57:15.051 [Info] - AppInfoManager.ProcessQuit: Clearing application steam.overlay.250820 PID was 408
Wed Aug 28 2024 06:57:15.051 [Info] - AppInfoManager.ProcessQuit: Clearing application steam.overlay.250820 PID because 408 has exited
Wed Aug 28 2024 06:57:15.077 [Info] - [Steam] Steam INIT.
Wed Aug 28 2024 06:57:15.077 [Info] - [Steam] Steam SHUTDOWN.
Wed Aug 28 2024 06:57:17.058 [Warning] - Shutting down server after 2.7 seconds. Recent Disconnect: false; Waiting for connection statuses: Foreground: 0 Monitor: 0 Web: 0
Wed Aug 28 2024 06:57:17.058 [Info] - VR server shutting down
Wed Aug 28 2024 06:57:17.157 [Info] - Listener thread ending
Wed Aug 28 2024 06:57:17.157 [Info] - [Web] Shutting down web server.
Wed Aug 28 2024 06:57:18.046 [Info] - lighthouse: [DepthAugmentedPassthrough] : Object is destroyed
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLServer::Shutdown()
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLRoot::Shutdown() start
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLRoot::Shutdown() m_thdEventsThread complete
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLRoot::Shutdown() m_pAudio->Stop() done
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLRoot::Shutdown() m_pLink->PrepareForPossibleShutdown()
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLDataLinkUDP::Shutdown(); m_nQuit = 0
Wed Aug 28 2024 06:57:18.099 [Info] - vrlink: SVLDataLinkUDP::Disconnect()
Wed Aug 28 2024 06:57:18.100 [Info] - vrlink: SVLDataLinkUDP::RXThread() Cleaned up
Wed Aug 28 2024 06:57:18.100 [Info] - vrlink: SVLDataLinkUDP::Shutdown(); Disconnect() complete
Wed Aug 28 2024 06:57:18.100 [Info] - vrlink: SVLDataLinkUDP::Shutdown(); Thread Join Complete.
Wed Aug 28 2024 06:57:18.100 [Info] - vrlink: SVLRoot::Shutdown() complete
Wed Aug 28 2024 06:57:18.153 [Info] - Cleaning up audio defaults
Wed Aug 28 2024 06:57:18.153 [Info] - Error: failed to remove audio mirror device
Wed Aug 28 2024 06:57:18.154 [Info] - Skipping audio playback console endpoint because it was not changed by SteamVR ()
Wed Aug 28 2024 06:57:18.154 [Info] - Skipping audio recording console endpoint because it was not changed by SteamVR ()
Wed Aug 28 2024 06:57:18.154 [Info] - Skipping audio playback communications endpoint because it was not changed by SteamVR ()
Wed Aug 28 2024 06:57:18.154 [Info] - Skipping audio recording communications endpoint because it was not changed by SteamVR ()
Wed Aug 28 2024 06:57:18.154 [Info] - Finished cleaning up audio defaults
Wed Aug 28 2024 06:57:18.158 [Info] - CSharedResourceNamespaceServer shutting down
Wed Aug 28 2024 06:57:18.160 [Info] - [vrserver] Graceful exit
Wed Aug 28 2024 06:57:18.569 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:18.569 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:18.569 [Info] - vrserver.exe 2.7.4 startup with PID=5172, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:18.569 [Info] - [vrserver] watchdogs enabled
Wed Aug 28 2024 06:57:18.571 [Info] - CSharedResourceNamespaceServer starting up
Wed Aug 28 2024 06:57:18.571 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:18.571 [Error] - CSharedResourceNamespaceClient::Init(): failed connect
Wed Aug 28 2024 06:57:18.571 [Warning] - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Wed Aug 28 2024 06:57:18.571 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: 1
Wed Aug 28 2024 06:57:18.572 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: -15
Wed Aug 28 2024 06:57:18.605 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:18.605 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:18.672 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:18.682 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:18.682 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:18.682 [Info] - Closing pipe SteamVR_Namespace because it was broken from the other end
Wed Aug 28 2024 06:57:18.682 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:18.682 [Info] - Self queried namespace: 5172
Wed Aug 28 2024 06:57:18.682 [Info] - [Init] VR server 2.7.4 (v1721847232) starting up with config=C:\Program Files (x86)\Steam\config
Wed Aug 28 2024 06:57:18.682 [Info] - [Init] VRServer will wait for VRMonitor before exiting
Wed Aug 28 2024 06:57:18.686 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.686 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.687 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.687 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.687 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.687 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.688 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:18.693 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.693 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.693 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.693 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.693 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.694 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.694 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:18.700 [Info] - [Display] Enabling direct mode for NVIDIA [Vid=0xD94D Pid=0xC207]…
Wed Aug 28 2024 06:57:18.700 [Error] - [Display] Failed to set display visibility.
Wed Aug 28 2024 06:57:18.701 [Info] - Unable to read app config file from C:\Program Files (x86)\Steam\config\appconfig.json. No applications will be available
Wed Aug 28 2024 06:57:18.703 [Info] - [Remapping] Loading automap templates.
Wed Aug 28 2024 06:57:18.705 [Info] - [Controller Setup] Adding controller type vive
Wed Aug 28 2024 06:57:18.705 [Info] - [Controller Setup] Adding controller type rift
Wed Aug 28 2024 06:57:18.706 [Info] - [Controller Setup] Adding controller type indexhmd
Wed Aug 28 2024 06:57:18.706 [Warning] - [Controller Setup] CreateHMDControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_hmd_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:18.706 [Info] - [Remapping] Setting up device remapping for controller type: vive_controller.
Wed Aug 28 2024 06:57:18.707 [Info] - [Controller Setup] Adding controller type vive_controller
Wed Aug 28 2024 06:57:18.707 [Info] - [Remapping] Setting up device remapping for controller type: oculus_touch.
