No network and display: Jetson TX2 NX on Nano Developer Kit Carrier
Hi there,
I managed to flash my device such that it boots up and I can log in via tty over USB. However, the network connection to the router is not detected, no IP address is picked up. Furthermore, the display doesn’t receive any signal, neither via HDMI nor via DP. Mouse and keyboard are connected. Any ideas?
Thanks and kind regards
You should post a serial console log which is from initial power on all the way through complete boot. Also, making sure the display is connected, post a copy of the “/var/log/Xorg.0.log”.
