No representor interfaces in infiniband based bluefield 2 dpu
I’m testing bluefield 2 dpu on my testbed.
I have two gigabyte g242-p33 servers with bluefield-2 dpu and two servers are connected to a qm8700 infiniband switch.
I installed doca 2.8.0 on host side and dpu side.
However, I don’t see any representor interfaces from host side and dpu side.
Also, when I execute “ovs-vsctl show” on dpu side, it shows me nothing.
I used dpu mode and I set link type to infiniband.
host side:
root@bf03:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether d8:5e:d3:84:db:c3 brd ff:ff:ff:ff:ff:ff
altname enP3p2s0f0
3: eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether d8:5e:d3:84:db:c4 brd ff:ff:ff:ff:ff:ff
altname enP3p2s0f1
5: ibP2s3f0: <BROADCAST,MULTICAST> mtu 4092 qdisc noop state DOWN mode DEFAULT group default qlen 256
link/infiniband 00:00:00:27:fe:80:00:00:00:00:00:00:08:c0:eb:03:00:f1:54:e0 brd 00:ff:ff:ff:ff:12:40:1b:ff:ff:00:00:00:00:00:00:ff:ff:ff:ff
altname ibP2p2s0f0
7: tmfifo_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 00:1a:ca:ff:ff:02 brd ff:ff:ff:ff:ff:ff
dpu side:
root@localhost:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAUL0
2: tmfifo_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state0
link/ether 00:1a:ca:ff:ff:01 brd ff:ff:ff:ff:ff:ff
3: oob_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP0
link/ether 08:c0:eb:f1:54:e6 brd ff:ff:ff:ff:ff:ff
altname enamlnxbf17i0
4: ib0: <BROADCAST,MULTICAST> mtu 4092 qdisc noop state DOWN mode DEFAULT group6
link/infiniband 00:00:10:c7:fe:80:00:00:00:00:00:00:08:c0:eb:03:00:f1:54:e2f
altname ibp3s0
root@localhost:~# ovs-vsctl show
3b84ffb5-afe8-451f-ac54-fca440beab21
ovs_version: “2.8.0-0091-24.07-based-3.3.0”
root@localhost:~#
When I tested it with an ethernet switch and link type set to ethernet, everything was ok.
Is dpu mode only available in an ethernet environment where the link type is set to ethernet?
BR,
Jae-Hyuck
Hello jhkwak,
Thank you for posting your inquiry on the NVIDIA Developer Forum - Infrastructure and Networking - Section.
Currently DPU mode in Infiniband is limited to the physical interface only, no representer option currently.
When the port type is set to Ethernet you have full capability regarding representers.
Thank you and regards,
~NVIDIA Networking Technical Support
