no reply from camera processor, lvds to mipi sensor
I have ported few sensors from an older version of L4T for TX2 and Xavier to newer version L4T-32.2.
I have a problem with IMX264 (LVDS interface converted to MIPI on Crosslink with Lattice IP). This configuration is working on TX2 but not on Xavier.
port binding test result:
Media device information
driver          tegra194-vi5
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  0.0.0
Device topology
- entity 1: imx264 30-001a (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev0
	pad0: Source
		[fmt:SRGGB12_1X12/2448x2056 field:none colorspace:srgb]
		-> "15a00000.nvcsi--1":0 [ENABLED]
- entity 3: 15a00000.nvcsi--1 (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev1
	pad0: Sink
		<- "imx264 30-001a":0 [ENABLED]
	pad1: Source
		-> "vi-output, imx264 30-001a":0 [ENABLED]
- entity 6: vi-output, imx264 30-001a (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
	pad0: Sink
		<- "15a00000.nvcsi--1":1 [ENABLED]
Dmesg error code running qv4l2:
[   88.565052] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[   93.616862] tegra194-vi5 15c10000.vi: no reply from camera processor
[   93.617011] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
[   93.617193] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[   93.620024] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[   98.740752] tegra194-vi5 15c10000.vi: no reply from camera processor
[   98.740904] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 5000 ms
[   98.741089] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[   98.741265] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[   98.741420] video4linux video0: vi capture release failed
[   98.741520] tegra194-vi5 15c10000.vi: fatal: error recovery failed
At first, I had errors on TX2 but longer timeout value in vi4 driver did the trick. I assumed the same thing is for vi5 driver but it did not resolve errors. Also, with negative value on timeout (wait indefinitely) I couldn’t get any frame. Indefinite wait on argus also nothing.
I have checked mipi lines over oscilloscope and sensor is outputting frames witch is expected (same HW conf, same driver, working on TX2).
I’ve tried with max clock on vi and nvcsi, same result. Also tried on L4T-32.2.1, nothing.
Do you have any suggestion what else could I try to resolve this problem? Any input is appreciated.
Did you check the trace log?
did not.
is there any documentation explaining the tag and data info from trace log? I couldn’t find anything in TRM.
Could you please explain the log?
root@nvidia-desktop:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 165/165   #P:8
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:2-1307  [000] ....   200.152957: rtos_queue_peek_from_isr_failed: tstamp:6488059478 queue:0x0bcbcf78
     kworker/0:2-1307  [000] ....   200.320814: rtos_queue_peek_from_isr_failed: tstamp:6493059460 queue:0x0bcbcf78
     kworker/0:2-1307  [000] ....   200.488783: rtos_queue_peek_from_isr_failed: tstamp:6498059485 queue:0x0bcbcf78
     kworker/0:2-1307  [000] ....   200.544864: rtos_queue_peek_from_isr_failed: tstamp:6499567794 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   257.315520: rtos_queue_send_from_isr_failed: tstamp:8274637297 queue:0x0bcb41f8
     kworker/0:5-1939  [000] ....   257.315527: rtos_queue_send_from_isr_failed: tstamp:8274639784 queue:0x0bcb8a60
     kworker/0:5-1939  [000] ....   257.315529: rtos_queue_send_from_isr_failed: tstamp:8274642258 queue:0x0bcba5e0
     kworker/0:5-1939  [000] ....   257.315530: rtos_queue_send_from_isr_failed: tstamp:8274644693 queue:0x0bcbb3a0
     kworker/0:5-1939  [000] ....   257.315532: rtos_queue_send_from_isr_failed: tstamp:8274647128 queue:0x0bcbc160
     kworker/0:5-1939  [000] ....   257.315535: rtcpu_nvcsi_intr: tstamp:8274671431 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
