I tried looking at other forum posts but with no success. There is no nvidia audio driver visible in lspci
whatsoever.
nvidia-bug-report.log.gz (418.8 KB)
The audio device is there on kernel init but then gets removed. Please check for a udev rule doing this
grep 10de /lib/udev/rules.d/*
kiroma@localhost:~> grep 10de /lib/udev/rules.d/*
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
/lib/udev/rules.d/90-nvidia-udev-pm-G05.rules:ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
# Remove NVIDIA USB xHCI Host Controller devices, if present
# Remove NVIDIA USB Type-C UCSI devices, if present
# Remove NVIDIA Audio devices, if present
# Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
# Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
This is weird, I have not edited the file, this is how it came from the package?
Yes, seems it came with the package. Please comment out the first three lines, then run sudo dracut -f to also change it in the initrd.
