Hi Shane,
I connected the system to CSI analyzer, and the traffic after the Deserializer received successful and correctly.
The sensor is transmitting 2048x384 raw12 over 4 lanes CSI at rate 1.1G each lane.
Below is my DT configuration:
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
imx324_vi_in0: endpopoint {
vc-id = <0>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx324_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx324_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx324_imx324_out0>;
port@1 {
reg = <1>;
imx324_csi_out0: endpoint@1 {
remote-endpoint = <&imx324_vi_in0>;
i2c@3180000 {
tca9546@70 {
i2c@0 {
imx324_a@1a {
compatible = "nvidia,imx324";
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="imx324";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
//use_decibel_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* vc_id = "";
* The virtual channel id of the sensor.
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* dynamic_pixel_bit_depth = "";
* sensor dynamic bit depth for sensor mode
* csi_pixel_bit_depth = "";
* sensor output bit depth for sensor mode
* mode_type="";
* Sensor mode type, For eg: yuv, Rgb, bayer, bayer_wdr_pwl
* pixel_phase="";
* Pixel phase for sensor mode, For eg: rggb, vyuy, rgb888
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* if use_decibel_gain = "true", please set the gain as decibel
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 {/*mode AWR2243_MODE_2048X384*/
vc_id="0";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "2048";
active_h = "384";
line_length = "2048";
inherent_gain = "1";
mclk_multiplier = "15.3";
pix_clk_hz = "367200000";
gain_factor = "10";
min_gain_val = "0"; /* dB */
max_gain_val = "300"; /* dB */
step_gain_val = "1"; /* 0.1 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "20000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "25000000";
exposure_factor = "1000000";
min_exp_time = "59"; /*us, 2 lines*/
max_exp_time = "55556";
step_exp_time = "1";
default_exp_time = "556";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx324_imx324_out0: endpoint {
port-index = <0>;
bus-width = <4>;
vc-id = <0>;
remote-endpoint = <&imx324_csi_in0>;
gmsl-link {
src-csi-port = "a";
dst-csi-port = "a";
serdes-csi-link = "a";
csi-mode = "1x4";
num-lanes = <4>;
streams = "ued-u1", "raw12";
}; /*i2c@0*/
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1100000>;
min_bits_per_pixel = <12>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "imx324_front";
position = "front";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx324 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx324_a@1a";
I boosted the clock, and open the debug traces.
Below is the trace log:
kworker/0:3-2165 [000] .... 214.645951: rtos_queue_peek_from_isr_failed: tstamp:7146539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 214.757939: rtos_queue_peek_from_isr_failed: tstamp:7151539895 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 214.925941: rtos_queue_peek_from_isr_failed: tstamp:7156539894 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.093982: rtos_queue_peek_from_isr_failed: tstamp:7161539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.261946: rtos_queue_peek_from_isr_failed: tstamp:7166539894 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.429940: rtos_queue_peek_from_isr_failed: tstamp:7171539894 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.597947: rtos_queue_peek_from_isr_failed: tstamp:7176539894 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.765994: rtos_queue_peek_from_isr_failed: tstamp:7181539896 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 215.877959: rtos_queue_peek_from_isr_failed: tstamp:7186539894 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 216.049964: rtos_queue_peek_from_isr_failed: tstamp:7191539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 216.218003: rtos_queue_peek_from_isr_failed: tstamp:7196539901 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 216.385938: rtos_queue_peek_from_isr_failed: tstamp:7201539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 216.721967: rtos_queue_peek_from_isr_failed: tstamp:7211539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 216.837977: rtos_queue_peek_from_isr_failed: tstamp:7216539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 217.005976: rtos_queue_peek_from_isr_failed: tstamp:7221539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 217.173941: rtos_queue_peek_from_isr_failed: tstamp:7226539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 217.509993: rtos_queue_peek_from_isr_failed: tstamp:7236539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 217.677982: rtos_queue_peek_from_isr_failed: tstamp:7241539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 217.957954: rtos_queue_peek_from_isr_failed: tstamp:7251539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 218.125936: rtos_queue_peek_from_isr_failed: tstamp:7256539892 queue:0x0bcbbbb8
kworker/0:3-2165 [000] .... 218.237955: rtos_queue_peek_from_isr_failed: tstamp:7259287510 queue:0x0bcbbbb8
v4l2-ctl-9515 [003] .... 227.820424: tegra_channel_open: vi-output, imx324 30-001a
v4l2-ctl-9515 [001] .... 227.832877: tegra_channel_set_power: imx324 30-001a : 0x1
v4l2-ctl-9515 [001] .... 227.832913: camera_common_s_power: status : 0x1
v4l2-ctl-9515 [001] .... 227.834070: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-9515 [001] .... 227.834079: csi_s_power: enable : 0x1
v4l2-ctl-9515 [001] .... 227.843742: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-9515 [001] .... 227.854937: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-9515 [001] .... 227.854941: csi_s_stream: enable : 0x1
v4l2-ctl-9515 [001] .... 227.854943: tegra_channel_set_stream: imx324 30-001a : 0x1
v4l2-ctl-9515 [001] .... 232.740804: tegra_channel_close: vi-output, imx324 30-001a
v4l2-ctl-9515 [001] .... 232.740888: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-9515 [001] .... 232.740891: tegra_channel_set_stream: imx324 30-001a : 0x0
v4l2-ctl-9515 [001] .... 232.742899: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-9515 [001] .... 232.742903: csi_s_stream: enable : 0x0
v4l2-ctl-9515 [000] .... 232.745340: tegra_channel_set_power: imx324 30-001a : 0x0
v4l2-ctl-9515 [000] .... 232.745347: camera_common_s_power: status : 0x0
v4l2-ctl-9515 [000] .... 232.745545: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-9515 [000] .... 232.745548: csi_s_power: enable : 0x0
It seems like the Jetson doesn’t receive FS even though it is being transmitted on the lines.
Also, when running the command:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=2048, height=384,
I get the following:
format=NV12' ! appsink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2048 x 384 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 0.000000, max 30.000000; Exposure Range min 59000, max 55556000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 2048 H = 384
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: Done Success
Got EOS from element "pipeline0".
Execution ended after 0:00:04.006548640
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
Any idea?