     kworker/0:5-1939  [000] ....   257.315536: rtcpu_nvcsi_intr: tstamp:8274671431 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/0:5-1939  [000] ....   257.483538: rtos_queue_peek_from_isr_failed: tstamp:8279443505 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   257.483546: rtcpu_start: tstamp:8279445256
     kworker/0:5-1939  [000] ....   257.483549: rtos_queue_send_from_isr_failed: tstamp:8279466002 queue:0x0bcb41f8
     kworker/0:5-1939  [000] ....   257.483550: rtos_queue_send_from_isr_failed: tstamp:8279466151 queue:0x0bcb8a60
     kworker/0:5-1939  [000] ....   257.483551: rtos_queue_send_from_isr_failed: tstamp:8279466322 queue:0x0bcba5e0
     kworker/0:5-1939  [000] ....   257.483553: rtos_queue_send_from_isr_failed: tstamp:8279466469 queue:0x0bcbb3a0
     kworker/0:5-1939  [000] ....   257.483554: rtos_queue_send_from_isr_failed: tstamp:8279466615 queue:0x0bcbc160
     kworker/0:5-1939  [000] ....   257.483557: rtcpu_string: tstamp:8279467061 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:5-1939  [000] ....   257.483601: rtcpu_string: tstamp:8279467239 id:0x04010000 str:"VM GOS[#0] addr=0xe4900000
     kworker/0:5-1939  [000] ....   257.483618: rtcpu_string: tstamp:8279467514 id:0x04010000 str:"VM GOS[#1] addr=0xe4901000
     kworker/0:5-1939  [000] ....   257.483634: rtcpu_string: tstamp:8279467782 id:0x04010000 str:"VM GOS[#2] addr=0xe4902000
     kworker/0:5-1939  [000] ....   257.483648: rtcpu_string: tstamp:8279468014 id:0x04010000 str:"VM GOS[#3] addr=0xe4903000
     kworker/0:5-1939  [000] ....   257.483660: rtcpu_string: tstamp:8279468263 id:0x04010000 str:"VM GOS[#4] addr=0xe4904000
     kworker/0:5-1939  [000] ....   257.483674: rtcpu_string: tstamp:8279468495 id:0x04010000 str:"VM GOS[#5] addr=0xe4905000
     kworker/0:5-1939  [000] ....   257.483688: rtcpu_string: tstamp:8279484058 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
     kworker/0:5-1939  [000] ....   257.483692: rtcpu_string: tstamp:8279484210 id:0x04010000 str:"on 2.2
     kworker/0:5-1939  [000] ....   257.483706: rtos_queue_send_from_isr_failed: tstamp:8279506707 queue:0x0bcb41f8
     kworker/0:5-1939  [000] ....   257.483708: rtos_queue_send_from_isr_failed: tstamp:8279506877 queue:0x0bcb8a60
     kworker/0:5-1939  [000] ....   257.483709: rtos_queue_send_from_isr_failed: tstamp:8279507030 queue:0x0bcba5e0
     kworker/0:5-1939  [000] ....   257.483710: rtos_queue_send_from_isr_failed: tstamp:8279507175 queue:0x0bcbb3a0
     kworker/0:5-1939  [000] ....   257.483712: rtos_queue_send_from_isr_failed: tstamp:8279507323 queue:0x0bcbc160
     kworker/0:5-1939  [000] ....   257.483713: rtcpu_string: tstamp:8279508254 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xe4904000
     kworker/0:5-1939  [000] ....   257.483726: rtcpu_vinotify_error: tstamp:8279513263 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:8279509076 data:0x00000001
     kworker/0:5-1939  [000] ....   257.483737: rtcpu_vinotify_event: tstamp:8280028521 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:8279509076 data:0x00000001
     kworker/0:5-1939  [000] ....   257.483739: rtcpu_vinotify_event: tstamp:8280028669 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7246436704 data:0x10000000
     kworker/0:5-1939  [000] ....   257.483740: rtcpu_vinotify_event: tstamp:8280028835 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7246469568 data:0x31000001
     kworker/0:5-1939  [000] ....   257.483742: rtcpu_vinotify_event: tstamp:8280028974 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7246479712 data:0x10000000
     kworker/0:5-1939  [000] ....   257.483743: rtcpu_vinotify_event: tstamp:8280029131 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:7246488288 data:0x07020001
     kworker/0:5-1939  [000] ....   257.483744: rtcpu_vinotify_event: tstamp:8280029266 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:7246518784 data:0x31000002
