When I first bought my Jetson Orin I thought I remembered seeing a splash screen and boot progress on the connected 4K displayport monitor. However, now, even after flashing Jetpack 5.0.2 it boots fine to the graphical login but does not display boot progress or a splash screen.
Is this normal? And if so can the boot progress (plus non-graphical login) be made to appear by altering extlinux.cfg somehow ?
No, more than that. You don’t see that, but you also do not see the boot progress scrolling by. But it has more impact than that, you then cannot login without a graphical logic because you cannot see the login prompt.
I’m still kind of confused what’s your issue.
did you setup a serial console to monitor the bootloader logs? or, you have display monitor connected but see nothing?
is it possible to share a short video clip to describe what you said. thanks
I could share a video but it would be a video of a blank screen.
Let’s describe it another way. If I were to disable the graphical login by running
sudo systemctl set-default multi-user.target
Then the computer would be with nothing visible on the screen. You would be able to login to the computer via ssh but you could not use the keyboard/monitor combination to login to a character based login screen but there isn’t one, just a blank screen.
