hyeyum1
November 13, 2024, 6:37am
1
Hello
I followed the link above as it is.
However, after entering the container, I entered the command below and the phrase ‘/usr/local/bin/python3: No module named nanodb’ appeared. Can’t I run the nanodb tutorial?
jetson-containers run $(autotag nanodb)
python3 -m nanodb
–path /data/nanodb/coco/2017
–server --port=7860
hyeyum1
December 4, 2024, 10:26am
3
I didn’t solve it. I’m sorry I couldn’t help you
lazziya
December 4, 2024, 12:05pm
4
I used IMAGE ID instead of $(autotag nanodb)
jetson-containers run 8118ef4e5cab
You can get the IMAGE ID via running sudo docker image ls
I use dustynv/nanodb:r36.2.0
image btw.
You can find it here GitHub
Thank you for your help. I’ll do it if I have time.:)
I also get the same error message when trying to start the Gradio server:
Due to this install.sh script failing:
git clone GitHub - dusty-nv/jetson-containers: Machine Learning Containers for NVIDIA Jetson and JetPack-L4T
bash jetson-containers/install.sh
with this error message:
ubprocess.CalledProcessError: Command ‘sudo DOCKER_BUILDKIT=0 docker build --network=host --tag nanodb:r36.4.2-python --file /home/ken/jetson-containers/packages/build/python/Dockerfile --build-arg BASE_IMAGE=nanodb:r36.4.2-cudnn_9.4 --build-arg PYTHON_VERSION_ARG=“3.10” /home/ken/jetson-containers/packages/build/python 2>&1 | tee /home/ken/jetson-containers/logs/20250108_082057/build/nanodb_r36.4.2-python.txt; exit ${PIPESTATUS[0]}’ returned non-zero exit status 127.
nanodb_r36.4.2-python.txt (7.8 KB)
‘sudo docker image ls’ shows an incomplete installation:
REPOSITORY TAG IMAGE ID CREATED SIZE
<none> <none> fb4900030dde 16 hours ago 6.91GB
nanodb r36.4.2-cudnn_9.4 4d73a710a23c 16 hours ago 6.91GB
nanodb r36.4.2-cuda_12.6 57f6b38b7dd0 16 hours ago 5.91GB
nanodb r36.4.2-pip_cache_cu126 efca951b50f6 16 hours ago 723MB
nanodb r36.4.2-build-essential be8f81cd8a0f 16 hours ago 723MB
ubuntu 22.04 981912c48e9a 3 months ago 69.2MB
dustynv/nanodb r36.2.0 8118ef4e5cab 10 months ago 16GB
Hi All,
It seems like the best way to get help and a fix for this is by raising an issue on GitHub - dusty-nv/jetson-containers: Machine Learning Containers for NVIDIA Jetson and JetPack-L4T . The team there are really responsive. Hope this helps.
Hi @kenluebbert , apologies everyone for not seeing this thread earlier - the latest container image for this is here: dustynv/nanodb:r36.4.0
When using the r36.4.0 container pulled from:
https://hub.docker.com/r/dustynv/nanodb/tags
There is an issue with the r36.4.0 indexing process where the validation step returns a warning for each image being validated:
22:15:22 | WARNING | incorrect or duplicate index [9999] indexes=[-1 -1 -1 -1 -1 -1 -1 -1] distances=[-3.4028235e+38 -3.4028235e+38 -3.4028235e+38 -3.4028235e+38
-3.4028235e+38 -3.4028235e+38 -3.4028235e+38 -3.4028235e+38]
Search queries using this index return an incorrect list of images all with similarity values of 0.0237
using the r36.2.0 container also pulled from:
results an indexing process that runs 4x faster (than r36.4.0) and generates an index that is validated with few warnings or errors. The index query results are correct.
similar to my comparison of r36.4.2 to r36.2.0 indexing at the tail end of:
About the performance, do you run the identical test for the r36.2.0 and r36.4.2 containers?
Yes, the tests were identical, and run on the same jetson orin nano.
I decided to test again from the beginning by flashing with sdkmanager, and then building r36.4.0 (instead of pulling the container from the hub ) and got the same results.
piter24
January 21, 2025, 1:35am
11
Hi were you able to solve it for 36.4.0? I am running dustynv/nanodb:r36.4.0 and I am getting the same error. search queries return incorrect result.
My test of r36.4.0 continues to return an invalid index and runs 4x slower than r36.2.0 (which returns a valid index).
piter24
January 21, 2025, 3:50am
13
I noticed this too, Have you tried using the ViT-L/14@336 in the 36.4.0 ?
I would recommend pulling r36.2.0 container from:
and lookup the (image id of nanodb) using:
and then run the image for r36.2.0 using
jetson-containers run (image id of nanodb)
These steps will allow you to test nanodb functionality without waiting for the issues with r36.4.0 to be resolved.
piter24
January 21, 2025, 4:36pm
16
running [dustynv/nanodb:r36.2.0] in r36.4.0 sometimes gives Segmentation fault (core dumped), other times it works… uses 100% of cpu resources (check jtop).
Also sometimes I am unable to download ‘ViT-L/14@336px’ model. I get checksum error after download.
Most likely is because the L4T version mismatch.
piter24
January 21, 2025, 5:26pm
17