     kworker/0:5-1939  [000] ....   257.651538: rtos_queue_peek_from_isr_failed: tstamp:8284443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   257.819488: rtos_queue_peek_from_isr_failed: tstamp:8289443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   257.987482: rtos_queue_peek_from_isr_failed: tstamp:8294443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.099471: rtos_queue_peek_from_isr_failed: tstamp:8299443903 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.155475: rtcpu_vinotify_event: tstamp:8300645019 tag:FS channel:0x00 frame:2 vi_tstamp:8300188809 data:0x00000010
     kworker/0:5-1939  [000] ....   258.155478: rtcpu_vinotify_event: tstamp:8300645164 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:8300188812 data:0x00000000
     kworker/0:5-1939  [000] ....   258.155480: rtcpu_vinotify_event: tstamp:8300645346 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:8300193425 data:0x00000001
     kworker/0:5-1939  [000] ....   258.155482: rtcpu_vinotify_event: tstamp:8300645485 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:7908156096 data:0x08020001
     kworker/0:5-1939  [000] ....   258.155484: rtcpu_vinotify_event: tstamp:8301188088 tag:CHANSEL_PXL_EOF channel:0x23 frame:2 vi_tstamp:8301055194 data:0x08070002
     kworker/0:5-1939  [000] ....   258.155485: rtcpu_vinotify_event: tstamp:8301188227 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:8301055217 data:0x00000000
     kworker/0:5-1939  [000] ....   258.155486: rtcpu_vinotify_event: tstamp:8301188403 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:7935736352 data:0x02020001
     kworker/0:5-1939  [000] ....   258.155488: rtcpu_vinotify_event: tstamp:8301188541 tag:FE channel:0x00 frame:2 vi_tstamp:8301055225 data:0x00000020
     kworker/0:5-1939  [000] ....   258.155490: rtcpu_vinotify_event: tstamp:8301188699 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8301055228 data:0x00000000
     kworker/0:5-1939  [000] ....   258.267445: rtos_queue_peek_from_isr_failed: tstamp:8304443861 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.435420: rtos_queue_peek_from_isr_failed: tstamp:8309443904 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.603436: rtos_queue_peek_from_isr_failed: tstamp:8314443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.771411: rtos_queue_peek_from_isr_failed: tstamp:8319443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   258.827408: rtcpu_vinotify_event: tstamp:8321023590 tag:FS channel:0x00 frame:1 vi_tstamp:8321020924 data:0x00000010
     kworker/0:5-1939  [000] ....   258.827414: rtcpu_vinotify_event: tstamp:8321532889 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:8321020927 data:0x00000000
     kworker/0:5-1939  [000] ....   258.827415: rtcpu_vinotify_event: tstamp:8321533030 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:8321025540 data:0x00000001
     kworker/0:5-1939  [000] ....   258.827417: rtcpu_vinotify_event: tstamp:8321533192 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:8574783744 data:0x08020001
     kworker/0:5-1939  [000] ....   258.827418: rtcpu_vinotify_event: tstamp:8322075954 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:8321887309 data:0x08070002
     kworker/0:5-1939  [000] ....   258.827419: rtcpu_vinotify_event: tstamp:8322076115 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:8321887334 data:0x00000000
     kworker/0:5-1939  [000] ....   258.827421: rtcpu_vinotify_event: tstamp:8322076255 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:8602364032 data:0x02020001
     kworker/0:5-1939  [000] ....   258.827422: rtcpu_vinotify_event: tstamp:8322076413 tag:FE channel:0x00 frame:1 vi_tstamp:8321887340 data:0x00000020
     kworker/0:5-1939  [000] ....   258.827423: rtcpu_vinotify_event: tstamp:8322076549 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:8321887343 data:0x00000000
     kworker/0:5-1939  [000] ....   258.939382: rtos_queue_peek_from_isr_failed: tstamp:8324443864 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.107389: rtos_queue_peek_from_isr_failed: tstamp:8329443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.219402: rtos_queue_peek_from_isr_failed: tstamp:8334443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.387414: rtos_queue_peek_from_isr_failed: tstamp:8339443860 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.499408: rtcpu_vinotify_error: tstamp:8341860472 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8341857654 data:0x00000589
