L4T 32.7.2 has been released , but there are no 32.7.2 packages in the apt repository.
$ sudo apt update
Hit:1 https://repo.download.nvidia.com/jetson/common r32.7 InRelease
Hit:2 https://repo.download.nvidia.com/jetson/t186 r32.7 InRelease
...snip...
$ apt-cache policy nvidia-jetpack
nvidia-jetpack:
Installed: (none)
Candidate: 4.6.1-b110 <--- Expect 4.6.2
Version table:
4.6.1-b110 500
500 https://repo.download.nvidia.com/jetson/t186 r32.7/main arm64 Packages
$ apt-cache policy nvidia-l4t-jetson-multimedia-api
nvidia-l4t-jetson-multimedia-api:
Installed: (none)
Candidate: 32.7.1-20220219090344 <--- Expect 32.7.2-20220417024839
Version table:
32.7.1-20220219090344 500
The following packages are not provided by BSP and are specifically needed.
nvidia-jetpack
The other nvidia-l4t-* package also does not exist 32.7.2 version.
Any plans to upload them?
Best regards,
kayccc
May 11, 2022, 3:34am
#2
For L4T R32.7.2, the only change came with the BSP for PSIRT fixes, others are the same as L4T R32.7.1, AFAIK, there is no plan to update relevant documents or packages.
@kayccc
32.7.2 cannot install nvidia-jetpack. Is it a spec?
Please upload the 32.7.2 debian package to the repository.
BSP for 32.7.2 cannot install nvidia-jetpack because nvidia-l4t-camera 32.7.2 is installed.
$ apt install nvidia-jetpack
...snip...
The following packages have unmet dependencies:
nvidia-l4t-jetson-multimedia-api : Depends: nvidia-l4t-camera (= 32.7.1-20220219090344) but 32.7.2-20220417024839 is to be installed
Depends: nvidia-l4t-multimedia (= 32.7.1-20220219090344) but 32.7.2-20220417024839 is to be installed
Depends: nvidia-l4t-multimedia-utils (= 32.7.1-20220219090344) but 32.7.2-20220417024839 is to be installed
E: Unable to correct problems, you have held broken packages.
nvidia-jetpack 4.6.1-b110 depends on nvidia-l4t-jetson-multimedia-api (>> 32.7-0, << 32.8-0).
$ apt show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6.1-b110
...snip...
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
nvidia-l4t-jetson-multimedia-api 32.7.1 depends on nvidia-l4t-camera 32.7.1.
$ apt show nvidia-l4t-jetson-multimedia-api
Package: nvidia-l4t-jetson-multimedia-api
Version: 32.7.1-20220219090344
...snip...
Depends: cuda-cudart-10-2, cuda-cudart-dev-10-2, libc6-dev, libglvnd-dev, libx11-dev, nvidia-l4t-camera (= 32.7.1-20220219090344), nvidia-l4t-multimedia (= 32.7.1-20220219090344), nvidia-l4t-multimedia-utils (= 32.7.1-20220219090344)
...snip...
kayccc
May 11, 2022, 7:46am
#4
You should be able to see the JetPack 4.6.2 for L4T R32.7.2.
@kayccc
No, only nvidia-jetpack 4.6.1.
Please upload nvidia-jetpack 4.6.2 and 32.7.2 debian package to the repository.
$ sudo apt update
...snip....
nvidia-jetpack:
Installed: (none)
Version table:
4.6.1-b110 500
Hi nomotoh3v2z ,
We will check apt install issue.
Please use SDK Manager to install sdk components first, it’s working.
@carolyuu
Thank you for your support.
I am unable to use the SDK Manager because I am using a custom board.
You should be able to install SDK components through SDKManager for custom board. Please give it a try.
@DaneLLL
sdkmanager requires flash.
OTA updates are not possible and require physical access.
Please upload jetpack v4.6.2 to the repository so that OTA updates can be done. Just like any other L4T version.
You can skip flash and install only SDK Components. Please try this.
@DaneLLL
In any case, sdkmanager requires a host PC.
L4T 32.7.2 cannot update jetpack on the device. This differs from other L4T versions.
We need a package in the apt repository that matches the L4T version.
Our teams are checking the issue. Will update.
Currently for installing SDK components, please install through SDKManager.
apt server has updated and has 32.7.2 package now. Please try.
@WayneWWW
I have verified that the package uploaded as expected.
Thank you for all your assistance.
$ sudo apt update
...snip...
nvidia-jetpack:
Installed: (none)
Candidate: 4.6.2-b5
Version table:
4.6.2-b5 500
4.6.1-b110 500
Installed: (none)
Candidate: 32.7.2-20220417024839
Version table:
32.7.2-20220417024839 500