Wed Aug 28 2024 06:57:18.708 [Info] - [Controller Setup] Adding controller type oculus_touch
Wed Aug 28 2024 06:57:18.709 [Info] - [Remapping] Setting up device remapping for controller type: knuckles.
Wed Aug 28 2024 06:57:18.709 [Info] - [Controller Setup] Adding controller type knuckles
Wed Aug 28 2024 06:57:18.709 [Warning] - [Controller Setup] CreateControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_controller_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:18.709 [Warning] - [Controller Setup] CreateControllerTypeFromPathIfDriverPresent failed. Not creating controller type ‘{holographic}/input/mixedreality_hpcontroller_profile.json’ because driver ‘holographic’ isn’t present.
Wed Aug 28 2024 06:57:18.710 [Info] - [Controller Setup] Adding controller type khr_simple_controller
Wed Aug 28 2024 06:57:18.710 [Info] - [Controller Setup] Adding controller type gamepad
Wed Aug 28 2024 06:57:18.711 [Info] - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:18.712 [Info] - Add Json firmware manifest from {indexcontroller}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:18.712 [Info] - Add Json firmware manifest from {indexhmd}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:18.712 [Info] - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:18.712 [Info] - Add Json firmware manifest from {tundra_labs}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:18.712 [Info] - Web language is english
Wed Aug 28 2024 06:57:18.713 [Info] - [Web] Starting web server on port 27062
Wed Aug 28 2024 06:57:18.715 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black-italic.ttf.
Wed Aug 28 2024 06:57:18.720 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black-italic.ttf.
Wed Aug 28 2024 06:57:18.724 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-black.ttf.
Wed Aug 28 2024 06:57:18.728 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-bold-italic.ttf.
Wed Aug 28 2024 06:57:18.732 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-bold.ttf.
Wed Aug 28 2024 06:57:18.736 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-extrabold-italic.ttf.
Wed Aug 28 2024 06:57:18.740 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-extrabold.ttf.
Wed Aug 28 2024 06:57:18.744 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-light-italic.ttf.
Wed Aug 28 2024 06:57:18.747 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-light.ttf.
Wed Aug 28 2024 06:57:18.750 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-medium-italic.ttf.
Wed Aug 28 2024 06:57:18.754 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-medium.ttf.
Wed Aug 28 2024 06:57:18.757 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-regular-italic.ttf.
Wed Aug 28 2024 06:57:18.761 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-regular.ttf.
Wed Aug 28 2024 06:57:18.764 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-thin-italic.ttf.
Wed Aug 28 2024 06:57:18.767 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans-thin.ttf.
Wed Aug 28 2024 06:57:18.770 [Info] - Caching webfont C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\webinterface\fonts\motiva-sans.ttf.
Wed Aug 28 2024 06:57:18.773 [Info] - Connecting client (VR_ServerPipe_5172) app container status: 1
Wed Aug 28 2024 06:57:18.774 [Info] - New Connect message from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe (VRApplication_VRMonitor) (Args: -nokillprocess -startupappid 250820 -startupreason steamvr_vrstartup -startupapptype 7) 4148
Wed Aug 28 2024 06:57:18.776 [Info] - Creating Builtin AppInfo for C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe (VRApplication_VRMonitor). steam.overlay.250820, , 4148
Wed Aug 28 2024 06:57:18.776 [Info] - AppInfoManager.ProcessConnected BEGIN 4148 C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe 5 steam.overlay.250820
Wed Aug 28 2024 06:57:18.778 [Info] - SetApplicationPid appkey=steam.overlay.250820 pid=4148, external transition
Wed Aug 28 2024 06:57:18.778 [Info] - SetApplicationPid: Setting app steam.overlay.250820 PID to 4148
Wed Aug 28 2024 06:57:18.778 [Info] - AppInfoManager.ProcessConnected END
Wed Aug 28 2024 06:57:18.778 [Info] - [Input] Enabling legacy input for steam.overlay.250820
Wed Aug 28 2024 06:57:18.792 [Info] - vrlink: SVLDriver::Init()
Wed Aug 28 2024 06:57:18.793 [Info] - driver vrlink implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:18.793 [Info] - Loaded server driver vrlink (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\bin\win64\driver_vrlink.dll
Wed Aug 28 2024 06:57:18.793 [Warning] - Driver vrlink has no suitable devices.
Wed Aug 28 2024 06:57:18.795 [Info] - Unable to load driver CloudXRRemoteHMD from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\bin\win64\driver_CloudXRRemoteHMD.dll (127)
Wed Aug 28 2024 06:57:18.795 [Error] - ASSERT: “DriverManager CloudXRRemoteHMD load error 127u” at c:\buildslave\steamvr_rel_win64\build\src\common\vrcommon\drivermanager.cpp:439.
Wed Aug 28 2024 06:57:18.798 [Info] - vrlink: SVLRoot::SVLRoot() Parsing Data
Wed Aug 28 2024 06:57:18.798 [Info] - vrlink: SVLRoot::SVLRoot() sReqEncMode = mid
Wed Aug 28 2024 06:57:18.798 [Info] - vrlink: SVLRoot::SVLRoot() Parsing Arg (0)
Wed Aug 28 2024 06:57:18.798 [Info] - vrlink: SVLRoot::SVLRoot() Arg Parsed
Wed Aug 28 2024 06:57:18.808 [Info] - vrlink: Soft AES PERF: 10.391769 MByte/s
Wed Aug 28 2024 06:57:18.808 [Info] - vrlink: Intel IPSEC AES PERF: 395.256927 MByte/s
Wed Aug 28 2024 06:57:18.809 [Info] - vrlink: OpenSSL AES PERF: 95.693779 MByte/s
Wed Aug 28 2024 06:57:18.819 [Info] - vrlink: Soft AES PERF: 11.072971 MByte/s
Wed Aug 28 2024 06:57:18.819 [Info] - vrlink: Intel IPSEC AES PERF: 383.141754 MByte/s
Wed Aug 28 2024 06:57:18.820 [Info] - vrlink: OpenSSL AES PERF: 99.502487 MByte/s
Wed Aug 28 2024 06:57:18.822 [Info] - vrlink: UDP Driver
Wed Aug 28 2024 06:57:18.823 [Info] - vrlink: Active Data Links: m_pLink:00000214584505D0 pTcpLink:0000000000000000 pUdpLink:00000214584505D0 p8814Link:0000000000000000
Wed Aug 28 2024 06:57:18.823 [Info] - vrlink: SVLDataLink::HandleFECChange( 32 )
Wed Aug 28 2024 06:57:18.823 [Info] - vrlink: SVLServer::SVLServer(…)
Wed Aug 28 2024 06:57:18.823 [Info] - vrlink: SVLAudioWSAPI::SVLAudioWSAPI(…)
Wed Aug 28 2024 06:57:18.823 [Info] - vrlink: SVLHMDDriverD3D11::SVLHMDDriverD3D11() C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources
Wed Aug 28 2024 06:57:18.824 [Info] - vrlink: SVLCryptWindows CryptAcquireContext succeeded for generation.
