After pluggin my HDMI cable there monitor isn’t detecting the HDMI input.
dmesg | cat shows a lot errors:
[ 596.412956] tegradc 15210000.nvdisplay: unblank
[ 596.412999] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 596.413017] Switching i2c_ddc sclk rate: from 6250, to 100000
[ 596.417954] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 596.475651] tegradc 15210000.nvdisplay: blank - powerdown
[ 596.481079] tegradc 15210000.nvdisplay: unblank
[ 596.485637] tegradc 15210000.nvdisplay: unblank
[ 596.523312] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 12. New remainder is 172. Failed at attempt 2
[ 596.537352] Switching i2c_ddc sclk rate: from 100000, to 50000
[ 596.576913] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 12. New remainder is 233. Failed at attempt 1
[ 596.590913] Switching i2c_ddc sclk rate: from 50000, to 25000
[ 596.649932] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 12. New remainder is 23. Failed at attempt 1
[ 596.663899] Switching i2c_ddc sclk rate: from 25000, to 12500
[ 596.774170] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 12. New remainder is 2. Failed at attempt 1
[ 596.788090] Switching i2c_ddc sclk rate: from 12500, to 6250
[ 596.996368] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 597.006832] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 597.017722] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 597.431719] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 597.441741] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 597.452699] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 597.864825] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 597.879142] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 597.890016] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 598.100423] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 598.110921] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 598.122315] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 598.535322] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 598.545723] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 598.556770] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 598.768274] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 598.778628] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 598.789823] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 599.202854] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 599.212783] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 599.223922] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 599.636178] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 599.650625] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 599.661475] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 599.872130] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 599.882029] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 599.893121] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 600.305715] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 154. Failed at attempt 1
[ 600.320049] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 600.330902] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 600.541516] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 600.551849] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 600.563188] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 600.976361] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 600.986764] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 600.998318] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 601.209814] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 601.220194] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 601.231576] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 601.645047] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 601.659258] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 601.670338] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 602.081798] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 183. New remainder is 151. Failed at attempt 1
[ 602.096073] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 602.106905] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 602.317202] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 602.326942] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 602.338351] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 602.751587] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 602.761872] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 602.773468] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 603.186062] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 603.196438] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 603.207604] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 603.620577] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 603.630885] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 603.642048] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 604.054361] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 604.064836] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 604.076258] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 604.488020] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 604.502223] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 604.513035] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 604.723443] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 604.733958] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 604.745522] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.158864] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.168867] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 605.180244] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.593238] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.603845] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 605.615856] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.827155] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 605.837555] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 605.848745] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 606.261307] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 606.275592] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 606.286443] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 606.496681] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 606.507386] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 606.521384] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 606.934028] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 154. Failed at attempt 1
[ 606.948517] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 606.959326] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 607.370859] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 607.380864] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 607.391805] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 607.603720] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 607.614033] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 607.625167] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 607.837035] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 607.847536] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 607.858771] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 608.270754] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 608.286876] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 608.297749] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 608.709503] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 608.719894] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 608.731235] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 608.942734] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 608.952896] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 608.963961] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.175354] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.185919] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 609.197121] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.610255] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.620692] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 609.631773] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.843080] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 609.852994] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 609.864294] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 610.277606] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 610.287997] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 610.299097] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 610.711652] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 610.721975] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 610.733456] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 611.146552] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 611.156917] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 611.168534] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 611.581563] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 611.595929] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 611.606874] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 611.817156] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 611.827523] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 611.838612] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.251509] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.262010] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 612.273046] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.484575] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.495138] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 612.506140] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.918790] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 612.928906] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 612.940248] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 613.355148] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 613.364786] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 613.380958] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 613.792281] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 613.806483] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 613.817272] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 614.231135] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 183. New remainder is 152. Failed at attempt 1
[ 614.251437] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 614.271354] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 614.688509] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 208. New remainder is 151. Failed at attempt 1
