Hi NVIDIA Team,
We have designed a custom carrier board based on the P3768-A04 Jetson Orin NX Carrier Board reference design and are experiencing an HDMI display issue.
Hardware
- Module: Jetson Orin NX Super
- Custom carrier board based on: P3768-A04 reference design
- Comparison board: AIB-SN31/41
- Software: Same SSD, same Jetson SOM, same BSP
Issue
There is no HDMI output when the Jetson Orin NX Super module is installed on our custom carrier board.
To rule out software issues, we tested the same Jetson SOM and the same SSD on the AIB-SN31/41 carrier board, where HDMI works correctly and the display is detected without any issues.
This indicates that the Jetson module and software image are functioning correctly, and the issue appears to be specific to our custom carrier board.
Request for Guidance
We would appreciate your assistance with the following:
- What are the recommended steps to debug HDMI on a custom carrier board?
- How can we verify whether the HDMI DDC/EDID I²C communication is working?
- Which I²C controller is used for HDMI DDC on the Jetson Orin NX platform, and how can we identify it from Linux?
- Are there any common hardware design considerations or device tree configurations that should be verified for HDMI bring-up?
We have also attached the HDMI schematic from our custom carrier board. We would greatly appreciate it if you could review the schematic and let us know if you notice any issues or deviations from the reference design that could explain the lack of HDMI output.
If additional logs, measurements, or test results are required, please let us know and we will provide them.
Thank you for your support.
HDMI-DP.pdf (104.5 KB)
I feel there are problems from both hardware and software.
- Custom carrier board based on: P3768-A04 reference design. P3768 does not have a HDMI connector support. Refer to it won’t give you a valid HDMI port.
Please do not say something like “rule out software issue”. HDMI must have extra software configuration to get fully supported. Default setting only has DP configuration. And somehow this mode could support HDMI with up to 1080p.
To get HDMI mode, please refer to p3509 board config in your BSP directory.
Hi @WayneWWW ,
Thank you for your input.
Currently, neither DisplayPort nor HDMI is working on our custom carrier board. The hardware has provisions for both HDMI and DP, but only one interface is intended to be active at a time depending on the configuration.
Based on your explanation, it seems that the required display configuration (DCB/device tree) for our board has not been applied. Since we do not currently have the BSP source or build environment, is there a way to verify from the running system whether the HDMI/DP display configuration has been correctly applied?
From the running system, I observed the following:
The board identifies itself as NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super.
The compatible string is nvidia,p3768-0000+p3767-0000-super.
The DRM subsystem exposes an HDMI-A-1 connector, but the kernel reports:
[drm] Cannot find any crtc or sizes
HDMI-DP.pdf (79.2 KB)
No, this must be configured by doing reflash.
If even default DP setting is not working, I wonder even hardware side has some issue. For example, that mux.
we will verify dp once again and check mux and other things in hardware and updte you.
We are currently running the following software configuration:
- JetPack: 6.2
- Jetson Linux (L4T): 36.4.3
- Kernel: 5.15.148-tegra
Could you please point me to the appropriate documentation(link) or guide for enabling HDMI support on a custom carrier board based on P3768?
Specifically, I’m looking for documentation that covers:
- The required device tree/DCB changes to enable HDMI.
- The BSP files that need to be modified.
- The steps to rebuild the DTB/BSP.
- The procedure to flash the updated configuration onto the target board.
The p3509 board config in your LInux_for_Tegra includes everything to enable the HDMI. You could refer to that first. Search “3509” in your BSP and it shall give you the result.
pinmux for hpd.
overlay file for DCB and hotplug pin.
Basically just these two.
The method to build source code is mentioned in the developer guide.
You could start with the webpage with the version you need. Then choose the developer guide to read kernel customization section.
Could you please review our carrier board schematics and let us know if you notice any issues related to the display interface?
Since both DisplayPort and HDMI are currently not working, and you mentioned that DisplayPort should work with the default P3768 configuration, we would appreciate it if you could verify our schematic and point out any potential issues with the HDMI/DP MUX, HPD, AUX routing, or any other display-related connections that may be incorrect.
