yes it does.
static_fields.h:
template <typename T> struct vec3 { typedef float Type; }; // dummy
template <> struct vec3<float> { typedef float3 Type; };
template <> struct vec3<double> { typedef double3 Type; };
template <typename T> struct vec4 { typedef float Type; }; // dummy
template <> struct vec4<float> { typedef float4 Type; };
template <> struct vec4<double> { typedef double4 Type; };
#define T3 typename vec3<T>::Type
#define T4 typename vec4<T>::Type
__device__ T4 apply_static_fields(T4 accel, T4 pos, T4 vel); // <---see, the definition with that arg list is right here!
(the code).cu:
#include "static fields.h"
template<typename T, bool multithreadBodies>
__global__ void
integrateBodies(T4* newPos,
T4* oldPos,
T4* vel,
float deltaTime, float damping, int numBodies) {
T4 position = oldPos[index];
T4 velocity = vel[index];
T4 accel = {0.0f,0.0f,0.0f,0.0f};
if (!multithreadBodies || (threadIdx.y == 0)) {
accel = apply_static_fields( accel, position, velocity); // <--this is the line that the "error" is on.
__device__ T4 apply_static_fields(T4 accel, T4 pos, T4 vel) { // <--and here is the actual function!
accel.w = 0;
what gives?
yes it does.
static_fields.h:
(the code).cu:
__global__ void
T4* oldPos,
T4* vel,
accel.w = 0;
what gives?
figured it out.
should be
accel = apply_static_fields<T>( accel, position, velocity); // <--this is the line that the "error" is on.
figured it out.
should be
