No image on monitor during running nvsipl_camera based application
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I’m working on the nvsiple_camera based application and slightly modified the example code under ../nvmedia/nvsipl/test/camera/main.cpp.
As I run the application as host client, it has it’s own executable and the excutable triggers the Init function which was main function in main.cpp.
(before)
int main(int argc, char *argv)
(after)
int PhantomSipl::Init(CCmdLineParser& params)
In this implementation, it worked well with the AR0820 camera which is connected to a1 port. I was able to see the images from ISP0,1,2 on the monitor.
Then, I changed the code again to add a callback function into the Init function in main.cpp
(before)
(After)
int PhantomSipl::Init(CCmdLineParser& params, std::function<void(NvSciBufObj* buffer)> callback_fnptr)
And modified CNvSIPLConsumer.hpp to insert the code below in OnFrameAvailable function.
(right above auto status = m_pComposite->Post(m_uID, pNvMBuffer);)
    if (m_pUserFunction != nullptr) {
      NvSciBufObj buffer = pNvMBuffer->GetNvSciBufImage();
      m_pUserFunction(m_uID, &buffer);
After this chage, I can see that the callback is hooked properly even it returns without any operation, but suddenly none of images on the monitor.
Can you help me out to figure out what makes the image on the monitor disappeared?
Dear @wooseok.won,
Is it possible to share repro code?
Dear @SivaRamaKrishnaNV, please find the attached file.
It contains the nvsipl_camera example code for “before” and “after”
nvsipl_camera.tar.gz (19.9 KB)
It’s resolved by put upComposite.get() into the 1st argument in CNvSIPLConsumer’s Init.
            status = upCons->Init(upComposite.get(),
                                  nullptr,
                                  callback_fnptr,
                                  uID,
                                  uSensor,
                                  eOutput,
                                  pProfiler,
                                  pFrameFeeder,
                                  cmdline_.sFiledumpPrefix,
                                  cmdline_.uNumSkipFrames,
                                  cmdline_.uNumWriteFrames);
the application implementation was
            status = upCons->Init(nullptr,
                                  nullptr,
                                  callback_fnptr,
                                  uID,
                                  uSensor,
                                  eOutput,
                                  pProfiler,
                                  pFrameFeeder,
Can you please explain briefly about the mechanism how the code change(upComposite.get()) makes displaying images?
Hi @SivaRamaKrishnaNV, can you please follow up this ticket?
