I am trying to run Isaac sim through omniverse, but when I click on launch, it just loads for sometime and stops.
Are you sure you are not running Isaac Sim on a remote PC?
Yes, this is running on my own server
You should launch Isaac Sim with headless mode and use LiveStream Client.
https://docs.omniverse.nvidia.com/isaacsim/latest/installation/manual_livestream_clients.html#livestream-clients
Isaac Sim cannot support to launch GUI from remote PC
I got the same problem, but when I try to launch Isaac Sim via Remote Desktop. My Host Machine runs Ubuntu 22.04 and the client is runnung windows 11.
When I’m working directly on my ubuntu machine, Isaac Sim launches and runs totally fine.
Do you habe any Sugguestion please?
Thanks in advance!
Even with remote desktop, Isaac Sim cannot launch a GUI.
In this case, you should still use LiveStream Client.
Thank you hijimasa for your reply.
I already have omniverse client streaming app installed on the host machine. That means I need to install omniverse and the client streaming app on my windows Laptop and put there into the “Server Field” the IP adress of my ubuntu machine?
You only need to install the omniverse client streaming app on your Windows laptop.
Enter the Ubuntu IP address into the omniverse client streaming app launched on the Windows laptop.
Thank you again hijimasa.
I’ trying to install omniverse Launcher on my windows machine following those steps
Installation on Windows — Omniverse Launcher latest documentation (nvidia.com)
but got this error as I tried to log into the Nvidia Licencing Portal.
Is there any other way to get the omniverse launcher installer for windows?
You can download Omniverse Launcher from SDK Download page.
Thank you hijimasa :)
by the way this time as I wanted to launch Isaac Sim via remote desktop I got this error message
GPU Foundation: Failed to create any GPU devices, including an attempt with compatibility mode.
And I installed omniverse launcher and streaming app on the windows machine and as I tried to connect to the ubuntu machine with the exact same IP adress that I use for remote desktop I got this error
Any thoughts?
You may get such an error when Isaac Sim in headless mode is not fully up and running; start Isaac Sim, wait some minutes and try it.
kit_20240813_184038.log (354.4 KB)
here is my log file.
Could you show me “nvidia-smi” command result?
How did you connect to host PC?