Wed Aug 28 2024 06:57:18.824 [Info] - vrlink: SVLDataLink::InitCrypt(…,55,1)
Wed Aug 28 2024 06:57:18.824 [Info] - vrlink: SVLDataLink::InitCrypt() m_TransportMode = 1 // 1017
Wed Aug 28 2024 06:57:18.824 [Info] - vrlink: Starting session with ID: 01b58bd8
Wed Aug 28 2024 06:57:18.824 [Info] - vrlink: SVLDataLinkUDP::Disconnect()
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: SVLDataLinkUDP: Found available QOS service! (Socket creation = 1708)
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: Socket bound to port 10400
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: SVLDataLinkUDP: WSAIoctl failed with 10022
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: SVLDataLinkUDP::Reconnect() Joining Thread 0000000000000000
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: SVLDataLinkUDP::Reconnect() Thread Create Complete
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: Set thread FFFFFFFFFFFFFFFE priority to: 15
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: Data Link Startup with Options: nTimedRetryOption = 1, nQoSOption = 0
Wed Aug 28 2024 06:57:18.826 [Info] - vrlink: Listening for incoming control connections on 10440 via socket 1716
Wed Aug 28 2024 06:57:18.864 [Info] - vrlink: SVLDriver::Init() Complete
Wed Aug 28 2024 06:57:19.035 [Error] - Unable to load driver CloudXRRemoteHMD because of error VRInitError_Init_FileNotFound(103). Skipping.
Wed Aug 28 2024 06:57:19.048 [Info] - lighthouse: version 2.7.4
Wed Aug 28 2024 06:57:19.048 [Info] - lighthouse: [DepthAugmentedPassthrough] supported on this system: 1
Wed Aug 28 2024 06:57:19.048 [Info] - lighthouse: [DepthAugmentedPassthrough] : Object is created
Wed Aug 28 2024 06:57:19.049 [Info] - lighthouse: Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:19.049 [Info] - lighthouse: Add Json firmware manifest from {indexcontroller}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:19.049 [Info] - lighthouse: Add Json firmware manifest from {indexhmd}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:19.049 [Info] - lighthouse: Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:19.050 [Info] - lighthouse: Add Json firmware manifest from {tundra_labs}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:19.050 [Info] - lighthouse: Attached HID Devices:
Wed Aug 28 2024 06:57:19.050 [Info] - lighthouse: No devices
Wed Aug 28 2024 06:57:19.050 [Info] - driver lighthouse implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:19.050 [Info] - Loaded server driver lighthouse (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\bin\win64\driver_lighthouse.dll
Wed Aug 28 2024 06:57:19.050 [Warning] - Driver lighthouse has no suitable devices.
Wed Aug 28 2024 06:57:19.052 [Info] - oculus: version 2.7.4
Wed Aug 28 2024 06:57:19.052 [Info] - driver oculus implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:19.052 [Info] - Loaded server driver oculus (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus\bin\win64\driver_oculus.dll
Wed Aug 28 2024 06:57:19.052 [Warning] - Driver oculus has no suitable devices.
Wed Aug 28 2024 06:57:19.053 [Info] - driver oculus_legacy implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:19.053 [Info] - Loaded server driver oculus_legacy (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus_legacy\bin\win64\driver_oculus_legacy.dll
Wed Aug 28 2024 06:57:19.053 [Warning] - Driver oculus_legacy has no suitable devices.
Wed Aug 28 2024 06:57:19.054 [Info] - driver gamepad implements interfaces IVRSettings_003 ITrackedDeviceServerDriver_005 IVRDisplayComponent_003 IVRDriverDirectModeComponent_009 IVRCameraComponent_003 IServerTrackedDeviceProvider_004 IVRWatchdogProvider_001 IVRVirtualDisplay_002 IVRDriverManager_001 IVRResources_001 IVRCompositorPluginProvider_001 IVRIPCResourceManagerClient_001
Wed Aug 28 2024 06:57:19.054 [Info] - Loaded server driver gamepad (IServerTrackedDeviceProvider_004) from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\gamepad\bin\win64\driver_gamepad.dll
Wed Aug 28 2024 06:57:19.054 [Warning] - Driver gamepad has no suitable devices.
Wed Aug 28 2024 06:57:19.054 [Warning] - Not loading driver null because it is disabled in settings
Wed Aug 28 2024 06:57:19.054 [Info] - No connected devices found. Returning best error VRInitError_Init_HmdNotFound
Wed Aug 28 2024 06:57:19.054 [Info] - [Remapping] Setting up device remapping for controller type: knuckles.
Wed Aug 28 2024 06:57:19.055 [Info] - [Remapping] Parsing remapping data succeeded for controller type: knuckles.
Wed Aug 28 2024 06:57:19.055 [Info] - [Remapping] Setting up device remapping for controller type: oculus_touch.
Wed Aug 28 2024 06:57:19.056 [Info] - [Remapping] Parsing remapping data succeeded for controller type: oculus_touch.
Wed Aug 28 2024 06:57:19.056 [Info] - [Remapping] Setting up device remapping for controller type: vive_controller.
Wed Aug 28 2024 06:57:19.057 [Info] - [Remapping] Parsing remapping data succeeded for controller type: vive_controller.
Wed Aug 28 2024 06:57:19.057 [Info] - Allowing driver load failure VRInitError_Init_HmdNotFound for application 4148: vrmonitor because it is VRApplication_VRMonitor
Wed Aug 28 2024 06:57:19.057 [Info] - Processing message VRMsg_Connect from 4148: vrmonitor took 0.284 seconds
Wed Aug 28 2024 06:57:19.285 [Info] - [Steam] Steam INIT.
Wed Aug 28 2024 06:57:19.286 [Info] - [Steam] Steam API available
Wed Aug 28 2024 06:57:19.286 [Info] - [Steam] Steam user logged in
Wed Aug 28 2024 06:57:21.202 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:21.202 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:21.268 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:21.268 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:21.279 [Info] - Connecting client (VR_ServerPipe_5172) app container status: 1
Wed Aug 28 2024 06:57:21.279 [Info] - New Connect message from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe (VRApplication_WebHelper) (Args: -lang=en_us) 4752
Wed Aug 28 2024 06:57:21.281 [Info] - AppInfoManager.ProcessConnected BEGIN 4752 C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe 8 steam.overlay.250820
Wed Aug 28 2024 06:57:21.283 [Info] - SetApplicationPid appkey=steam.overlay.250820 pid=4752, external transition
Wed Aug 28 2024 06:57:21.283 [Info] - SetApplicationPid: Setting app steam.overlay.250820 PID to 4752
Wed Aug 28 2024 06:57:21.283 [Info] - AppInfoManager.ProcessConnected END
Wed Aug 28 2024 06:57:21.283 [Info] - [Input] Enabling legacy input for steam.overlay.250820
Wed Aug 28 2024 06:57:21.284 [Info] - Allowing driver load failure VRInitError_Init_HmdNotFound for application 4752: vrwebhelper_main because it is VRApplication_WebHelper
Wed Aug 28 2024 06:57:23.446 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:23.446 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:23.848 [Info] - [Settings] Save Json Settings to C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:24.594 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/settings_desktop.html
Wed Aug 28 2024 06:57:24.595 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/pairing.html
Wed Aug 28 2024 06:57:24.606 [Info] - [Web] HTTP_REQUEST /fonts/get_font
Wed Aug 28 2024 06:57:24.608 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css/fonts/motiva_sans.css
Wed Aug 28 2024 06:57:24.609 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css/vrsettings.css
Wed Aug 28 2024 06:57:24.609 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css/base.css
Wed Aug 28 2024 06:57:24.609 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css/fonts/motiva_sans.css
Wed Aug 28 2024 06:57:24.610 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/css/pairing.css
Wed Aug 28 2024 06:57:24.612 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:24.612 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:24.615 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css%5Cvrwebui_shared.css
Wed Aug 28 2024 06:57:24.615 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/libraries.js
Wed Aug 28 2024 06:57:24.616 [Info] - [Web] HTTP_REQUEST /fonts/get_font
Wed Aug 28 2024 06:57:24.616 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/vrwebui_shared.js
Wed Aug 28 2024 06:57:24.620 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/libraries.js
Wed Aug 28 2024 06:57:24.621 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/vrwebui_shared.js
Wed Aug 28 2024 06:57:24.645 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:24.645 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:24.656 [Info] - Connecting client (VR_ServerPipe_5172) app container status: 1
Wed Aug 28 2024 06:57:24.656 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Wed Aug 28 2024 06:57:24.656 [Info] - CSharedResourceNamespaceServer sent namespace data: 5172
Wed Aug 28 2024 06:57:24.656 [Info] - New Connect message from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe (VRApplication_WebHelper) (Args: --type=renderer --no-sandbox --autoplay-policy=no-user-gesture-required --enable-experimental-web-platform-features --field-trial-handle=1480,9010068414625382984,18109898835447656131,131072 --service-pipe-token=8020247664615761926 --enable-blink-features=ResizeObserver --lang=en-US --log-file=C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\debug.log --log-severity=disable --product-version=SteamVR HTML --disable-spell-checking --device-scale-factor=1 --num-raster-threads=2 --enable-main-frame-before-activation --service-request-channel-token=8020247664615761926 --renderer-client-id=3 --mojo-platform-channel-handle=1932 /prefetch:1) 4288
Wed Aug 28 2024 06:57:24.658 [Info] - AppInfoManager.ProcessConnected BEGIN 4288 C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe 8 steam.overlay.250820
Wed Aug 28 2024 06:57:24.660 [Info] - SetApplicationPid appkey=steam.overlay.250820 pid=4288, external transition
Wed Aug 28 2024 06:57:24.660 [Info] - SetApplicationPid: Setting app steam.overlay.250820 PID to 4288
Wed Aug 28 2024 06:57:24.660 [Info] - AppInfoManager.ProcessConnected END
Wed Aug 28 2024 06:57:24.660 [Info] - [Input] Enabling legacy input for steam.overlay.250820
Wed Aug 28 2024 06:57:24.661 [Info] - Allowing driver load failure VRInitError_Init_HmdNotFound for application 4288: vrwebhelper_pairing because it is VRApplication_WebHelper
Wed Aug 28 2024 06:57:24.661 [Info] - New Connect message from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe (VRApplication_WebHelper) (Args: --type=renderer --no-sandbox --autoplay-policy=no-user-gesture-required --enable-experimental-web-platform-features --field-trial-handle=1480,9010068414625382984,18109898835447656131,131072 --service-pipe-token=11878623749364392309 --enable-blink-features=ResizeObserver --lang=en-US --log-file=C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\debug.log --log-severity=disable --product-version=SteamVR HTML --disable-spell-checking --device-scale-factor=1 --num-raster-threads=2 --enable-main-frame-before-activation --service-request-channel-token=11878623749364392309 --renderer-client-id=4 --mojo-platform-channel-handle=2040 /prefetch:1) 5968
Wed Aug 28 2024 06:57:24.662 [Info] - AppInfoManager.ProcessConnected BEGIN 5968 C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe 8 steam.overlay.250820
Wed Aug 28 2024 06:57:24.664 [Info] - SetApplicationPid appkey=steam.overlay.250820 pid=5968, external transition
Wed Aug 28 2024 06:57:24.664 [Info] - SetApplicationPid: Setting app steam.overlay.250820 PID to 5968
Wed Aug 28 2024 06:57:24.664 [Info] - AppInfoManager.ProcessConnected END
Wed Aug 28 2024 06:57:24.665 [Info] - [Input] Enabling legacy input for steam.overlay.250820
Wed Aug 28 2024 06:57:24.665 [Info] - Allowing driver load failure VRInitError_Init_HmdNotFound for application 5968: vrwebhelper_settings_desktop because it is VRApplication_WebHelper
Wed Aug 28 2024 06:57:24.665 [Info] - Processing message VRMsg_Connect from 5968: vrwebhelper_settings_desktop took 0.00855 seconds
Wed Aug 28 2024 06:57:24.673 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/pairing.js
Wed Aug 28 2024 06:57:24.679 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/images/pairingui/background.png
Wed Aug 28 2024 06:57:24.725 [Info] - [Web] HTTP_REQUEST Static Content /lighthouse/webinterface/localization/lighthouse_web_english.json
Wed Aug 28 2024 06:57:24.727 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/localization/webhelper_english.json
Wed Aug 28 2024 06:57:24.728 [Info] - [Web] HTTP_REQUEST /input/localization.json
Wed Aug 28 2024 06:57:24.739 [Info] - [Web] WebSocket Handshake Request
Host: 127.0.0.1:27062
Connection: Upgrade
Pragma: no-cache
Cache-Control: no-cache
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) SteamVR HTML Safari/537.36
Upgrade: websocket
Origin: http://127.0.0.1:27062
Sec-WebSocket-Version: 13
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9
Sec-WebSocket-Key: xu2uuc9Uewh/l1oYa8M+TQ==
Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
Wed Aug 28 2024 06:57:24.739 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:24.789 [Info] - [Web] HTTP_REQUEST /fonts/get_font
Wed Aug 28 2024 06:57:26.815 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/css%5Cvrwebui_shared.css
Wed Aug 28 2024 06:57:26.815 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/settings_desktop.js
Wed Aug 28 2024 06:57:26.927 [Info] - [Web] HTTP_REQUEST /drivers/list.json
Wed Aug 28 2024 06:57:26.935 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/localization/vrmonitor_english.json
Wed Aug 28 2024 06:57:26.936 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/localization/bindingui_english.json
Wed Aug 28 2024 06:57:26.938 [Info] - [Web] HTTP_REQUEST Static Content /dashboard/localization/webhelper_english.json
Wed Aug 28 2024 06:57:26.939 [Info] - [Web] HTTP_REQUEST /input/localization.json
Wed Aug 28 2024 06:57:26.941 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: GKqKar1tJ0+PDxAVRur4zg==
Wed Aug 28 2024 06:57:26.941 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:26.946 [Info] - [Web] HTTP_REQUEST /input/getstate.json
Wed Aug 28 2024 06:57:26.950 [Info] - [Web] HTTP_REQUEST /app/list.json
Wed Aug 28 2024 06:57:26.952 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: lUgiU0V5R7M5qrQH01NYgQ==
Wed Aug 28 2024 06:57:26.952 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:26.963 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: 2YwnGHSeT4zwYCS56J/FbQ==
Wed Aug 28 2024 06:57:26.963 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:26.974 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: anDfqgWtaDlcBNmw3FINPw==
Wed Aug 28 2024 06:57:26.974 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:26.984 [Info] - [Web] HTTP_REQUEST /settings_getinfo
Wed Aug 28 2024 06:57:26.985 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: UfgdhLSkv63lKhT3ImBT1Q==
Wed Aug 28 2024 06:57:26.985 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 06:57:26.985 [Info] - [Web] HTTP_REQUEST /app/list.json
Wed Aug 28 2024 06:57:26.987 [Info] - [Web] HTTP_REQUEST /input/getstate.json
Wed Aug 28 2024 06:57:27.016 [Info] - [Web] HTTP_REQUEST /input/getstate.json
Wed Aug 28 2024 06:57:27.045 [Info] - [Web] WebSocket Handshake Request
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-WebSocket-Key: w6Y/8R8+R0By2a2REE7OGA==
Wed Aug 28 2024 06:57:27.045 [Info] - [Web] WebSocket Handshake Done
Wed Aug 28 2024 07:00:13.865 [Info] - lighthouse: Triggered by system report: USB status (rates over 10 sec)
Wed Aug 28 2024 07:00:17.882 [Info] - Processing message VRMsg_WritePropertyDataToFile from 4148: vrmonitor took 0.0154 seconds
— vrserver.txt - C:/Program Files (x86)/Steam/logs
=== vrmonitor.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:18.288 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:18.288 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:18.289 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:18.289 [Info] - vrmonitor.exe 2.7.4 startup with PID=4148, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:18.290 [Info] - Tools Path: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\tools exists.
Wed Aug 28 2024 06:57:18.290 [Info] - Demo Path: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\demo not found.
