• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version6.0
• TensorRT Version8.0.1
I am trying to infer an image(1frame) using deepstream-app
with pgie + sgie
and output to a msgbroker
. The pipeline is able to run successfully and the msgbroker
is able to output the meta data infer from the pgie
but the msgbroker
did not have the output infer from the sgie
. When i check the process flow, i noticed the msgconv
start to process the message after the frame has done processing and did not wait for the object processing to be done in sgie
. Therefore, receiving output without the meta data from sgie
in the msgbroker