[ 614.702697] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 614.713468] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 614.925964] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 614.936221] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 614.947020] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.358639] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.368675] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 615.379597] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.592211] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.601767] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 615.612687] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.824743] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 615.835231] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 615.846064] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 616.263181] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 616.273414] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 616.284320] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 616.696910] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 616.707451] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 616.719040] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 617.133260] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 617.143639] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 617.155288] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 617.165652] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 617.171788] tegradc 15210000.nvdisplay: hdmi: using fallback edid
[ 617.178048] tegradc 15210000.nvdisplay: blank - powerdown
[ 617.183681] tegradc 15210000.nvdisplay: hdmi: plugged
[ 617.204292] tegradc 15210000.nvdisplay: blank - powerdown
[ 617.209816] tegradc 15210000.nvdisplay: unblank
[ 617.209838] PD DISP0 index2 UP
[ 617.211017] PD DISP1 index3 UP
[ 617.211126] PD DISP2 index4 UP
[ 617.213288] Parent Clock set for DC plld2
[ 617.215321] tegradc 15210000.nvdisplay: hdmi: pclk:74250K, set prod-setting:prod_c_75M
[ 617.664267] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 183. New remainder is 151. Failed at attempt 1
[ 617.664288] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 617.664289] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 617.664309] tegradc 15210000.nvdisplay: hdmi: tegra_edid_read_block(0) returned err -5
[ 617.664322] tegradc 15210000.nvdisplay: hdmi_recheck_edid: read_edid_into_buffer() returned -5
[ 617.664332] tegradc 15210000.nvdisplay: hdmi: unable to read EDID
[ 617.865284] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 617.868677] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 617.868833] tegradc 15210000.nvdisplay: hdmi: tegra_edid_read_block(0) returned err -5
[ 617.868845] tegradc 15210000.nvdisplay: hdmi_recheck_edid: read_edid_into_buffer() returned -5
[ 617.868855] tegradc 15210000.nvdisplay: hdmi: unable to read EDID
[ 617.937151] PD DISP2 index4 DOWN
[ 617.937582] PD DISP1 index3 DOWN
[ 617.937701] PD DISP0 index2 DOWN
[ 618.358831] tegradc 15210000.nvdisplay: blank - powerdown
[ 618.364293] tegradc 15210000.nvdisplay: unblank
[ 618.364328] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 618.364346] Switching i2c_ddc sclk rate: from 6250, to 100000
[ 618.369334] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 618.426292] tegradc 15210000.nvdisplay: blank - powerdown
[ 618.431732] tegradc 15210000.nvdisplay: unblank
[ 618.432352] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 618.443597] tegradc 15210000.nvdisplay: unblank
[ 618.497560] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 618.537636] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 44. New remainder is 235. Failed at attempt 1
[ 618.551784] Switching i2c_ddc sclk rate: from 100000, to 50000
[ 618.586607] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 44. New remainder is 188. Failed at attempt 1
[ 618.600924] Switching i2c_ddc sclk rate: from 50000, to 25000
[ 618.662497] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 44. New remainder is 216. Failed at attempt 1
[ 618.676621] Switching i2c_ddc sclk rate: from 25000, to 12500
[ 618.785028] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 44. New remainder is 2. Failed at attempt 1
[ 618.799099] Switching i2c_ddc sclk rate: from 12500, to 6250
[ 619.005827] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 44. New remainder is 216. Failed at attempt 1
[ 619.019869] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 619.030663] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 619.241122] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 619.251613] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 619.262588] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 619.675573] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 619.685758] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 619.696909] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.109586] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.119950] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 620.131047] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.342632] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.352656] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 620.363879] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.577002] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 620.587376] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 620.598841] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.011466] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.021861] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 621.033015] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.244986] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.255490] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 621.266486] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.477780] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.488167] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 621.499237] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.912151] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 621.922616] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 621.934802] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 622.347108] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 622.361260] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 622.371995] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 622.583959] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 622.593519] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 622.604334] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 623.019113] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 623.029558] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 623.052497] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 623.463977] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 623.478344] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 623.489147] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 623.902155] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 623.912459] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 623.923029] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 624.336429] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 624.350685] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 624.361480] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 624.573192] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 624.583422] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 624.594197] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 624.807495] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 624.817443] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 624.830111] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.043230] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.052854] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 625.063873] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.481731] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.491954] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 625.505605] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.717439] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 625.727658] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 625.738515] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 626.150267] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 626.164386] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 626.175116] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 626.586048] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 626.596456] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 626.608380] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 627.022548] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 627.036700] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 627.047445] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 627.458564] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 627.468463] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 627.480223] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 627.892514] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 627.902651] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 627.913316] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 628.124776] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 628.134761] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 628.145663] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 628.558292] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 628.568340] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 628.578993] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 628.990290] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 629.004438] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 629.015272] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 629.426599] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 629.436319] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 629.449557] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 629.860688] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 629.875036] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 629.885830] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 629.903155] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.922509] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.937473] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.954002] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.968788] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.983644] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 