I’m trying to follow along with the “Interface Problem by Variational Method” example, but when I try to use quadpy with:
quad_rec = Quad_Collection(Quad_Rect, paras)
I run into the error :
ModuleNotFoundError: No module named 'quadpy.cn._helpers'
with the traceback showing:
File /usr/local/lib/python3.8/dist-packages/modulus/sym/utils/vpinn/integral.py:156, in Quad_Rect.__init__(self, v, n, region_type, scheme_fcn)
155 def __init__(self, v, n, region_type=True, scheme_fcn=qd.c2.get_good_scheme):
--> 156 from quadpy.cn._helpers import transform, get_det
Has this been encountered before? Is it an issue with newer versions of quadpy?