Wed Aug 28 2024 06:57:18.321 [Info] - AUDIO: Refreshing audio devices
Wed Aug 28 2024 06:57:18.321 [Info] - AUDIO: Detected 0 playback and 0 record devices
Wed Aug 28 2024 06:57:18.321 [Info] - Default Playback Audio Devices: , (Comm)
Wed Aug 28 2024 06:57:18.321 [Info] - Default Record Audio Device: , (Comm)
Wed Aug 28 2024 06:57:18.322 [Info] - [System] Prepare operating system environment
Wed Aug 28 2024 06:57:18.322 [Info] - [System] Setting power settings to minimum power savings.
Wed Aug 28 2024 06:57:18.322 [Info] - [System] Found power mode {381B4222-F694-41F0-9685-FF5BB260DF2E} Balanced
Wed Aug 28 2024 06:57:18.322 [Info] - [System] Found power mode {8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C} High performance (current)
Wed Aug 28 2024 06:57:18.323 [Info] - [System] Found power mode {A1841308-3541-4FAB-BC81-F71556F20B4A} Power saver
Wed Aug 28 2024 06:57:18.323 [Info] - [System] Setting High Performance power mode
Wed Aug 28 2024 06:57:18.372 [Info] - [System] Detected first setup.
Wed Aug 28 2024 06:57:18.375 [Info] - [System] Transition from ‘SteamVRSystemState_Off’ to ‘SteamVRSystemState_Startup’.
Wed Aug 28 2024 06:57:18.458 [Info] - [System] Runtime: 1721847232 250820 STEAMVR
Wed Aug 28 2024 06:57:21.191 [Info] - VR_Init failed with Hmd Not Found (108)
Wed Aug 28 2024 06:57:21.193 [Info] - [Steam] Attempt to connect to Steam
Wed Aug 28 2024 06:57:21.193 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:21.202 [Info] - Closing pipe SteamVR_Namespace because it was broken from the other end
Wed Aug 28 2024 06:57:21.202 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:21.210 [Info] - Add Json firmware manifest from {htc}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:21.210 [Info] - Add Json firmware manifest from {indexcontroller}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:21.210 [Info] - Add Json firmware manifest from {indexhmd}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:21.211 [Info] - Add Json firmware manifest from {lighthouse}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:21.211 [Info] - Add Json firmware manifest from {tundra_labs}/firmware/manifest.vrfirmware
Wed Aug 28 2024 06:57:21.212 [Info] - [Audio] Audio init
Wed Aug 28 2024 06:57:21.230 [Info] - [Status] Graphics driver version is 446.16.
Wed Aug 28 2024 06:57:21.231 [Info] - [System] Transition from ‘SteamVRSystemState_Startup’ to ‘SteamVRSystemState_Connecting’.
Wed Aug 28 2024 06:57:21.242 [Info] - [System] Transition from ‘SteamVRSystemState_Connecting’ to ‘SteamVRSystemState_NotReady’.
Wed Aug 28 2024 06:57:21.258 [Info] - [Steam] Connected to Steam in 0.06 seconds.
Wed Aug 28 2024 06:57:22.286 [Info] - [System] Runtime: 1721847232 250820 STEAMVR
Wed Aug 28 2024 06:57:22.286 [Info] - [Steam] Connect to Steam finished: check for dismissable warnings
Wed Aug 28 2024 06:57:28.365 [Info] - [System] System is running for 10 seconds.
Wed Aug 28 2024 06:57:28.365 [Info] - CQVRController::CheckHmdDriverName: failed to get ActualTrackingSystemName: TrackedProp_InvalidDevice
Wed Aug 28 2024 07:00:17.866 [Info] - [System Report] Discover USB Topology: Took 0.00 seconds
Wed Aug 28 2024 07:00:17.866 [Info] - [System Report] Iterate USB Topology: Took 0.00 seconds
— vrmonitor.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrmonitor.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:18.484 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:18.484 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:18.484 [Info] - vrmonitor.exe 2.7.4 startup with PID=4148, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:18.485 [Info] - vrclient type=VRApplication_VRMonitor
Wed Aug 28 2024 06:57:18.489 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.490 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.490 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.490 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.490 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.491 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:18.492 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:18.494 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:18.494 [Info] - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe -waitformonitor in C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Wed Aug 28 2024 06:57:18.500 [Info] - vrserver pid 5172
Wed Aug 28 2024 06:57:18.500 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:18.500 [Error] - CSharedResourceNamespaceClient::Init(): failed connect
Wed Aug 28 2024 06:57:18.500 [Warning] - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Wed Aug 28 2024 06:57:18.601 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:18.605 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:18.605 [Info] - WaitNamedPipe VR_ServerPipe_5172 failed because no one is listening at that name.
Wed Aug 28 2024 06:57:18.706 [Info] - Client (VR_ServerPipe_5172) app container state: 1
Wed Aug 28 2024 06:57:19.057 [Info] - Received success response from vrserver connect
Wed Aug 28 2024 06:57:21.181 [Info] - Timed out waiting for a good app key
Wed Aug 28 2024 06:57:21.181 [Info] - App key after connect message:steam.overlay.250820
Wed Aug 28 2024 06:57:21.187 [Info] - Reading EDID vendor Id timed out.
Wed Aug 28 2024 06:57:21.190 [Info] - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\vrwebhelper\win64\vrwebhelper.exe with pid 4752
Wed Aug 28 2024 06:57:21.203 [Info] - Unable to create property container PC_100000000 because creation was not requested
Wed Aug 28 2024 06:57:21.225 [Error] - [Input] Failed to load binding file. We’ll wait and try again when CRC or load count changes( computed CRC=0, old CRC=0, shared CRC=0, load count=0, shared load count=1 [app: steam.overlay.250820]
— vrclient_vrmonitor.txt - C:/Program Files (x86)/Steam/logs
C:/Program Files (x86)/Steam/logs/vrcompositor.txt is not available.
C:/Program Files (x86)/Steam/logs/vrclient_vrcompositor.txt is not available.
C:/Program Files (x86)/Steam/logs/vrprismhost.txt is not available.
