Hello out there, I have quite new Debian system with GeForce RTX 4060Ti 16GB and Core i7-14700 on a MSI Z690-A WIFI DDR4. The system boots up but does not open a display manager or something else.
uname -a > Linux jupiter 6.11.5-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.11.5-1 (2024-10-27) x86_64 GNU/Linux
Blockquote
dmesg | grep nvidia
[ 3.428925] nvidia: loading out-of-tree module taints kernel.
[ 3.428931] nvidia: module license ‘NVIDIA’ taints kernel.
[ 3.428933] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.428933] nvidia: module license taints kernel.
[ 3.529038] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 3.529835] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 3.668222] audit: type=1400 audit(1731518567.508:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=948 comm=“apparmor_parser”
[ 3.668225] audit: type=1400 audit(1731518567.508:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=948 comm=“apparmor_parser”
[ 4.358670] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 535.183.06 Wed Jun 26 06:40:18 UTC 2024
[ 5.131093] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 5.131095] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
Blockquote
and during bootup it creates two Xorg.0.log files successively. I don’t know if this normal. But look on the stats of these two files:
File: Xorg.0.log
Size: 3328 Blocks: 8 IO Block: 4096 regular file
Device: 259,2 Inode: 55443509 Links: 1
Access: (0644/-rw-r–r–) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2024-11-13 16:47:09.841449666 +0100
Modify: 2024-11-13 16:47:09.845449672 +0100
Change: 2024-11-13 16:47:09.845449672 +0100
Birth: 2024-11-13 16:47:09.841449666 +0100
File: Xorg.0.log.old
Size: 9671 Blocks: 24 IO Block: 4096 regular file
Device: 259,2 Inode: 55444047 Links: 1
Access: 2024-11-13 16:47:00.593437723 +0100
Modify: 2024-11-13 16:47:09.613449355 +0100
Change: 2024-11-13 16:47:09.841449666 +0100
Birth: 2024-11-13 16:47:00.593437723 +0100
So the 2nd file is created after the 1st was closed?
I attach the two files. But the 2nd logfile says that the xserver actually starts and the kernel modules are getting loaded. But nvidia-smi on the other side, says: No devices were found
At the end ,y dmesg is fludded with this two lines over and over again:
NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x23:0x65:1426)
NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
nvidia-bug-report.log.gz (611.7 KB)
dmesg6.txt (91.2 KB)
Xorg.0.log (8.4 KB)
Xorg.0.old.log (9.4 KB)
Can anyone find a clue here, in which state my driver is?
Thanks a lot
BR Christian
