No Language Selection button
Hi.
Recently, I installed jetpack 5.1 to Jetson Xavier NX using sd card method.
Everything seems okay, except that language selection buttion is disappeared.
When I used jetpack 4.5.1 or 4.6.1, I could find language selection button(En usually) at the top right of the screen. But I can’t find it now.
I also tried to change input language. I tried to install Korean, but when I enter to language settings, korean is disabled.
Without this, everything seems okay. Could you tell me what is the problem and how to fix it?
Please try the steps and see if you can change system language:
https://linuxconfig.org/change-system-language-on-ubuntu-20-04-from-command-line
