Hi, I am new to DS and I am trying to build my own application on a remote server using Graph Composer. The specs of the remote machine are above. I am currently using a VNC viewer to have a UI of the remote machine through ssh connection.
When running the command in the Terminal
echo $DISPLAY
the output number correspond to the desktop number I am currently using.
I followed the same command as described in the guide
The docker container is successfully instantiated, but once I run the composer command no GUI is opened. In attachment you can see the error that arise.
There is no physical monitor directly attached to the A100 machine. The only “monitor” i can have is via ssh connection with VNC viewer.
I managed to get the graph composer GUI by authenticating the container to access the X Server without the need of VNCviewer. First, I got an X authentication token from your host machine (A100) by running xauth list and note down one of the listed tokens. Then, I installed the xauth package inside the docker container itself and I added the token I copied in the previous step.
# in host machine
xauth list
# copy entire line of <token>
xhost +
docker run -it --entrypoint /bin/bash --gpus all --rm --network=host -e DISPLAY=${DISPLAY} -v /tmp/.X11-unix/:/tmp/.X11-unix --privileged -v /var/run/docker.sock:/var/run/docker.sock nvcr.io/nvidia/deepstream:6.1.1-devel
# Inside docker container
apt install -y xauth
xauth add <token>
composer
However, even though I get the GUI up and running it is often lagging and it is not the best user-interface experience.
Do you have other suggestions?
Thanks!!
There should be a physical monitor connected with the Nvidia GPU. And please make sure the Graph Composer works well on local machine before you use remote terminal.
