Hi @all,
I tried to connect an ultra sonic sensor to my jetson nano via I2C connection.
I followed this tutorial to build up the sensor: Ultrasonic Sensor for the Jetbot - thestrongestlink
The sensor worked fine at the IDE Arduino and give me the right response to the distance. So the next step was to connect the sensor to the jetson but it faild when I tried to run the code.
So I checked with sudo i2cdetect -r -y 1
if some device is detected but without any result.
I already checked the wiring. I have right connection between my pins and my sensor and also voltage at both pins (3&5)
Now I dont know what to do next or where my mistake could be. Does anyone has an idea?
Here is a picture of my wiring. I hope evyerthing is clear to see.
