this is my situation:
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.1d3
I pull the nvidia docker: nvcr.io/nvidia/deepstream:5.0.1-20.09-triton in nvidia V100
cd /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app
export DISPLAY=":0"
deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
then it prints:
No protocol specified
** ERROR: <main:655>: Failed to set pipeline to PAUSED
Quitting
App run failed
then i run xrandr
it prints:
Can't open display :0
how can i fix this problem?
Amycao
January 5, 2022, 8:36am
3
Same issue with this topic.
DeepStreamSDK 5.0.0
cuDNN Version: 7.6
I run in nvidia docker: nvcr.io/nvidia/deepstream:5.0.1-20.09-triton in nvidia V100
this is the code:
cd /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app
deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
then it prints:
** ERROR: main:655 : Failed to set pipeline to PAUSED
Q…
it works on the morning, but i don’t know why this problem comes again afternoon and can you see the way to fix it from the result of xrandr?
Amycao
January 5, 2022, 9:19am
5
Please try export DISPLAY=“:0” before run the docker. and add option when run docker, -e DISPLAY=$DISPLAY
system
Closed
January 25, 2022, 3:12am
7
