No-Flash Option Only Working in Recovery Mode
We did a migration to Jetpack 5.1.3 / L4T 35.5.0 and updated the SDK Manager to 2.1.0.1 1660.
Following those updates, the --no-flash option stopped working if the Orin is not in Recovery Mode.
As this process requires physical access (enter / leave Recovery Mode), it poses a constraint to the team.
The problem is the following:
$ sudo ./flash.sh -r --no-flash jetson-agx-orin-devkit mmcblk0p1 # not in recovery mode
# L4T BSP Information:
# R35 , REVISION: 5.0
# User release: 0.0
ECID is
Board ID() version() sku() revision()
Chip SKU(00:00:00:D0) ramcode() fuselevel(fuselevel_production) board_FAB()
Error: Unrecognized module SKU
When in Recovery Mode:
$ sudo ./flash.sh -r --no-flash jetson-agx-orin-devkit mmcblk0p1 #  in recovery mode
no_flash_recov_mode_read_info.txt (15.4 KB)
no_flash_recov_mode.txt (26.3 KB)
Note that normal flashing works perfectly fine (but causes development constraints, since it resets the board):
$ sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1 #  in recovery mode
How should we proceed to make --no-flash work again without Recovery Mode?
Thank you.
I don’t really know what’s the purpose of putting -r and --no-flash together.
From JP 6 , jetson-agx-orin-devkit board configure require that BOARDSKU, FAB, BOARDID are provided through environment variable in the command line like this:
Your eeprom information
Board ID(3701) version(500) sku(0000) revision(M.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(500)
So your command would be like
sudo BOARDID=3701 BOARDSKU=0000 FAB=500 BOARDREV=500 CHIP_SKU=D0 RAMCODE=0 FUSELEVEL=fuselevel_production ./flash.sh --no-flash jetson-agx-orin-devkit mmcblk0p1
by the way it is possible to control the board remotely through the use of its micro USB port, Board Automation — Jetson Linux Developer Guide documentation