Any feedback or recommendations would be greatly appreciated. Thank you.
I have attached the decompressed dts file and schematics for reference.
kernel_tegra234-p3768-0000+p3767-0000-nv-super.zip (37.5 KB)
I am not any hardware folk that is able to review a schematic.
You may refer to design guide document first. Even p3768 carrier boars is not supported to switch DP and HDMI on the same board.
From software check, you could check your xorg log when you hotplug the DP cable. If even that not triggering any new log in xorg, it means even the hotplug does not respond to dpaux pad.
Below is my xorg and dmesg log
export DISPLAY=:0 nvidia@localhost:~$ xrandr
Screen 0: minimum 8 x 8, current 640 x 480, maximum 32767 x 32767
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
nvidia@localhost:~$
$ sudo dmesg -w | grep -Ei “dp|drm|display|aux|hotplug|edid”
[ 0.129905] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.129953] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.130636] RPC: Registered udp transport module.
[ 9.429558] systemd[1]: Created slice Slice /system/modprobe.
[ 9.530924] systemd[1]: Starting Load Kernel Module drm…
[ 9.572700] systemd[1]: Starting Coldplug All udev Devices…
[ 10.399920] drm drm: [drm] Cannot find any crtc or sizes
[ 10.410199] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[ 10.499557] dce: tegra_dce_probe:245 Found display consumer device
[ 10.561571] nv_platform 13800000.display: Adding to iommu group 48
[ 10.576246] platform 13800000.display:nvdisplay-niso: Adding to iommu group 49
[ 10.693644] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[ 10.713403] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[ 10.720931] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[ 10.734654] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[ 16.126603] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[ 24.404515] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[ 24.405115] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
Xorg-log.txt (42.3 KB)
Do you want to try DP or HDMI case now?
Please do not mix up 2 different interfaces at once. I hope we just discuss one interface first.
Also, why is your xorg log like a chaos with lots of unrelated info? Please just post the right information.
Since DP is supported by default, we are first trying to get the DP display working. Sorry for the Xlog confusion—I accidentally copied some unrelated logs as well.
Xorg-log.txt (16.6 KB)
How did you flash your board?
I don’t think you are using any default setting.
24.407] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 24.407] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 24.408] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
This indicates you are actually using a HDMI setting now. If you use default setting, then there should be a DP in above. But it is not there.
To provide some context, we have the AIB-SN31/41 EVK, where HDMI works correctly. Our custom carrier board uses the same NVIDIA Jetson Orin NX SOM along with the same SSD from the EVK.
Our goal is to verify that all interfaces on the custom carrier board are functioning correctly. Initially, I mentioned that HDMI was working because it works on the EVK with this exact SOM and SSD. However, when we move the same hardware to our custom carrier board, HDMI does not work.
As far as I know, we are still using the default image that came with the EVK, as I have not flashed a new BSP or modified the software. The module is the NVIDIA Jetson Orin NX, and the EVK supports (Super Mode-enabled) modules.
Just to clarify. I don’t think you understand the situation correctly.
I don’t know what is “AIB-SN31/41 EVK”. I tried to goolge search for this and shows that it is a custom board. Any carrier board that is not a NV devkit is called custom board. Using a custom board to prove any behavior may not be precise.
Even the default software setting “partially” supports the HDMI function which makes you think “this thing supports HDMI” but it is not true. When it goes to 4k monitor, it won’t work.
Please be aware that "default image’ here means the image from sdkmanager. Not something else.
As you are using a custom board, actually that “default image that came with the EVK” does not mean anything to me. That EVK you are talking about is a custom board. No one knows what software you are truly using there.
You should not rely on a mysterious image to check things here. Learn to flash the image by yourself and also how to build kernel dts first. If you are using sdkmanager image, please just tell it is sdkmanager image instead of “default image that came with the EVK”. No one knows what is that.
Also, focus on just one item first. I notice you are still discussing things between DP and HDMI. That is bad idea when you are a newbie for this.
HDMI and DP software setting are totally different. Decide what you want to do first.