     kworker/0:5-1939  [000] ....   259.499414: rtcpu_vinotify_event: tstamp:8342149857 tag:FS channel:0x00 frame:2 vi_tstamp:8341853039 data:0x00000010
     kworker/0:5-1939  [000] ....   259.499416: rtcpu_vinotify_event: tstamp:8342149996 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8341857654 data:0x00000589
     kworker/0:5-1939  [000] ....   259.499417: rtcpu_vinotify_event: tstamp:8343234586 tag:FE channel:0x00 frame:2 vi_tstamp:8342719454 data:0x00000020
     kworker/0:5-1939  [000] ....   259.555377: rtos_queue_peek_from_isr_failed: tstamp:8344443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.723358: rtos_queue_peek_from_isr_failed: tstamp:8349443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   259.891328: rtos_queue_peek_from_isr_failed: tstamp:8354443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.059326: rtos_queue_peek_from_isr_failed: tstamp:8359443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.171361: rtcpu_vinotify_error: tstamp:8362692593 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:8362689764 data:0x00000589
     kworker/0:5-1939  [000] ....   260.171367: rtcpu_vinotify_event: tstamp:8362766566 tag:FS channel:0x00 frame:1 vi_tstamp:8362685148 data:0x00000010
     kworker/0:5-1939  [000] ....   260.171369: rtcpu_vinotify_event: tstamp:8362766724 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:8362689764 data:0x00000589
     kworker/0:5-1939  [000] ....   260.171370: rtcpu_vinotify_event: tstamp:8363851290 tag:FE channel:0x00 frame:1 vi_tstamp:8363551563 data:0x00000020
     kworker/0:5-1939  [000] ....   260.227348: rtos_queue_peek_from_isr_failed: tstamp:8364443868 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.339379: rtos_queue_peek_from_isr_failed: tstamp:8369443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.507338: rtos_queue_peek_from_isr_failed: tstamp:8374443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.675307: rtos_queue_peek_from_isr_failed: tstamp:8379443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   260.787306: rtcpu_vinotify_error: tstamp:8383524835 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8383521879 data:0x00000589
     kworker/0:5-1939  [000] ....   260.787313: rtcpu_vinotify_event: tstamp:8383525258 tag:FS channel:0x00 frame:2 vi_tstamp:8383517263 data:0x00000010
     kworker/0:5-1939  [000] ....   260.787315: rtcpu_vinotify_event: tstamp:8383525399 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8383521879 data:0x00000589
     kworker/0:5-1939  [000] ....   260.843315: rtcpu_vinotify_event: tstamp:8384413285 tag:FE channel:0x00 frame:2 vi_tstamp:8384383679 data:0x00000020
     kworker/0:5-1939  [000] ....   260.843323: rtos_queue_peek_from_isr_failed: tstamp:8384443864 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.011304: rtos_queue_peek_from_isr_failed: tstamp:8389443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.179272: rtos_queue_peek_from_isr_failed: tstamp:8394443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.347224: rtos_queue_peek_from_isr_failed: tstamp:8399443879 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.459236: rtcpu_vinotify_error: tstamp:8404356820 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:8404354003 data:0x00000589
     kworker/0:5-1939  [000] ....   261.459244: rtos_queue_peek_from_isr_failed: tstamp:8404443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.459247: rtcpu_vinotify_event: tstamp:8404487179 tag:FS channel:0x00 frame:1 vi_tstamp:8404349387 data:0x00000010
     kworker/0:5-1939  [000] ....   261.459248: rtcpu_vinotify_event: tstamp:8404487340 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:8404354003 data:0x00000589
