No output on I2S5 with APE driver on JetPack 35.3.1
If you still see an issue; Could you please read the PINMUX registers? the values should be as below.
pinmux.0x02431020 = 0x00000408; # aud_mclk_ps4: aud, pull-up, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431080 = 0x00000444; # dap5_sclk_pt5: i2s5, pull-down, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431078 = 0x00000404; # dap5_dout_pt6: i2s5, pull-down, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431070 = 0x00000454; # dap5_din_pt7: i2s5, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x02431068 = 0x00000444; # dap5_fs_pu0: i2s5, pull-down, tristate-disable, input-enable, lpdr-disable
You can also refer:
