Please provide the following info:
Hardware Platform: [DRIVE AGX Pegasus™ Developer Kit]
Software Version: [DRIVE Software 10]
Host Machine Version: [native Ubuntu 18.04]
SDK Manager Version: [-]
Hello, since last week, last time I restarted the pegasus drive, the screen wont boot up. but, for some reason Xavier B does work, when I plug straight into XB hdmi port, but XA-(1 to 4) does not work at all.
any idea what can be the reason and what can be done?
Thanks in advance.
Dear @mikepo2808,
Are you able to connect to XA via minicom. Is it possible to re flash the target? If so, please check and let us know if the issue persists?
I faced same problem on my Drive AGX Xavier Dev Kit. Had to re-flash the kit to solve the issue.
Dear @mikepo2808,
did you check re-flashing? Could you provide any update?
Re-flashing the drive solves the problem.
Hello
I faced the same issue and tried to reflash the kit with Drive Software 10.0(rev.2) using SDK manager version 1.5.0.774 , however I am still not getting any HDMI output from Xavier A only Xavier B HDMI output seems to be working
note: Parallel flashing took very long. Xavier B was flashed in 72 minutes while Xavier B took 82 minute. Is this expected ?
Dear @alaa.mahdy,
Could you please file new topic
