Hi everyone,
I’ve started looking at the particle example supplied with CUDA 5.5 and have run into an issue when I try and compile it. When I build the example with VS 2010 I get no errors but when I run it performance is terrible; Its running at around ~20FPS. I checked GPU utilization and its almost 0%, but CPU utilization is 25% and one core is maxed out. When I run the Nvidia supplied .exe everything runs great, right around ~300FPS and up to 50% GPU usage. Should I try a makefile or is my environment not setup properly
My System:
Dell M6600
NVIDIA Quadro 3000M
Intel i7 2620 @2.7GHz
Windows 7 64bit
Visual Studio 2010 and 2012
