I’m running Fedora 11 From uname -a I get:
Linux phy108204.phy.tcd.ie 2.6.29.6-217.2.3.fc11.x86_64 #1 SMP Wed Jul 29 16:02:42 EDT 2009 x86_64 x86_64 x86_64 GNU/Linux
and when I run the deviceQueryDrv binary i get
Device 0: “Tesla C1060”
CUDA Driver Version: 2.20
and
Device 1: “Quadro NVS 295”
but deviceQuery returns “No CUDA device enabled.” and bandWidthTest seg faults.
I have nvida0, nvidia1, nvram, and nvidiaactl in my /dev directory However
rpm -qa | grep nvidia d
oesn’t return anything.
Is this an issue with my kernel? Is there any way to fix this or should I just reinstall the toolkit, then the driver, then the sdk and keep my fingers crossed?
Are you sure that you install CUDA driver? I’ve get the same error because I do not install the driver. Be careful with the graphics driver. They do not turn you able to use the CUDA capability of the GPU.