C:/Program Files (x86)/Steam/logs/vrclient_vrprismhost.txt is not available.
C:/Program Files (x86)/Steam/logs/firmware_update.txt is not available.
C:/Program Files (x86)/Steam/logs/vrserver.previous.txt is not available.
=== basestation_wireless.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:18.373 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:18.373 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:18.373 [Info] - vrmonitor.exe 2.7.4 startup with PID=4148, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:21.211 [Info] - [Bluetooth Controller] BaseStation Controller Init.
Wed Aug 28 2024 06:57:21.211 [Info] - [Bluetooth Controller] Radio features: 0x00000000
Wed Aug 28 2024 06:57:21.211 [Info] - [Bluetooth Controller] Setting system inactivity timeout to 60 minutes.
— basestation_wireless.txt - C:/Program Files (x86)/Steam/logs
C:/Program Files (x86)/Steam/logs/vrdashboard.txt is not available.
=== vrclient_vrstartup.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:14.073 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:14.073 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:14.073 [Info] - vrstartup.exe 2.7.4 startup with PID=408, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win32
Wed Aug 28 2024 06:57:14.074 [Info] - vrclient type=VRApplication_Bootstrapper
Wed Aug 28 2024 06:57:14.081 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.081 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.082 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.082 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.082 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.083 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:14.084 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:14.087 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:14.087 [Info] - Starting vrserver process: C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrserver.exe -waitformonitor in C:\Program Files (x86)\Steam\steamapps\common\SteamVR
Wed Aug 28 2024 06:57:14.091 [Info] - vrserver pid 4828
Wed Aug 28 2024 06:57:14.091 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name.
Wed Aug 28 2024 06:57:14.091 [Error] - CSharedResourceNamespaceClient::Init(): failed connect
Wed Aug 28 2024 06:57:14.091 [Warning] - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Wed Aug 28 2024 06:57:14.192 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:14.194 [Info] - Closing pipe SteamVR_Namespace because it was broken from the other end
Wed Aug 28 2024 06:57:14.194 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 4828
Wed Aug 28 2024 06:57:14.194 [Info] - WaitNamedPipe VR_ServerPipe_4828 failed because no one is listening at that name.
Wed Aug 28 2024 06:57:14.295 [Info] - Client (VR_ServerPipe_4828) app container state: 1
Wed Aug 28 2024 06:57:15.049 [Info] - Received connect response VRInitError_Init_HmdNotFound. Giving up.
Wed Aug 28 2024 06:57:18.241 [Info] - Started C:\Program Files (x86)\Steam\steamapps\common\SteamVR\bin\win64\vrmonitor.exe with pid 4148
— vrclient_vrstartup.txt - C:/Program Files (x86)/Steam/logs
C:/Program Files (x86)/Steam/logs/vrclient_steamtours.txt is not available.
C:/Program Files (x86)/Steam/logs/vrclient_steamvr_room_setup.txt is not available.
C:/Program Files (x86)/Steam/logs/vrclient_steamvr_tutorial.txt is not available.
=== vrwebhelper_main.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:21.242 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:21.242 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:21.243 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:21.243 [Info] - vrwebhelper.exe 2.7.4 startup with PID=4752, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:23.414 [Info] - Using htmlcache path C:\Users\Administrator\AppData\Local\SteamVR\htmlcache
Wed Aug 28 2024 06:57:23.444 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:23.446 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:23.447 [Info] - Added overlay (pairing)
Wed Aug 28 2024 06:57:23.450 [Info] - Creating browser pointed at http://127.0.0.1:27062/lighthouse/webinterface/pairing.html?desktop=true&persisted=true (max fps 120)
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (bindingcallouts) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (controllerbinding) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (controllerbinding_desktop) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (debugcommands_desktop) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (fallback) because setting “driver_lighthouse.enableImuFallback” is False
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (keyboard) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (managetrackers_desktop) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (messageoverlay) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (notificationtoast) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.451 [Info] - Skipped overlay (scenegraphtest) because setting “dashboard.sceneGraphTest” is False
Wed Aug 28 2024 06:57:23.451 [Info] - Added overlay (settings_desktop)
Wed Aug 28 2024 06:57:23.454 [Info] - Creating browser pointed at http://127.0.0.1:27062/dashboard/settings_desktop.html?desktop=true&persisted=true (max fps 120)
Wed Aug 28 2024 06:57:23.454 [Info] - Skipped overlay (systemui) because no HMD is present. Set valid_without_hmd to true to create it anyway.
Wed Aug 28 2024 06:57:23.455 [Info] - Added 2 overlays from 2 configurations. 2 have been opened.
Wed Aug 28 2024 06:57:23.455 [Info] - Starting CEF Message Loop…
— vrwebhelper_main.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_Steam.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:11.051 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:11.051 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:11.051 [Info] - Steam.exe 2.7.4 startup with PID=3728, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win32
Wed Aug 28 2024 06:57:11.052 [Info] - vrclient type=VRApplication_SteamWatchdog
Wed Aug 28 2024 06:57:11.057 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.057 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.057 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.058 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.058 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.058 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.059 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:11.061 [Info] - Watchdog namespace: 3728
Wed Aug 28 2024 06:57:11.061 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.062 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.062 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.062 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.062 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.063 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:11.063 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:11.066 [Info] - Unable to load driver vrlink. Primary driver shared library not found on filesystem (for this architecture): C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\bin\win32\driver_vrlink.dll.
Wed Aug 28 2024 06:57:11.066 [Info] - Unable to init watchdog mode for driver vrlink: VRInitError_Init_FileNotFound
Wed Aug 28 2024 06:57:11.066 [Info] - Unable to load driver CloudXRRemoteHMD. Primary driver shared library not found on filesystem (for this architecture): C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\bin\win32\driver_CloudXRRemoteHMD.dll.
