Dear @mark158,
What does the logs indicates, Flashing Tegra A is successful or failed?
i didn’t check the logs
i have flashed tegra A+B and got notification from sdk manager finished successfully.
i can flash only tegra A and check the status
i flashed tegra A only via sdk manager and it finished successfully
but still i have no access to it.
i have no ping to tegra A from tegra B
also no response from minicom
SDKM_logs_DRIVE_OS_5.2.6_SDK_Linux_for_DRIVE_AGX_Xavier_2022-09-13_15-18-34.zip (209.7 KB)
logs from sdk manager attached
Dear @yoav10,
I can see in log that, Flashing Tegra A is successful. Could you check pinging 10.42.0.28 from Tegra B again and confirm? Just to confirm no issue with ssh on Tegra B, please check accessing any other machine in network from Tegra B. Also, check if the Aurix verison is still DRIVE-V5.1.6-E3550-EB-Aurix-With3LSS-ForHyperion-StepA-3.05.04
Dear @yoav10,
Also, you may check flashing DRIVE SW 10.0/DRIVE OS 5.2.0 on target to see if any display is coming up after Tegra boot.
@yoav10 @adi4 @mark158 have you tried flashing back DRIVE Software 10 @SivaRamaKrishnaNV suggested? Does it solve the Xavier A access issue?