629.998043] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.012914] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.027844] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.041996] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.056857] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.071705] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.085947] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.101124] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.115925] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.130702] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.145477] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.160299] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.175184] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.190024] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.204843] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.225004] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.253194] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.269996] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.284830] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.299718] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.313993] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.328327] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.343111] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.357965] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.373153] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.387953] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.402829] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.417618] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.432412] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.447234] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.461994] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.476845] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.491783] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.505932] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.520730] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.535541] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.549985] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 630.558369] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 630.564281] tegradc 15210000.nvdisplay: hdmi: using fallback edid
[ 630.570410] tegradc 15210000.nvdisplay: blank - powerdown
[ 630.575893] tegradc 15210000.nvdisplay: hdmi: plugged
[ 630.581005] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 630.591229] tegradc 15210000.nvdisplay: blank - powerdown
[ 630.596667] tegradc 15210000.nvdisplay: unblank
[ 630.601282] tegradc 15210000.nvdisplay: unblank
[ 630.644182] tegradc 15210000.nvdisplay: blank - powerdown
[ 630.649610] tegradc 15210000.nvdisplay: unblank
[ 630.654177] tegradc 15210000.nvdisplay: unblank
[ 637.530770] Switching i2c_ddc sclk rate: from 6250, to 100000
[ 637.587271] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 195. New remainder is 206. Failed at attempt 1
[ 637.601461] Switching i2c_ddc sclk rate: from 100000, to 50000
[ 637.641594] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 195. New remainder is 191. Failed at attempt 1
[ 637.655690] Switching i2c_ddc sclk rate: from 50000, to 25000
[ 637.714676] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 195. New remainder is 91. Failed at attempt 1
[ 637.728781] Switching i2c_ddc sclk rate: from 25000, to 12500
[ 637.839983] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 195. New remainder is 165. Failed at attempt 1
[ 637.854197] Switching i2c_ddc sclk rate: from 12500, to 6250
[ 638.062207] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 638.072175] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 638.083067] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 640.090697] tegra-i2c 3190000.i2c: timed out for bus clear
[ 640.101485] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 640.513581] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 640.523891] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 640.535249] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 640.746086] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 640.756084] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 640.767467] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 641.179405] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 641.189114] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 641.200150] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 641.612076] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 641.634709] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 641.658664] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 642.083008] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 216. New remainder is 154. Failed at attempt 1
[ 642.097169] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 642.107909] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 642.525811] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 183. New remainder is 151. Failed at attempt 1
[ 642.553018] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 642.563712] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 642.974796] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 642.984839] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 642.996941] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 643.209671] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 643.219832] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 643.230410] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 643.641373] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 643.655552] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 643.666317] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 644.079719] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 208. New remainder is 151. Failed at attempt 1
[ 644.093832] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 644.104543] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 644.515589] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 644.525938] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 644.536996] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 644.950953] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 158. Failed at attempt 1
[ 644.970844] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 644.981596] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 645.392183] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 210. New remainder is 151. Failed at attempt 1
[ 645.406430] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 645.417213] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 645.827767] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 208. New remainder is 151. Failed at attempt 1
[ 645.841930] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 645.852688] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 646.062732] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 646.073031] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 646.084169] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 646.308377] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.323311] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.337683] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.352496] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.367338] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.386867] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.402266] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.417400] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.436196] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.451063] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.465716] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.480522] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.495331] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.510340] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.525194] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.540017] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.554848] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.570122] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.584999] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.599790] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.614673] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.629522] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.644323] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.659205] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.673589] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.688392] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.703199] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.717897] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.732716] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.747545] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.762322] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.776994] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.791801] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.806903] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.821881] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.835998] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.850822] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.865723] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.880515] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.895289] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.909559] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.924325] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.939484] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.953601] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.968395] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.983224] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 646.997646] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.012486] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.027469] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.041638] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.056390] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.071168] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.085594] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.100391] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.115680] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.130539] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.145390] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.160256] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.175197] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.189923] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.204935] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.219734] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.234537] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.249429] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.264390] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.279318] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.293686] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.308516] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.325614] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.340769] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.356086] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.370897] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.385709] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.400552] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.415427] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 647.423270] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 647.429246] tegradc 15210000.nvdisplay: hdmi: using fallback edid
