I’m new to Isaaac. I try to import parse_env_cfg by from omni.isaac.lab_tasks.utils import parse_env_cfg
. However, I get No module named ‘omni.isaac.core’
. Here is the full error:
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/__init__.py", line 25, in <module>
from .utils import import_packages
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/__init__.py", line 9, in <module>
from .parse_cfg import get_checkpoint_path, load_cfg_from_registry, parse_env_cfg
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/parse_cfg.py", line 16, in <module>
from omni.isaac.lab.envs import DirectRLEnvCfg, ManagerBasedRLEnvCfg
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/__init__.py", line 45, in <module>
from . import mdp, ui
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/mdp/__init__.py", line 18, in <module>
from .actions import * # noqa: F401, F403
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/mdp/actions/__init__.py", line 8, in <module>
from .actions_cfg import *
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/mdp/actions/actions_cfg.py", line 9, in <module>
from omni.isaac.lab.managers.action_manager import ActionTerm, ActionTermCfg
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/managers/__init__.py", line 13, in <module>
from .action_manager import ActionManager, ActionTerm
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/managers/action_manager.py", line 20, in <module>
from omni.isaac.lab.assets import AssetBase
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/__init__.py", line 41, in <module>
from .articulation import Articulation, ArticulationCfg, ArticulationData
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/__init__.py", line 8, in <module>
File "/home/uchi/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py", line 17, in <module>
import omni.isaac.core.utils.stage as stage_utils
ModuleNotFoundError: No module named 'omni.isaac.core'
I’m not sure how I’m getting this error if I install it correctly. I also from isaacsim import SimulationApp
and simulation_app = SimulationApp({"headless": True})
before env_cfg = parse_env_cfg(env_name, use_gpu=True, num_envs=num_envs)
Does anyone have any idea how to debug it?