Wed Aug 28 2024 06:57:11.066 [Info] - Unable to init watchdog mode for driver CloudXRRemoteHMD: VRInitError_Init_FileNotFound
Wed Aug 28 2024 06:57:11.074 [Info] - error VRInitError_Init_LowPowerWatchdogNotSupported when initing driver lighthouse from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\bin\win32\driver_lighthouse.dll.
Wed Aug 28 2024 06:57:11.074 [Info] - Unable to init watchdog mode for driver lighthouse: VRInitError_Init_LowPowerWatchdogNotSupported
Wed Aug 28 2024 06:57:11.077 [Info] - Could not create interface in driver oculus from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus\bin\win32\driver_oculus.dll.
Wed Aug 28 2024 06:57:11.077 [Info] - Unable to init watchdog mode for driver oculus: VRInitError_Init_InterfaceNotFound
Wed Aug 28 2024 06:57:11.079 [Info] - Could not create interface in driver oculus_legacy from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\oculus_legacy\bin\win32\driver_oculus_legacy.dll.
Wed Aug 28 2024 06:57:11.079 [Info] - Unable to init watchdog mode for driver oculus_legacy: VRInitError_Init_InterfaceNotFound
Wed Aug 28 2024 06:57:11.080 [Info] - Unable to load driver gamepad from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\gamepad\bin\win32\driver_gamepad.dll (126)
Wed Aug 28 2024 06:57:11.081 [Error] - ASSERT: “DriverManager gamepad load error 126u” at c:\buildslave\steamvr_rel_win32\build\src\common\vrcommon\drivermanager.cpp:439.
Wed Aug 28 2024 06:57:11.081 [Info] - Unable to init watchdog mode for driver gamepad: VRInitError_Init_FileNotFound
Wed Aug 28 2024 06:57:11.081 [Info] - No drivers were capable of being watchdogs. Failing init.
— vrclient_Steam.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrwebhelper_main.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:21.253 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:21.253 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:21.253 [Info] - vrwebhelper.exe 2.7.4 startup with PID=4752, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:21.254 [Info] - vrclient type=VRApplication_WebHelper
Wed Aug 28 2024 06:57:21.258 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.258 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.258 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.259 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.259 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.259 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:21.260 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:21.262 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:21.268 [Info] - Closing pipe SteamVR_Namespace because it was broken from the other end
Wed Aug 28 2024 06:57:21.268 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:21.268 [Info] - Client (VR_ServerPipe_5172) app container state: 1
Wed Aug 28 2024 06:57:21.284 [Info] - Received success response from vrserver connect
Wed Aug 28 2024 06:57:23.408 [Info] - Timed out waiting for a good app key
Wed Aug 28 2024 06:57:23.408 [Info] - App key after connect message:steam.overlay.250820
Wed Aug 28 2024 06:57:23.482 [Error] - [Input] Failed to load binding file. We’ll wait and try again when CRC or load count changes( computed CRC=0, old CRC=0, shared CRC=0, load count=0, shared load count=1 [app: steam.overlay.250820]
— vrclient_vrwebhelper_main.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrwebhelper_pairing.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:24.628 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:24.628 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:24.628 [Info] - vrwebhelper.exe 2.7.4 startup with PID=4288, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:24.629 [Info] - vrclient type=VRApplication_WebHelper
Wed Aug 28 2024 06:57:24.635 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.635 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.635 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.635 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.636 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.636 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.638 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:24.640 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:24.645 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:24.645 [Info] - Client (VR_ServerPipe_5172) app container state: 1
Wed Aug 28 2024 06:57:24.661 [Info] - Received success response from vrserver connect
Wed Aug 28 2024 06:57:24.663 [Info] - App key after connect message:
Wed Aug 28 2024 06:57:24.675 [Error] - [Input] Failed to load binding file. We’ll wait and try again when CRC or load count changes( computed CRC=0, old CRC=0, shared CRC=0, load count=0, shared load count=1 [app: ]
— vrclient_vrwebhelper_pairing.txt - C:/Program Files (x86)/Steam/logs
=== vrclient_vrwebhelper_settings_desktop.txt - C:/Program Files (x86)/Steam/logs
Wed Aug 28 2024 06:57:24.633 [Info] - //==============================================================================================
Wed Aug 28 2024 06:57:24.633 [Info] - ================================================================================================
Wed Aug 28 2024 06:57:24.633 [Info] - vrwebhelper.exe 2.7.4 startup with PID=5968, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Wed Aug 28 2024 06:57:24.641 [Info] - vrclient type=VRApplication_WebHelper
Wed Aug 28 2024 06:57:24.647 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.647 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.647 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.648 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.648 [Info] - [Settings] Load Default Json Settings from C:\Program Files\NVIDIA Corporation\CloudXR\VRDriver\CloudXRRemoteHMD\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.648 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\resources\settings\default.vrsettings
Wed Aug 28 2024 06:57:24.649 [Info] - [Settings] Load Json Settings from C:\Program Files (x86)\Steam\config\steamvr.vrsettings
Wed Aug 28 2024 06:57:24.651 [Info] - Client (SteamVR_Namespace) app container state: 1
Wed Aug 28 2024 06:57:24.656 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 5172
Wed Aug 28 2024 06:57:24.656 [Info] - Client (VR_ServerPipe_5172) app container state: 1
Wed Aug 28 2024 06:57:24.665 [Info] - Received success response from vrserver connect
Wed Aug 28 2024 06:57:26.798 [Info] - Timed out waiting for a good app key
Wed Aug 28 2024 06:57:26.798 [Info] - App key after connect message:steam.overlay.250820
Wed Aug 28 2024 06:57:26.812 [Error] - [Input] Failed to load binding file. We’ll wait and try again when CRC or load count changes( computed CRC=0, old CRC=0, shared CRC=0, load count=0, shared load count=1 [app: steam.overlay.250820]
— vrclient_vrwebhelper_settings_desktop.txt - C:/Program Files (x86)/Steam/logs