     kworker/0:5-1939  [000] ....   261.515270: rtcpu_vinotify_event: tstamp:8405572685 tag:FE channel:0x00 frame:1 vi_tstamp:8405215802 data:0x00000020
     kworker/0:5-1939  [000] ....   261.627232: rtos_queue_peek_from_isr_failed: tstamp:8409443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.795234: rtos_queue_peek_from_isr_failed: tstamp:8414443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   261.963236: rtos_queue_peek_from_isr_failed: tstamp:8419443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.131191: rtos_queue_peek_from_isr_failed: tstamp:8424443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.131199: rtcpu_vinotify_error: tstamp:8425188944 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8425186128 data:0x00000589
     kworker/0:5-1939  [000] ....   262.187174: rtcpu_vinotify_event: tstamp:8425646578 tag:FS channel:0x00 frame:2 vi_tstamp:8425181513 data:0x00000010
     kworker/0:5-1939  [000] ....   262.187177: rtcpu_vinotify_event: tstamp:8425646723 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:8425186128 data:0x00000589
     kworker/0:5-1939  [000] ....   262.187179: rtcpu_vinotify_event: tstamp:8426189386 tag:FE channel:0x00 frame:2 vi_tstamp:8426047929 data:0x00000020
     kworker/0:5-1939  [000] ....   262.299229: rtos_queue_peek_from_isr_failed: tstamp:8429443979 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.467173: rtos_queue_peek_from_isr_failed: tstamp:8434443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.579144: rtos_queue_peek_from_isr_failed: tstamp:8439443887 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.747178: rtos_queue_send_from_isr_failed: tstamp:8443533645 queue:0x0bcb41f8
     kworker/0:5-1939  [000] ....   262.747192: rtos_queue_send_from_isr_failed: tstamp:8443533799 queue:0x0bcb8a60
     kworker/0:5-1939  [000] ....   262.747194: rtos_queue_send_from_isr_failed: tstamp:8443533951 queue:0x0bcba5e0
     kworker/0:5-1939  [000] ....   262.747196: rtos_queue_send_from_isr_failed: tstamp:8443534098 queue:0x0bcbb3a0
     kworker/0:5-1939  [000] ....   262.747201: rtos_queue_send_from_isr_failed: tstamp:8443534244 queue:0x0bcbc160
     kworker/0:5-1939  [000] ....   262.747202: rtos_queue_send_from_isr_failed: tstamp:8443584646 queue:0x0bcb41f8
     kworker/0:5-1939  [000] ....   262.747203: rtos_queue_send_from_isr_failed: tstamp:8443584814 queue:0x0bcb8a60
     kworker/0:5-1939  [000] ....   262.747205: rtos_queue_send_from_isr_failed: tstamp:8443584967 queue:0x0bcba5e0
     kworker/0:5-1939  [000] ....   262.747206: rtos_queue_send_from_isr_failed: tstamp:8443585115 queue:0x0bcbb3a0
     kworker/0:5-1939  [000] ....   262.747207: rtos_queue_send_from_isr_failed: tstamp:8443585260 queue:0x0bcbc160
     kworker/0:5-1939  [000] ....   262.747210: rtcpu_string: tstamp:8443592147 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:5-1939  [000] ....   262.747242: rtcpu_string: tstamp:8443592325 id:0x04010000 str:"VM GOS[#0] addr=0xe4900000
     kworker/0:5-1939  [000] ....   262.747256: rtcpu_string: tstamp:8443592581 id:0x04010000 str:"VM GOS[#1] addr=0xe4901000
     kworker/0:5-1939  [000] ....   262.747266: rtcpu_string: tstamp:8443592850 id:0x04010000 str:"VM GOS[#2] addr=0xe4902000
     kworker/0:5-1939  [000] ....   262.747276: rtcpu_string: tstamp:8443593083 id:0x04010000 str:"VM GOS[#3] addr=0xe4903000
     kworker/0:5-1939  [000] ....   262.747285: rtcpu_string: tstamp:8443593316 id:0x04010000 str:"VM GOS[#4] addr=0xe4904000
     kworker/0:5-1939  [000] ....   262.747294: rtcpu_string: tstamp:8443593551 id:0x04010000 str:"VM GOS[#5] addr=0xe4905000