[ 647.435401] tegradc 15210000.nvdisplay: blank - powerdown
[ 647.440920] tegradc 15210000.nvdisplay: hdmi: plugged
[ 647.446090] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 647.455665] tegradc 15210000.nvdisplay: blank - powerdown
[ 647.461137] tegradc 15210000.nvdisplay: unblank
[ 647.465742] tegradc 15210000.nvdisplay: unblank
[ 647.509254] tegradc 15210000.nvdisplay: blank - powerdown
[ 647.514750] tegradc 15210000.nvdisplay: unblank
[ 647.519316] tegradc 15210000.nvdisplay: unblank
[ 652.514513] Switching i2c_ddc sclk rate: from 6250, to 100000
[ 652.525523] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 652.565845] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 652.572843] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 652.585186] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 654.590453] tegra-i2c 3190000.i2c: timed out for bus clear
[ 654.600379] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 654.641077] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 75. New remainder is 221. Failed at attempt 1
[ 654.655286] Switching i2c_ddc sclk rate: from 100000, to 50000
[ 654.693168] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 75. New remainder is 174. Failed at attempt 1
[ 654.707262] Switching i2c_ddc sclk rate: from 50000, to 25000
[ 654.766742] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 75. New remainder is 213. Failed at attempt 1
[ 654.780796] Switching i2c_ddc sclk rate: from 25000, to 12500
[ 654.893254] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 75. New remainder is 252. Failed at attempt 1
[ 654.907390] Switching i2c_ddc sclk rate: from 12500, to 6250
[ 655.114368] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 655.124630] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 655.135498] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 655.548609] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 655.558862] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 655.571900] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 655.983742] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 655.993996] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 656.005000] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 656.417647] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 656.427753] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 656.438374] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 656.850242] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 656.859782] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 656.870655] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 657.283011] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 657.292807] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 657.303438] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 657.714879] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 152. Failed at attempt 1
[ 657.729089] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 657.739898] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 658.352293] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 154. New remainder is 151. Failed at attempt 2
[ 658.366498] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 658.377387] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 658.587954] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 658.598293] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 658.609451] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.022886] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.032876] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 659.044470] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.457131] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.467796] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 659.479589] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.892246] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 659.902645] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 659.913739] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.125628] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.135777] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 660.146925] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.559641] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.570016] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 660.581447] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.793202] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 660.803607] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 660.815087] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.227622] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.237991] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 661.249668] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.461709] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.471766] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 661.483086] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.896762] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 661.907405] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 661.918743] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.130236] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.140659] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 662.151828] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.363516] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.374027] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 662.385219] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.798442] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 662.808765] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 662.820176] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 663.232522] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 663.246952] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 663.258376] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 663.669854] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 663.680461] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 663.691730] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.104979] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.115249] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 664.126501] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.539196] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.549511] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 664.560609] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.772666] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 664.782962] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 664.793960] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 665.205540] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 665.219782] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 665.230638] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 665.642099] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 665.652490] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 665.664026] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 665.875517] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 666.297259] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 666.307483] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 666.318381] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 666.730573] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous remainder was 130. New remainder is 151. Failed at attempt 1
[ 666.745392] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maximum rate:4000000
[ 666.756145] Cannot halve i2c speed givingup on trying to change the i2c speed for EDID read
[ 666.970662] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 666.980613] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 666.991254] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 667.403796] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 667.414038] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 667.425091] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.042685] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.052959] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 668.064318] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.477477] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.487629] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 668.498937] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.911093] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 668.921417] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 668.932784] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 669.345807] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 669.355631] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 669.367230] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 669.780119] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 669.790495] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 669.801572] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.214251] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.224788] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 670.235945] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.447872] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.458508] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 670.469808] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.882998] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 670.892633] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 670.903584] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 671.315724] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 671.327569] tegra-i2c 3190000.i2c: Un-recovered Arb lost
[ 671.340624] tegra-i2c 3190000.i2c: arb lost in communicate to add 0x50
[ 671.752021] tegra_edid_read_block: checksum failed and did not match consecutive reads. Previous
The HDMI port on a different Jetson TX2 with exactly the same configuration is working absolutly fine. So can someone take a look on the dmesg log above? Is it possible that the HDMI port is broken?
