No display with JP6.1
Hi.
I just updated to JP6.1 but when I use DP-HDMI and a mobile monitor, the screen can not display, I have changed to the monitor that has DP and it can work. Please help me fix it.
Thank you.
Please help share the result of /var/log/Xorg.0.log with DP-HDMI cable connected case.
Also, please help test if jetpack6.0 is fine. Just a experiment.
I’ve just returned to JP6, and the DP-HDMI works perfectly with it!
If possible, please also share me the /var/log/Xorg.0.log with DP-HDMI cable connected case on jp6.1.
Thank you.
