I just flashed the TX1 with JetPack 2.3.1, I dont see the firefox browser which came default when I booted the TX1 by default.
I did run:
sudo apt-get update
sudo apt-get upgrade
but doesn’t seem to help get firefox.
I did run:
sudo apt-get update
Firefox has not worked in prior JetPack versions. Using Chromium browser since.
Marc
On R24.2.1 I installed firefox and very minimal testing worked. The command is:
sudo apt-get install firefox
I don’t know which repository this is from, but basically I have everything uncommented in “/etc/apt/sources.list”, and then updated with “sudo apt update”, so if you can’t use apt-get install, then it might be a missing repo config.
