I use Fedora11 and do scientific computation on GPU(GTX480).
Since several month ago, I cannot find any GPUs on the other computer by using SSH,then I found two way to solve this problem.
go to that GPU computer and log in (or then “switch user”), then go back to my own computer.
if nobody locally use the GPU computer, I can remotely use it without any problem. If anybody log in locally (I mean sitting in front of the GPU computer and use it), the GPU will “disappear”.
by the way, I use an additional graphic card to connect the monitor, the GTX480 are only used to do computation.
Being fedora, I would guess it is something to do with SElinux. I work in the exact scenario you are describing every day in a Ubuntu box, and have never seen anything like that. Check the kernel ring buffer and syslog and see whether there are any errors being reported.