     kworker/0:5-1939  [000] ....   262.747304: rtos_queue_peek_from_isr_failed: tstamp:8444443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   262.919178: rtos_queue_peek_from_isr_failed: tstamp:8449443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.087148: rtos_queue_peek_from_isr_failed: tstamp:8454443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.255130: rtos_queue_peek_from_isr_failed: tstamp:8459443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.423151: rtos_queue_peek_from_isr_failed: tstamp:8464443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.535137: rtos_queue_peek_from_isr_failed: tstamp:8469443879 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.703114: rtos_queue_peek_from_isr_failed: tstamp:8474443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   263.871077: rtos_queue_peek_from_isr_failed: tstamp:8479443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.039061: rtos_queue_peek_from_isr_failed: tstamp:8484443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.207058: rtos_queue_peek_from_isr_failed: tstamp:8489443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.375034: rtos_queue_peek_from_isr_failed: tstamp:8494443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.547028: rtos_queue_peek_from_isr_failed: tstamp:8499443860 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.659074: rtos_queue_peek_from_isr_failed: tstamp:8504443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.827007: rtos_queue_peek_from_isr_failed: tstamp:8509443864 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   264.995000: rtos_queue_peek_from_isr_failed: tstamp:8514443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.162986: rtos_queue_peek_from_isr_failed: tstamp:8519443887 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.331040: rtos_queue_peek_from_isr_failed: tstamp:8524443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.498984: rtos_queue_peek_from_isr_failed: tstamp:8529443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.666964: rtos_queue_peek_from_isr_failed: tstamp:8534443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.779002: rtos_queue_peek_from_isr_failed: tstamp:8539443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   265.946981: rtos_queue_peek_from_isr_failed: tstamp:8544443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.114953: rtos_queue_peek_from_isr_failed: tstamp:8549443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.282915: rtos_queue_peek_from_isr_failed: tstamp:8554443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.450944: rtos_queue_peek_from_isr_failed: tstamp:8559443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.618927: rtos_queue_peek_from_isr_failed: tstamp:8564443861 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.786937: rtos_queue_peek_from_isr_failed: tstamp:8569443883 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   266.898934: rtos_queue_peek_from_isr_failed: tstamp:8574443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.066904: rtos_queue_peek_from_isr_failed: tstamp:8579443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.234879: rtos_queue_peek_from_isr_failed: tstamp:8584443861 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.402883: rtos_queue_peek_from_isr_failed: tstamp:8589443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.570857: rtos_queue_peek_from_isr_failed: tstamp:8594443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.738910: rtos_queue_peek_from_isr_failed: tstamp:8599443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   267.906830: rtos_queue_peek_from_isr_failed: tstamp:8604443887 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   268.018912: rtos_queue_peek_from_isr_failed: tstamp:8609443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   268.186845: rtos_queue_peek_from_isr_failed: tstamp:8614443866 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   268.354810: rtos_queue_peek_from_isr_failed: tstamp:8619443865 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   268.522793: rtos_queue_peek_from_isr_failed: tstamp:8624443864 queue:0x0bcbcf78
     kworker/0:5-1939  [000] ....   268.634811: rtos_queue_peek_from_isr_failed: tstamp:8627506571 queue:0x0bcbcf78
I’ve managed to solve the problem.
embedded_metadata_height had the wrong value.
If you could still send me error description of vi log it would be great.
